Panasonic plasma TX-P42ST50 - 6 blinks
This topic has been answered.
  • jm1234
    • Jan 2024
    • 76
    • Slovakia
    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
    I checked that board for any obvious faults like mosfets, diods etc. All the electrolythic caps seems to be 90% of their original capacitance, while ESR looked fine (<1ohm) I think.
    Any suggestions?
  • Answer selected by jm1234 at 05-24-2024, 12:40 AM.
    vinceroger69
    • Mar 2012
    • 6714
    • uk
    not sure if this service manual will be close enough https://cdn.badcaps-static.com/pdfs/...9a36ba0e6f.pdf
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      • jm1234
        • Jan 2024
        • 76
        • Slovakia
        I found a disfunctional optocoupler on the SN board, replaced it and the issue is still the same - 6 flashes. :-(
        • dom.true
          IC2960 for A Board - Panasonic TH-P42X10Z Plasma Television
          by dom.true
          Hi Folks,
          I have a Panasonic TH-P42X10Z Plasma Television (2009-era; New Zealand model).
          This set has proven to be extremely reliable throughout its +16-year lifespan. However, late last year, when going to use the TV, I noticed a 9-blink red LED error code on the front of the set after the television failed to turn on. A quick Google search revealed that this indicates a problem with the set’s main A-board.
          After opening up the set and giving the board a thorough test with my digital multimeter, I found that one of the integrated circuits on the board...
          01-17-2026, 05:01 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • stecos
          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
          by stecos
          Hi everyone!
          I happened several times, in the search for help from the web, to consult this very interesting forum.
          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
          Having said that I come to the gist of my post on the forum as the title suggests.
          For my passion for technology I'm now collecting several...
          11-28-2022, 11:39 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • Biruslapio
          Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
          by Biruslapio
          Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
          It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
          It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
          02-16-2021, 09:44 PM
