Screen white Samsung LE37B550A5W
    Hi!.We have this tv for repair with the white screen and i can see the menu a little under.
    Any idea?.THanks and regards
    Re: Screen white Samsung LE37B550A5W
    It sounds like it has GAMMA Voltage probelm on the T-CON board due to bad GAMMA Vref. IC.
    Can we see the screen shot of the image you are seeing? Also the pictures of the T-CON board.
      Ok,the sound works and this the pictures:
        The SMD is on the bottom left of that T-CON board, it may be AS15 or AS19, I cannot read the number from your pictures.
          Replace as15 chip, many videos on youtube.
            It´s a AS15,how can check it?.Thanks
              Don't check it, change it, resolution 100%
                But i would like to learn how i can check if its fail.
                  Putting "gamma test" into the search box at the top of the page will reveal many threads detailing the procedure.
                    Ok,thanks!.
                      Hi again.
                      With the TV turned on and the antenna connected I have taken these measurements, some VG are missing:
                      VG1=15,25v
                      VG2=14,96v
                      VG4=12,48v
                      VG6=10,87v
                      VG8=9,99v
                      VG10=8,82v
                      VG11=8,57v
                      VG12=7,60v
                      VG13=7,89v
                      VG15=5,56v
                      VG17=4,66v
                      VG19=3,15v
                      VG21=0,60v
                      VG22=0,30v
                      V1D2=1,20v
                      VGHC=27,11v
                      VGL=-5,9v
                        As suspected, they don't look like right.
                          Where do you see the irregularities?, In which VG?.
                          I am a newbie and I want to learn to recognize this fault
                            There is an excel file on here that tom66 created.
                            The voltages should read a nice even slope down.
                              I'm going to look for that excel and try to understand it. Thanks
                                To save you looking.
                                  Ohhhh!,thanks mate!
                                    If I pass the data that I have measured to the graph of the excel I can see that the relationship between the tensions is not correct.
                                      For example, VG12 and VG13, VG10 and VG11, have very close tensions
                                        Yes, you're correct.
