whole new repair / learning world... plasma! Yikes!
  • freakaftr8
    • Oct 2012
    • 3743
    Re: whole new repair / learning world... plasma! Yikes!
    your looking at the Brown and white connector. Sorry. Probe one lead of your voltmeter to white and the other to brown. You should get about 200 Dcv or so.
    • freakaftr8
      • Oct 2012
      • 3743
      I guarantee you that SC board is littered with shorted mosfets. When you get to scoping this board you will want to use black lead to the soldered big leg and red lead to each end of all the mosfets on this board that start with the letter Q.
      • freakaftr8
        • Oct 2012
        • 3743
        Originally posted by budwich
        OK... I think I understand, you are checking the power supply line side of the disconnected cable... hoping that the power supply will at least provide some powering there before any shut down. Right?
        That is correct. However I pretty sure that your power supplies fine. These things are very Hardy
        This task will also tell is your SS board is good
        • freakaftr8
          • Oct 2012
          • 3743
          Good God look it that SC board. There's Nothing worse than having all active components soldered directly to the PCB
          • budwich
            • Jul 2015
            • 3097
            wow 200v dc could be deadly... be steady my hand... :-)
            Question: will the voltage remain there for a period (til power off) or will the system try shut down immediately based on not seeing some connection somewhere (ie. sc disconnected)?
            • budwich
              • Jul 2015
              • 3097
              me too, since I might have to try to removed them with a heat gun as posted that was linked here a bit back... :-(
              nice heat sinking... :-)
              • budwich
                • Jul 2015
                • 3097
                OK thanks... I was doing it wrong. I did check the resistors mentioned in the kit and they seem ok.
                • tvtimmy
                  • Mar 2015
                  • 1160
                  • usa
                  #28
                  Check these IBGTs for shorts: Q401,Q403, Q422, Q423,Q660,Q661,and Q600.
                  Watch this video. Tnpa5335 repair kit on youtube.
                  I use a 45 watt solder station and I dont have any problems. You have to check your parts that you buy to make sure they are not fakes from china.
                  • budwich
                    • Jul 2015
                    • 3097
                    can someone explain how to do this check as mentioned in the first thread link that I posted...
                    "you try in continuity / diodetest on the buffers and run the probe slowly along the contacts at the panel ribbon connectors with respect to Vf gnd which is the plates that the bolts go in on the SD/SU. I would go slow if it's a cheap meter as response will be slow and watch for short cct. ".
                    • tvtimmy
                      • Mar 2015
                      • 1160
                      • usa
                      #30
                      Brown and white. There is a video you should watch on youtube: TNPA5335 repair kit.
                      Check your new parts before installing because there are sooooooooooo many fakes from China on the market.
                      • budwich
                        • Jul 2015
                        • 3097
                        OK... I did a "diode check" on the suspected semis (Q402,403,422,423 and D401,402).
                        All are shorted. Check all other "equivalent" components on the board... all checked good.
                        So the question now is, what caused them to go out... subtending board is bad or the panel is bad? I checked the mounting screws, they were tight.
                        I kind of remember there are some "dependencies" where by if you fix one board but the subtending one is bad, it will take the fixed board out again. What further checks do I need to do
                        OK... I found further testing in the pdf.
                        • martino
                          Not so "senior"
                          • Aug 2013
                          • 997
                          • canada
                          #32
                          Check the board where the screws sit,you will see a darkened area on the tin,either front side or backside where it has been arcing.
                          They really are not too bad to repair,less scary as it seems. Any of our members close to you that can perhaps help? I'm willing to do it for cost,but I'm in Alberta
                          Proud owner of dozens of broken TV's and many,many,many boards.
                          Our website and passion:http://hollenhundshepherds.com/
                          • budwich
                            • Jul 2015
                            • 3097
                            thanks.... i am probably just over thinking / cautious.... nothing to lose since it will just go back in the dumpster if i am unsuccessful where it was anyway ... :-)
                            it appears it will be less than $50 to get to a point one way or the other.... the budget should work.
                            • Wellington1
                              • Sep 2017
                              • 43
                              Not to interfere with this thread but as I saw a 50" Panasonic plasma locally for 30 obo ( TC P50VT25 - June 2010 ) that has mostly thin black vertical lines across the screen, described by the Seller, no images of it and I have yet to look personally but my understanding is that the panel is most likely no good?
                              It does function so all the boards are good - worth it for parts ( doubt I could use any them for my late 2012 U50 ) perhaps?
                              • budwich
                                • Jul 2015
                                • 3097
                                no problem.... if you look at the thread that i posted as my ref start, the guy had lines after his work.... reseating some cables cleared them up....:-) you might get lucky.
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  following the resistance test in the troubleshooting pdf, looking at the TPSC1 (R515) and VF-5V (pin 3 of IC724), both show good. I take this that perhaps only the SC board has issues as already identified... assuming that the panel itself is good (no visible signs of physical damage).
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    I've found in my experience that when a Panasonic SC board eats it's lunch, very rarely do I see failed SU or SD. I mean it can happen, but in your case sounds like you found them ok.
                                    For removal of FETs soldered to the board, I use a soldering iron and lift both small legs. Then I break out the Weller soldering gun and tin the big tab, heat the hell out of it and use tweezers to pull up after I notice the solder underneath bubbling.
                                    Once removed I use the Weller and run it over the pad to reflow the solder flat. Installation is usually the same but use flux and a little solder between the gun and top of tab. Use the soldering iron to solder down the 2 tabs.
                                    It takes a minute cause of heat dissipation but they will come off. It's kinda like the dentistry of electronics repair..
                                    Others may have a different view of how to do thjs, but it's never failed me yet out of the 200 or so FETs I've replaced..
                                    • martino
                                      Not so "senior"
                                      • Aug 2013
                                      • 997
                                      • canada
                                      #38
                                      It's such a common fault on that model that I don't even test buffer boards for it,leaving them on the ribbons as to not having to readjust them (can be a real pain on panny's).
                                      I do replace all the parts in the kit as to be sure your work is covered,reality will show after removal that not all parts are blown as per kit. The surviving parts did get a good stress before failure so could be weak.
                                      All points where screws meet the board should be reflown with fresh solder (both sides of board) to ensure the new screws make good contact to prevent a repeat of this fault.
                                      They are nice tv's with a very decent picture,well worth the repair cost and adventure.
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        Indeed. You should see the SC board for a TC-50UT50 I just repaired for someone locally. Damn floating grounds! All the screw locations were blown and had to create new pads.
                                        A word of advice do not remove buffer boards you can slide the SC board out from underneath the buffer boards just remove the screws.
                                        Also why are in their tighten down the screws on the SS, SU and SD boards. They're gonna be loose. Preventative maintenance...
                                        • budwich
                                          • Jul 2015
                                          • 3097
                                          thanks.... I am going to see if I can get the components locally as I only have a small window because of other things going on at home. Otherwise it will have to wait for a while.
                                          PS. Freakaftr8, glad you got your oled working.... :-) that was a good trip!
                                          • Firentiosi
                                            1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                                            by Firentiosi
                                            Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                                            The issues are as follows: the...
                                            11-27-2024, 12:33 AM
                                          • ArMaaN376
                                            Samsung PS51E550 Plasma TV
                                            by ArMaaN376
                                            I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                            Opened TV cover & observed foll
                                            a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                            b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                            c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                            How to confirm Y -Buffer board...
                                            06-19-2024, 04:05 AM
                                          • jm1234
                                            Panasonic plasma TX-P42ST50 - 6 blinks
                                            by jm1234
                                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                            I checked that board for any obvious faults...
                                            05-22-2024, 06:59 AM
                                          • KYBOSH
                                            Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                                            by KYBOSH
                                            Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                                            No picture but you hear the TV static (white noise) playing loud and clear.
                                            The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                                            But it seems they didn't get too far and just left it.
                                            When I first took a look I was amazed at how pristine the inside looked.
                                            Its as if the TV had been in a time capsule.
                                            Caps looked like they were just pulled off the self.
                                            Copper coils had no sign of corrosion on...
                                            02-01-2023, 11:10 PM
                                          • alltvrepairs
                                            Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                            by alltvrepairs
                                            I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                            I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                            Any one met this problem in the past?...
                                            10-08-2025, 07:34 AM
