whole new repair / learning world... plasma! Yikes!
  • budwich
    • Jul 2015
    • 3097
    Re: whole new repair / learning world... plasma! Yikes!
    RJP63G4 reads ok with the diode test. The small transistor array (q531) checks / compares to others with no shorts other then the "normal connection" between pin 5 and 3.
    Small question: with the sc board disconnected from the su/sd boards and a "test short" on sc50 and with sc20 connected, powering up still gives a 6 code flash so is this still an indication of further problems within the SC... or does the "test short" on the SC50 potentially cause this to happen?
    • budwich
      • Jul 2015
      • 3097
      I "meter checked" all the buffer ICs (BD8693FVM-HVTR) on the SC board. I didn't find any shorts... probably doesn't mean much as the "in" and "out" could be open or at issue when powered.
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        #143
        With all cables connected and SC50 shorted you will get a steady green light when you turn the tv on. ( no blinks ).
        6 blinks means a problem in the sustain area which is almost certain the IC501 and transistor next to it. Just buy a SS board and get all parts you need from that board. Saves time and you got original parts.
        Take the 30F131 and RJ30H2A from the ss board together with the small ic and transistor. So you know you got original parts
        At the moment you are just gambling and guessing which part fails.....
        • budwich
          • Jul 2015
          • 3097
          thanks.... the strategy may work... assuming that I can recover the parts "well" from the board (you saw the picture of my current board... :-) ) and assuming that the board I find doesn't have issues especially with the 30f131's.
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            #145
            The SS board usually does not fail unless the SC board gets damaged and shorts out the RN part on the SS board.
            They are cheap also!
            • foxyUK
              • 35
              • United Kingdom
              #146
              Do you have this guide, which describes many of the tests on these SC boards?
              In theory it shouldn't be copied or distributed, but I figure Panasonic are probably no longer interested?
              https://1drv.ms/b/s!AhyAtuUSxECNmmK-bZWYoxYi-hVu
              Now, can someone help me with my poor picture after an SC repair (see post!)
              • budwich
                • Jul 2015
                • 3097
                thanks... I will take a look at the guide.
                On your problem, I suggested in another post that you look at reseating the sc to su/sd connectors / cables.
                did you disconnect the su/sd boards from the panel during your work... then it is possible you have issues with those connections.
                Further: at first glance to my unexperienced eye, the guide looks pretty good... people might want to grab it if they don't already have something like this.... before some "thing" happens to it.
                • budwich
                  • Jul 2015
                  • 3097
                  After going thru the checks as outlined in the great guide that was "linked" by foxyUK, and focusing on IC501 as suggested by Moreno88, IC501 failed (shorted) the pin 3-7 check in diode mode. i haven't removed it yet. Just posting my "baby step progress".
                  All the checks in the first two "blocks" seem to be OK. But I see from the check list that I still need to recheck q606.
                  • budwich
                    • Jul 2015
                    • 3097
                    I think / I hope I replaced the ic501 successfully (soldering isn't my forte). Moving on to block 3 checks, there seems to be an issue with ic724 which is a 5v regulator at the "top" of the board. The test from pins 1-3 shows a "capacitance" type reading while the diode check is in the 2+v as opposed to .65v.
                    • budwich
                      • Jul 2015
                      • 3097
                      I don't see any 30f131's on the ss board for this model of set. Am I seeing wrong?
                      • budwich
                        • Jul 2015
                        • 3097
                        I was re-reading the panasonic guide (page 95) which deals with testing of components in block3... more specifically ic724 and ic795. I don't see how the test for these two different components can be the same. IC724 (5v regulator) has been Vin / pin1 and Vout / pin3 while IC795 (regulator?) has Vin / pin3 and Vout / pin1. Basically, the opposite of each other. Yet the "test result" uses the same + to - minus diode test setup on pins 1 to 3. My problem is ic724 appears to be wrong as the diode test is high in the stated direction but correct if you reverse the + -.
                        Can anyone confirm the diode test for a good IC724 (5v regulator BA178M05FP-E2)? thanks for any direction on this.
                        • foxyUK
                          • 35
                          • United Kingdom
                          #152
                          Yes, the guide is wrong. For IC724 pin 1 should be negative for the voltage shown. Reads about 1.5v for pin 1 +. Also, the centre pin 2 is not connected to the heatsink (the actual pin 2).
                          [and yes, there should be 3x 30F131 and 3x RJP30H2A on the SS board]
                          • budwich
                            • Jul 2015
                            • 3097
                            Thanks...... i think that means my ic724 is good.... readings of .59 which is in line with the "target" of .65v +/- .2. wish I was a bit slower taking it off the board... but I wanted to make sure it wasn't an issue with the "in-board" test.
                              May be worth reading my thread here
                              https://www.badcaps.net/forum/showthread.php?t=63035
                              • budwich
                                • Jul 2015
                                • 3097
                                thanks... nice scope. As you say, my old 20 mhz "one legged" (probe) scope might be hard pressed to help. what frequency are involved / "chopped" with the voltage stuff. Can it be triggered with the"line" or do I need some isolation transformer?
                                Further: I see that you used the "modify the cord" method for "isolation".... :-) I might have to try that although we are only dealing with 120v systems here so a "3/2" plugs are in the "tool box". Of course, not sure yet whether I want to go there yet.
                                Still further, I noticed your comment in the reference thread about the "30 series"... perhaps that's a bad omen for me.
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  so, I ran some "pre_checks" on voltages with the SC board isolated from the sd/su boards along with sc50 test short applied. When power up, I still end up with a blink 6 code... :-(
                                  Checking the voltages as suggested in the block3 all look correct / appropriate.
                                  Vsus 214vdc
                                  P15v 15.7
                                  Vad 199
                                  Vscn 147
                                  16v_f 18
                                  15v_f 14.7
                                  5v_f 4.9
                                  I then tried to measure the MID voltage, I couldn't get a steady reading and saw a reading of 201 during initial "auto range" along with others in the 120-140 range.... so it looks like the range of the MID (measured at the capacitors) is outside the range of things. :-(
                                    The sustain waveforms could be conceivably monitored with a 20MHz scope with some loss of detail (but not much), but the issue is more that a digital scope lets you pause the waveform and look closely and shut down sequences etc. You cannot do this with an analog scope.
                                    Yes it's a bit naughty. I can say I would only ever do it with a plastic cased DSO, a full metal case with earthing represents a serious electric shock hazard as it will be floating hundreds of volts above earth. On a DSO you still have to look out for the BNC jacks etc which are also grounded and so could shock you, and make sure you don't plug anything else grounded into it, e.g. USB port to PC, as that will obviously disable your ground hack.
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      I was looking at getting one of those "far east" digital "modules" that are "standalone". Cheap ones can be had but most are only single channel and 10M. As a DIY hobby guy who does really get "dirty" much, it is hard to justify putting more in as the hobby is "sunsetting". Basically, the opportunities are only when I come across something different / interesting that cost nothing but time to look at and maybe save from the landfill.
                                      I will likely look for a used card to see if I can get this set up or at least see what the difference is between it and a "tested card" (ie. so the listing says). :-)
                                      • foxyUK
                                        • 35
                                        • United Kingdom
                                        #159
                                        Vsus 214vdc
                                        P15v 15.7
                                        Vad 199
                                        Vscn 147
                                        16v_f 18
                                        15v_f 14.7
                                        5v_f 4.9
                                        6 Blinks is indeed consistent with the energy recovery mid voltage being out of limits. It should be very steady, only fluctuating by a few volts. Typical level is around 115v.
                                        So... you need to check again IC502, IC522, Q531, Q551, Q451&2, D461&2, Q581, Q441&2, D481&2. (those little Ic's and driver transistor pairs being the favourites for incidental damage after an explosive event).
                                        If you have changed any of them, check for pins that haven't actually been soldered to the board pads...quite hard to see. Associated resistors are also possible victims.
                                        Good luck.
                                        • budwich
                                          • Jul 2015
                                          • 3097
                                          thanks... its probably more likely that my soldering is "less than good" but I have checked the components listed in the three "blocks" in the TS guide that you posted. I usually check components by going from the pin to somewhere on the board for continuity in hopes that soldering has been successful. I potentially need to do a better job on cleaning off flux as it is all over the place and makes finding a "contact point" harder and possibly resulting in "false checks" as then one is pressing / scratching to make a contact which might not be there when the probe is removed which doesn't help. I will check the suggested list again... thanks.
                                          • Firentiosi
                                            1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                                            by Firentiosi
                                            Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                                            The issues are as follows: the...
                                            11-27-2024, 12:33 AM
                                          • ArMaaN376
                                            Samsung PS51E550 Plasma TV
                                            by ArMaaN376
                                            I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                            Opened TV cover & observed foll
                                            a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                            b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                            c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                            How to confirm Y -Buffer board...
                                            06-19-2024, 04:05 AM
                                          • jm1234
                                            Panasonic plasma TX-P42ST50 - 6 blinks
                                            by jm1234
                                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                            I checked that board for any obvious faults...
                                            05-22-2024, 06:59 AM
                                          • KYBOSH
                                            Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                            by KYBOSH
                                            Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                            No picture but you hear the TV static (white noise) playing loud and clear.
                                            The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                            But it seems they didn't get too far and just left it.
                                            When I first took a look I was amazed at how pristine the inside looked.
                                            Its as if the TV had been in a time capsule.
                                            Caps looked like they were just pulled off the self.
                                            Copper coils had no sign of corrosion on...
                                            02-01-2023, 11:10 PM
                                          • alltvrepairs
                                            Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                            by alltvrepairs
                                            I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                            I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                            Any one met this problem in the past?...
                                            10-08-2025, 07:34 AM
