philips 42pfl6007h dead...
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    hi all, a m8 got this tv that was working fine till some days ago when suddenly it wont turn on.
    if he press remote control to turn on, the red light on tv blink, but nothing happens.
    if he left tv on its own, the red led start blinking twice.
    hre is some picture of mainboard inside that looks like new... no bad component spotted.
    any help would be good
    edit: ive done some measurement and on a component on green pc board, i got 5 volt for 1 second when psu board emitted one high tone noise, and then that 5 volt went down after that seconds. that things repeat every 30-60 minute. didnt measured the interval time exactly, but keep doing like this.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4539
    • Italy - Milan
    Re: philips 42pfl6007h dead...
    Cacchio ho dovuto leggere 5 volte per capire che m8=mate!! Mannaggia..
    Why that mate gave it to you? It was already defective?
    If i'm right theese boards suffers from software problems, i have a 6008 series with a similar fault, you better solder 2 wires to the SDM solder place on mainboard and on a GND spot then join those together , switch on the current and the tv , watch the SDM mode led pulsing, and after download service manual to know what's the error, long blinks are decimals, short are units, ex. 5long 3 short means 53.
    If you have 53 much probably software error, you need to find a way to upgrade it, serv. man. tells you several recovery modes on how to begin update.
    • dellxps15
      • Feb 2014
      • 1598
      • italy
      tnx for reply. problem is that tv doesnt seems to get 5 volts. when there is a memory problem i see philips logo should pop up on tv, while here is totally dead....
      edit: strange thing as i said is that on the marked red zone in picture if i put multimeter for measure volts, it is 0 volt..... then after a bit it goes to -0.4 (negative volts) volt for some seconds, then to 5 volt (positive this time) and then back to 0 volt.
      why that - 0.4 volt ?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4539
        • Italy - Milan
        That zone is for audio output VS internal loudspeakers, i repeat if you want to hear me (old scurengion.. =-) you have to enter SDM mode..
        • dellxps15
          • Feb 2014
          • 1598
          • italy
          post an edited picture of the shorted wire i have to do....
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4539
            • Italy - Milan
            There's no need of a picture, watch yours, on the center bottom zone there's an electrolytic cap, on top of it the big flash memory, on the side of it the SDM place clearly visible, for the GND place you can peel the wire and wrap it around a screw for board fixing.
            • dellxps15
              • Feb 2014
              • 1598
              • italy
              tnx, now i found it. so i have to solder a wire to that smd and one to gnd, and then connect them so smd is shorted. after that power on tv and read code ?
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4539
                • Italy - Milan
                Yes, SDM not SMD... or to be more safe use only a wire from SDM to the chassis screw..
                • dellxps15
                  • Feb 2014
                  • 1598
                  • italy
                  tnx very much for reply. soldering done and the result is an error code 53
                  what's next ?
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4539
                    • Italy - Milan
                    So you only get led blinks and no audio/video?
                    As my last sentence on post #2, check the serv. man. for instruction on various recovery modes for upgrading it. I never tested them with mine...
                    • dellxps15
                      • Feb 2014
                      • 1598
                      • italy
                      yes tv is dead except that blinking. tried put firmware on usb but no sign of life....
                      couldnt be that bga need reflow ? i see video on youtube that when software problem, philips logo at least comes on...
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4539
                        • Italy - Milan
                        Which term do you search on youtube?
                        Watch this: https://www.youtube.com/watch?v=MGpUdFhivg0&t=22s
                        if you try many many times with remote or on board keys do you have a boot?
                        Since tha fault is no booting at all, maybe the software to upgrade is the standby one that normal upgrade doesn't upgrade..
                        • dellxps15
                          • Feb 2014
                          • 1598
                          • italy
                          philips tv led blinking
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4539
                            • Italy - Milan
                            I don't see the videos you say, what about my previous post?
                            It can also be a defective standby sw chip (25xxx)
                            • dellxps15
                              • Feb 2014
                              • 1598
                              • italy
                              im not expert on tv . the problem as describes is a tv that keep cliking every around 30 seconds (relè?) but no picture no sound no logo. nothing. all voltages looks present, the bga chip also get hot and i measured some voltage on the ssb and there are different olts, but no picture. wich one is the swich chip and where is it located ? and measure i can make with multimeter ?
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4539
                                • Italy - Milan
                                you describe your problem? you never told about relay clicking.. what switch chip are you talking aboout? I never said this..
                                • dellxps15
                                  • Feb 2014
                                  • 1598
                                  • italy
                                  dunno if its a relay, but every some times it make a pitch noise and 5 volt comes from that audio zone, so i can imagine its a relay ? 25xxx is a bios ? i can try to reprogram it , but wich file i need to put on it ?
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4539
                                    • Italy - Milan
                                    There are no image files available for theese tasks, i have an image for another model, 6008 series, 25xxx is standby software, not main software. I think the fault is more on the NAND flash than serial flash, because led blinks and the diagnostic routines works on the standby processor and memory.. It was helpful to have acces to the debug serial line on the board, but it is needed a low voltage rs232 i think, and on my board there are lot of connector solder places for uart et similar..
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4539
                                      • Italy - Milan
                                      For the RS232 adapter you can use a CH341 eeprom programmer / USB-232 adapter.
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        Check soldering on all 8 pinvoltage regulators on main board. I had a philips do this where the Voltage for the 1.1 v core to the main processor with shooting up towards 6 because of the control pin on one of that regulators for feedback were not making a good contact. The processor itself was making a high pitch ringing sound when this occurred with a 2 Flash shut down.
                                        • kew1701
                                          Philips taw6205 ambilight speaker STM32 mcu dead
                                          by kew1701
                                          Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
                                          04-09-2025, 03:59 AM
                                        • Rubenlily
                                          Philips 50PUS6503 - dead panel? Picture
                                          by Rubenlily
                                          Hey,
                                          I gave up on my last TV and got a new one to try.
                                          Only vertical lines. Sound is OK. Screen is black with a few white lines until I change channel, then these colors gradually starts filling up the screen.
                                          Is this fixable in any way or should I just give up on this one too?...
                                          08-21-2023, 01:07 PM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • alro7779
                                          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                          by alro7779
                                          Hello, guys!
                                          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                          09-14-2025, 12:25 AM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
