TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
This topic has been answered.
  • Robby-Gr
    • Sep 2025
    • 22
    • Greece
    I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
    However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
    The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
    Additional issues:
    - The HDMI ports behave incorrectly: port order seems scrambled (e.g., HDMI 1 acts like HDMI 2)
    - No audio output over HDMI, even though video works
    Here’s what I’ve tried so far:
    - Adjusted Type, Local Set, Front Color, Panel Display Type, Model, Tuner, EDID Write, etc.
    - Compared values with other HU8500 units
    - Verified internal connections and performed factory resets
    Despite this, I haven’t found the correct configuration that allows the TV to boot normally and restore full HDMI functionality. The image looks fine after reset, but the boot loop returns after power off.
    📸 I can share screenshots of the current service menu settings if helpful.
    👉 I’m specifically looking for the correct service menu values for this 2014 4K model in Europe/Greece, especially after a panel replacement with 55A1UU8EH. If anyone has experience with HU8500 servicing or knows the right configuration for this region, I’d be grateful for your help.
    🛠️ As an alternative solution, I’m also exploring firmware engineering and reflashing. If I can reflash the firmware successfully, I may be able to reinstall the latest version (1410) cleanly and potentially resolve the boot/audio issues. If anyone has experience with reflashing on this series or knows whether this approach could help, I’d love to hear your thoughts.
    Thanks in advance!
    Kostas
  • Answer selected by Robby-Gr at 09-27-2025, 05:48 AM.
    Davi.p
    Hobbist Tech
    • Sep 2009
    • 4450
    • Italy - Milan
    Lotas there are codes for LG and Samsung, The Samsung ones enlarges some already big menus, Samsung menu has 3 level of menu access, the stanard one, the Advanced section with password and the full menu, he needs the full menu access to be able to give the write command next to panel type to enable it, this is what i remember..
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4450
      • Italy - Milan
      I do not know why but the window with the panel type seems to lack some items, try to access the full menu by entering the service remote key, even by portable device + ir blaster + wav file (i have the files) , so you can unlock the panel type & front color write options..
      • Diah
        • Feb 2013
        • 6435
        go to samygo.tv and you will find complete entry service menu Photos to compare
        • William1967
          • Nov 2017
          • 215
          • Netherlands
          Maybe the problem is the panel number, you write 55A1UU8EH but the data says 55A1UU9RH. The OCB sees a different panel than and maybe therefor the tv resets.
          • lotas
            • Jan 2016
            • 4740
            • Russia
            Yes, you have some strange model in the menu, it should be like this.
            • lotas
              • Jan 2016
              • 4740
              • Russia
              Don't confuse LG with Samsung.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4450
                • Italy - Milan
                • lotas
                  • Jan 2016
                  • 4740
                  • Russia
                  Why bother with such complications? There is a special remote control AA81-00243A, and it costs pennies.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4450
                    • Italy - Milan
                    It's up to the thread owner to decide, where is the problem? The less the items the less confusion and earth pollution
                    • lotas
                      • Jan 2016
                      • 4740
                      • Russia
                      And before doing any manipulations in the service menu, you need to make a backup of the eeprom 24C256 (512), so that you can return everything to its original state, as it was initially, otherwise you can change something in the settings and after that the TV may not turn on at all.
                      • Robby-Gr
                        • Sep 2025
                        • 22
                        • Greece
                        You're right, William1967. You must have looked at the wrong panel in an internal menu;
                        that was from other tests. It's actually the first option, though of course, I don't know
                        if that one is correct either, but it's working well. Thank you very much for your help
                        with the issues I mentioned.
                        Hello Davi.p, thank you for the very quick response. Your information is extremely helpful!
                        Despite that, I'm lacking some technical knowledge—I'm not sure how to use the .wav files
                        you sent me. I will look into it, but even if I manage to access the deeper Service Menu,
                        I will still be missing the correct values to input. Regarding the Service Remote Control,
                        I will look into how I can purchase one. Thank you again for all your help. Kostas
                        Hello Lotas, your note and the hint with the image you sent really woke me up, because
                        I was taking that panel for granted and wasn't paying attention to the model listed there!
                        Also, the image of the remote control was very helpful. Thank you again. Kostas
                        Hello Diah, I will check Samy.go.tv and I hope to find something to save my old but really
                        very good TV. Thanks a lot, your help, like everyone else's, is invaluable​
                        • Robby-Gr
                          • Sep 2025
                          • 22
                          • Greece
                          About Samsung UE55HU8500
                          Hello DiahI visited samyGo.tv and found one interesting post I will inform you when I have some action on it. Thanks
                          • Robby-Gr
                            • Sep 2025
                            • 22
                            • Greece
                            • Robby-Gr
                              • Sep 2025
                              • 22
                              • Greece
                              • Robby-Gr
                                • Sep 2025
                                • 22
                                • Greece
                                • Robby-Gr
                                  • Sep 2025
                                  • 22
                                  • Greece
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4450
                                    • Italy - Milan
                                    Not that difficult, you need a smartphone or tablet and a IR blaster, it's a simple 3,5mm mono or stereo plug with a resistor and a ir led, you can purchase it on eBay, it's 1-2 euro thing, or you can make it by yourself, it needs the stereo plug, an ir led taken from old useless remote commander, and a 100 ohm resistor, well i used a 20 ohm but it works only on my old phone, i don't know why, from tip ----resistor----anode---cathode----ring.. Put volume to maximum ad go close to the tv receiver, you need to be already in service mode, if you use stereo plug, join center ring to gnd ring, you have to play the wav file by a file manager like total commander for android..
                                    • Robby-Gr
                                      • Sep 2025
                                      • 22
                                      • Greece
                                      I thing is better to buy one service remote control is very chp!. After that I will enter the settings I found in SamyGo.Tv Diah send me I will inform you when I will be ready
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4450
                                        • Italy - Milan
                                        i tapped the link someone gave to you, i do not find the instruction there, since you seem not practical, i suggest you to ask what to do of what you see exactly before doing actions..
                                        • Diah
                                          • Feb 2013
                                          • 6435
                                          the link i gave you are threat name Defult Service Menu Setting UE65HU8500 , at first post there are link for the photos of service menu.
                                            09-07-2024, 05:50 AM
                                          • GeckoGreen
                                            Samsung service bulletin: need firmware file for PN63C550 TV
                                            by GeckoGreen
                                            I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
                                            You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
                                            The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
                                            Will you please help me get the [2D63]LOGIC.bin file for my TV?
                                            05-17-2025, 02:47 PM
                                          • sikocan
                                            NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
                                            by sikocan
                                            I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
                                            However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
                                            01-11-2024, 01:47 AM
                                            LCD LED TV Service Menu Codes
                                            TCL LED TV Service Menu Code
                                            LG LED TV Service Menu Code
                                            10-31-2024, 03:58 AM
                                          • Mirenia
                                            Samsung UEMU6199U - no Standby - bad Firmware?
                                            by Mirenia
                                            I've got a Samsung UEMU6199U which has no Standby LED and no reaction if try turning it on.
                                            Voltages on the power supply board is okay. Backlight test is also okay.
                                            I read about a corrupt firmware on IC1604 on some models, did a dump of this IC and turns out: First sectors are empty.
                                            So I think my TV has exactly this issue.
                                            Can someone please fix the dump?
                                            And how do you do that?
                                            As I understand you fill in the empty sectors and leave the rest as it is. But where do you get the "information" of what you...
                                            05-12-2025, 06:13 AM
