Insignia service menu
  • Jackching
    • May 2017
    • 127
    Anyone know the process to get into the Insignia NS-L322Q-NA service menu? I cannot turn off over-scan while watching the satellite. A lot of the picture is missing.
    Re: Insignia service menu
    Do you have the remote to change the Image setting, I.E. ZOOM, FULL, 4:3, etc.
    • Jackching
      • May 2017
      • 127
      Yes i scrolled through the different sizes but wide is the closest setting. Overscan is turned on by default in the menu and it wont let me turn it off.
      • R_J
        • 9628
        Have you checked the setting in the satellite reciever, maybe the output can be changed there.
        • Jackching
          • May 2017
          • 127
          yes i went through all the settings on the bell receiver also. Say if i go to my roku stick, the tv lets me turn off over-scan then and the video is fine. Soon as i go back to satellite, over-scan is greyed out again.
          • R_J
            • 9628
            which inputs are they conncted to? Likely the hdmi input is the one that the overscan is greyed out. Did this just happen or has it always been this way? I see there is a format button on the bell remote and one of the settings is stretch (stretches the image and makes it wider)
            • budwich
              • Jul 2015
              • 3097
              if you look at the bell sat when you change channels, there is an indication of what the sat receiver has been set for in terms of aspect ratio for both SD and HD channels. "page up" and "page down" on the remote allows the user to cycle the appropriate settings for either SD or HD depending on the channel being watch. People (me) sometimes cause problems when "paging" thru the guide and this results in "inadvertent" changes of the aspect.
                LCD LED TV Service Menu Codes
                ALL LCD LED TV SERVICE MENU CODES
                Service Menu Code with Board Name
                China Universal Board / Jumper Board Service Menu Code
                Changhong Ruba Service Menu Code
                Ecostar LED TV Service Menu Code
                Orient LED TV Service Menu Code
                Haier LED TV Service Menu Code
                TCL LED TV Service Menu Code
                Samsung LED TV Service Menu Code
                LG LED TV Service Menu Code
                Videocon LED TV Service Menu Code
                Supra LED TV Service Menu Code
                Toshiba LED TV Service Menu Code
                Symphony LED TV Service Menu Code
                Veste/ LED TV Service Menu Code...
                10-31-2024, 03:58 AM
              • Robby-Gr
                TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
                by Robby-Gr
                I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
                However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
                The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
                Additional issues:...
                09-27-2025, 12:02 AM
              • tusiime
                How to access Vizio m652i-b2 service menu
                by tusiime
                The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
                So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
                Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
                09-15-2023, 09:57 AM
              • intercepter
                JVC LT-32CA120 service menu
                by intercepter
                I have JVC LT-32CA120
                Board:Vestel 17MB171
                I need rotate screen.It is possible in service menu and how to enter service menu?
                Thanks.
                12-10-2024, 10:29 AM
              • alltvrepairs
                Jvc Lt-65VU3000 reduce backlight from service menu
                by alltvrepairs
                I have just replaced led set of this vestel tv due to age.
                I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
                Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
                Thanks again....
                09-20-2025, 05:03 AM
