JVC LT-32CA120 service menu
  • intercepter
    • Sep 2016
    • Bosna i Hercegovina
    I have JVC LT-32CA120
    Board:Vestel 17MB171
    I need rotate screen.It is possible in service menu and how to enter service menu?
    Thanks.
  • yokoono
    • Apr 2010
    • 517
    1. Have you tried with the MENU 4725 key?.
    2. At Vestel, you cannot return the image from SM
    3. I don't think you can, but try to save the TV panel profile on the stick (with downloadpq.mb171 folder)​
    • intercepter
      • Sep 2016
      I find service menu with Menu-advanced options-4725 but no find any option for return image in service menu.
      I try with this metod but no success.
      https://www.badcaps.net/forum/troubl...flip-the-image
      How to get DownloadPq.mb171 from this board?
      • yokoono
        • Apr 2010
        • 517
        Save the panel profile from the TV and post it here to return the image.
        1. Format a stick with FAT32
        2. Create a folder called downloadpq.mb171 on the stick
        3. Turn on the TV and type MENU 4725
        4. Go to USB Options and type OK on the remote control
        5. After 10 seconds you can remove the USB stick and you will have some files on the stick.
        6. You post them here.
        You can try this method but I do not guarantee that it will work. I have not repaired the TV with this motherboard until now.​
          LCD LED TV Service Menu Codes
          TCL LED TV Service Menu Code
          LG LED TV Service Menu Code
          10-31-2024, 03:58 AM
        • Robby-Gr
          TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
          by Robby-Gr
          I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
          However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
          The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
          Additional issues:...
          09-27-2025, 12:02 AM
        • kintaro77
          Service Menu Device Lock in LG UHD Hi3751V352
          by kintaro77
          Hello brilliant minds!
          I was busy hacking my LG android TV to remove the tons of restrictions and Bloatware that came with it, when I discovered the service menu by entering INPUT 2580 on the remote. However I accidentally clicked the DEVICE LOCK option and now my TV is asking me for a password. I have literally tried every code I have come across on the internet and nothing works. I don't know what the default password for this is.
          The TV is a LG 50UQ70 (specifically the smart models using the Hi3751 board). It is very likely a Chinese board. The board is specifically...
          01-08-2026, 11:56 PM
        • tusiime
          How to access Vizio m652i-b2 service menu
          by tusiime
          The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
          So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
          Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
          09-15-2023, 09:57 AM
        • alltvrepairs
          Jvc Lt-65VU3000 reduce backlight from service menu
          by alltvrepairs
          I have just replaced led set of this vestel tv due to age.
          I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
          Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
          Thanks again....
          09-20-2025, 05:03 AM
