Panasonic TC-P42ST50B - 7 blinks after some time
    Hi all
    My beloved Panasonic TC-P42ST50B that I've had for just over a year now has started giving me a 7 blink code after around five minutes of operation. The picture is absolutely perfect before the TV dies.
    I'll take some pictures tomorrow when I have the back off, but wondering if anyone has heard of this before.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P42ST50B - 7 blinks after some time
    negative. Though the first step I guess you could monitor the voltages the SOS7 cct guards when it trips?
      I'll try monitoring SOS7 and sustain waveforms on the scope, if there's a time delay between one and the other it might clue me into what's going bad where. I'm thinking main board right now - probably BGA solder - ugh. But maybe I can borrow the reflow oven at work.
      • tw2005
        • Oct 2011
        • 6458
        built yourself a Tesla yet?
          Soon, that or just buy one. Model 3 looks nice and I might even be able to afford it.
            Pictures inside. Very nice design.
            Removed and inspected all sustain board screws, no sign of arcing. Power supply Vsus is nice 215V and steady before power is cut by A board.
            Tested TP_SOS6 and TP_SOS7 and both are at 5V during fault, not sure what voltage level indicates a fault so may have to do a little digging.
              tw2005, curious if you have a schematic for the SN board of this model?
              • tw2005
                • Oct 2011
                • 6458
                So before fault it's 0V? I'm pretty sure a high is shutdown. 5v is a high.
                probably going to have fun tracking down a usable schematic
                  Before fault it's 5V. Always 5V, then SOS7. I've got this: which tells me the 5V indicates a fault (slide 6).
                  Haven't yet got it to power up again, suspect it'll go high then SOS7 with trip out. Nothing obviously shorted on the board, and I know it generates sustain pulses which produces a good picture. Can't be sure if something like Vad is going askew and causing mild picture distortion before it goes bad, but it looks absolutely perfect before it dies (excellent PQ as expected from a Panasonic PDP!)
                  If it's similar to the '30 series, which I diagnosed (bedroom TV is a TC-P42U30B which had the shorted transistors with locked green LED) then it's a simple voltage comparator so it's looking at various rails to see if there's a fault.
                  But I've tested Vad, Vscn, Vfg5V and they are all good. Thinking it could be a faulty comparator or voltage reference, or something obscure. SN boards are scarce, so would like to fix it.
                    Odd. SOS6 and SOS7 both go high after the sus cuts out...but... I was only able to get to this point by freeze-spraying the lower half of the SN board. So the SOS6/SOS7 may have nothing to do with the fault. They may be going high after some other fault latches out on the SN board.
                    Scope screenshots showing that SOS6 (1st pic) and SOS7 (2nd) are low before the sustain dies. And the sustain always cuts off on a frame boundary - just after last subfield of given frame. Really frickin weird if this is an A board issue. Maybe the A board samples an error signal (undocumented one, not SOS6 or 7) on each frame, instead of continuously.
                    • tw2005
                      • Oct 2011
                      • 6458
                      This will have to do with the same SN
                      • tw2005
                        • Oct 2011
                        • 6458
                        On sale , cheap enough not to break the bank even as a spare if it's not this board.
                        Ends 5.55 pm Lancashire time
                        http://www.ebay.co.uk/itm/YSUS-FOR-P...YAAOSww3tY39qQ
                          Wrong board - my set uses the 1080p board and that's a 720p one
                            Though found this board for about £16
                            http://www.ebay.co.uk/itm/TXNSN11WFD...kAAOSwuLZY5RUE
                            Should work in my set, so I might get it. Fairly sure it's the SN board at fault here. Kind of want to diagnose it. Running thought is something wrong with VFG5V or 15V as that area seems most affected by heat and freezer spray.
                            • tw2005
                              • Oct 2011
                              • 6458
                              Right, that's a dagger in my heart, usually pretty good at getting it right.
                              So that makes the manual useless then. I saw XT50, normally 3D version should have had a closer look instead of rushing.
                              So the board is TNPA5523
                              Back to the drawing board then, glad you spotted it.
                              • tw2005
                                • Oct 2011
                                • 6458
                                Next time I'll search TX-P42ST50B then, for the manual , LOL
                                  No worries, your help is appreciated! I bought the board, but I'm going to look at this one closely to see if I can figure out what went wrong. Then maybe I'll have a spare.
                                  It does seem like the ST50 is much more reliable than the previous 30 series which was plagued by SN/SC board failures. Still on the lookout for a cheap 55-60" Panny PDP for the living room - of similar series to what I've got.
                                  Thanks for the manual.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    I picked a 65" V10 $20, My god only just fitted in the back of my wagon. Made good money on it but a part of me feels I should have kept it. Rare opportunity.
                                    At least the 30 series is generally easy repair but the parts are obsolete
                                      OK, MAIN_STOP0 is the SOS7 signal and it's generated by IC725 (16725 on schematic S-30), heating this causes the board to stop working but during fault I can't see anything wrong-it seems to behave like a normal 5V regulator. The chip seems semi custom as it's a voltage regulator (15V to 5V) but also generates fault signals and has several unknown inputs going into it.
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        What marking is on it? If it fails with heat, could be it, does show it has a thermal pad so it must get warm in use. So if it's feeze sprayed, does it last longer?
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • CrewmanRedShirt
                                          Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                                          by CrewmanRedShirt
                                          Hello all,
                                          As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                                          07-13-2024, 11:02 AM
                                        • nobbnobb1
                                          Panasonic TC-P50U50 Powers Off - 8 blinks
                                          by nobbnobb1
                                          I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
                                          2x DG302 (Q16051)
                                          2x RF2001 (D16041)
                                          2x 5.6 ohm SMD resistor
                                          1x BD8694 IC
                                          I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
                                          03-21-2023, 08:33 PM
