philips 42pfl6007h dead...
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    Re: philips 42pfl6007h dead...
    tnx both for reply. was it a led tv? because i think old plasma tv got different led indicator.
    ill try my best to find if all voltages are ok
    • freakaftr8
      • Oct 2012
      • 3743
      Mine was LED also. 47 inch
      • dellxps15
        • Feb 2014
        • 1598
        • italy
        tnx for your help. problem is solved by reflowing the bga. tv is back to a normal working condition. u put a better heatsink and a notebook fan on 3.3 volt to dissipate heat.
        • freakaftr8
          • Oct 2012
          • 3743
          Nice!
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4539
            • Italy - Milan
            OK thanks, i've heard about the same thing for the 6008 by a Philips tech, the CPU gets too hot, it exists a modify to lower the temp, don't know which, so upgrade to the last version hoping that will solve a bit..
            • dellxps15
              • Feb 2014
              • 1598
              • italy
              #26
              tv was already on latest firmware version, i wrote "u" but was meaning "I" put a heatsink and a fan , so cpu now should run very cooler
              • boxteko
                • Dec 2018
                • 5
                • spain
                #27
                I have the same problem as you with the tv, you can tell me some first easy checkings to know where it,s my problem??
                sorry my english, i,m from spain
                • boxteko
                  • Dec 2018
                  • 5
                  • spain
                  #28
                  also i,ve realised that my psu board does the same 30 seconds sound that you (dellxps15) told in the beginning of the post, also the bga get warm from the heatsink side and when the two blink error starts, the sound and bga warming finishes...maybe this helps hahahhh
                  • boxteko
                    • Dec 2018
                    • 5
                    • spain
                    #29
                    yesterday was a good night, as my tv was doing "the same" as dell,s, i unassembly the main board and did a little reflow, not a good one because I have no idea how to do it and have no tools, with a hair dresser and contact cleaner.
                    now the tv starts but I still not get philips letters and the screen is working, but i don,t get the real image. I hope you understand me and help me doing a good reflow to the chip. In the worst i know the problem of my tv and getting a new main board and installing it, right??
                    thank you for everything
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4539
                      • Italy - Milan
                      #30
                      New mainboards are off sale, reflowing with phon / hair dresser is not possible, needed at least a hot air gun, and the chip must move at a certain point, i use a double temp one with a long warming on 300 degrees and a fast warming on 600 deg. but attention not to get too close as the chip may be destroyed and nearby components fly away.. heatsink must be detached.
                      • boxteko
                        • Dec 2018
                        • 5
                        • spain
                        #31
                        i can,t found any replacement for the mainboard. there is any other model that i could use, somebody knows something about it??
                        next week i,ll try to reflow but I want to advance in my new or used mainboard investigation
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4539
                          • Italy - Milan
                          #32
                          Download the service manual, there is the complete list of models w/ same ma.bo.
                          • kew1701
                            Philips taw6205 ambilight speaker STM32 mcu dead
                            by kew1701
                            Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
                            04-09-2025, 03:59 AM
                          • Rubenlily
                            Philips 50PUS6503 - dead panel? Picture
                            by Rubenlily
                            Hey,
                            I gave up on my last TV and got a new one to try.
                            Only vertical lines. Sound is OK. Screen is black with a few white lines until I change channel, then these colors gradually starts filling up the screen.
                            Is this fixable in any way or should I just give up on this one too?...
                            08-21-2023, 01:07 PM
                          • double_DD
                            How can I be sure that my EC chip is dead?
                            by double_DD
                            As the title suggests, how can I be sure that my EC chip is really dead?
                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                            03-12-2025, 07:47 AM
                          • alro7779
                            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                            by alro7779
                            Hello, guys!
                            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                            09-14-2025, 12:25 AM
                          • G33RT
                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                            by G33RT
                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                            It does power up when pressing the power button.
                            I already try the power button while plugin the plug with no result.
                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                            Could this be an PSU or eMMC issue ?
                            07-19-2025, 03:43 AM
