Screen white Samsung LE37B550A5W
  • Nawual
    • Jul 2016
    • 65
    • Spain
    Hi!.We have this tv for repair with the white screen and i can see the menu a little under.
    Any idea?.THanks and regards
    Re: Screen white Samsung LE37B550A5W
    It sounds like it has GAMMA Voltage probelm on the T-CON board due to bad GAMMA Vref. IC.
    Can we see the screen shot of the image you are seeing? Also the pictures of the T-CON board.
    • Nawual
      • Jul 2016
      • 65
      • Spain
      Ok,the sound works and this the pictures:
        The SMD is on the bottom left of that T-CON board, it may be AS15 or AS19, I cannot read the number from your pictures.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4456
          • Italy - Milan
          Replace as15 chip, many videos on youtube.
          • Nawual
            • Jul 2016
            • 65
            • Spain
            It´s a AS15,how can check it?.Thanks
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4456
              • Italy - Milan
              Don't check it, change it, resolution 100%
              • Nawual
                • Jul 2016
                • 65
                • Spain
                But i would like to learn how i can check if its fail.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Putting "gamma test" into the search box at the top of the page will reveal many threads detailing the procedure.
                  • Nawual
                    • Jul 2016
                    • 65
                    • Spain
                    Ok,thanks!.
                    • Nawual
                      • Jul 2016
                      • 65
                      • Spain
                      Hi again.
                      With the TV turned on and the antenna connected I have taken these measurements, some VG are missing:
                      VG1=15,25v
                      VG2=14,96v
                      VG4=12,48v
                      VG6=10,87v
                      VG8=9,99v
                      VG10=8,82v
                      VG11=8,57v
                      VG12=7,60v
                      VG13=7,89v
                      VG15=5,56v
                      VG17=4,66v
                      VG19=3,15v
                      VG21=0,60v
                      VG22=0,30v
                      V1D2=1,20v
                      VGHC=27,11v
                      VGL=-5,9v
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        As suspected, they don't look like right.
                        • Nawual
                          • Jul 2016
                          • 65
                          • Spain
                          Where do you see the irregularities?, In which VG?.
                          I am a newbie and I want to learn to recognize this fault
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            There is an excel file on here that tom66 created.
                            The voltages should read a nice even slope down.
                            • Nawual
                              • Jul 2016
                              • 65
                              • Spain
                              I'm going to look for that excel and try to understand it. Thanks
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                To save you looking.
                                • Nawual
                                  • Jul 2016
                                  • 65
                                  • Spain
                                  Ohhhh!,thanks mate!
                                  • Nawual
                                    • Jul 2016
                                    • 65
                                    • Spain
                                    If I pass the data that I have measured to the graph of the excel I can see that the relationship between the tensions is not correct.
                                    • Nawual
                                      • Jul 2016
                                      • 65
                                      • Spain
                                      For example, VG12 and VG13, VG10 and VG11, have very close tensions
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        Yes, you're correct.
                                        • harp
                                          White screen repairs
                                          by harp
                                          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                          05-13-2024, 03:43 AM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                          by JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                          No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                          Please help. Thanks in advance!
                                          08-12-2025, 11:45 AM
                                        • Kiberge
                                          Samsung LH82QENELGC/EN Help needed - Static line on screen
                                          by Kiberge
                                          HI guys!
                                          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                          04-22-2024, 11:28 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
