1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
  • Firentiosi
    Hobbyist
    • May 2021
    • 5
    Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
    The issues are as follows: the left-hand 1/3rd of the screen is black, no image and occasionally has vertical multicoloured lines. The backlight is functioning on the TV and shining a flashlight doesn't show any image.
    The circuitry has a power supply unit and a TCON board (CHOT CV580U1)
    Voltages measured are as follows:
    12Vin - 12.49V
    VBo 0.03V
    VSS1 7V
    RVAA 15V
    LVAA 15V
    VGHF 7.7V
    VGL -8.8V
    There are also 1.2V, 3.3V, 12V and 15V DC power rails present.
    The TCON board connects to a LEFT and a RIGHT sub-panels. Each sub panel has multiple connections (chip-on-film, I believe) to the panel/LED circuitry. If a third of the screen is not working, then perhaps it is something to do with a short or open circuit 'upstream' of the three COF strips that feed the leftmost third of the board?
    I have attempted to unseat and reseat the mainboard -> TCON board ribbon strip and TCON--> sub-panel ribbon strips.
    1. How can one tell if it is the LED strips themselves vs another component? I see that these strips are usually arranged horizontally, but my issue is a vertical one. Perhaps I am naively thinking that it is not the actual LEDs?
    Any further information or troubleshooting greatly appreciated.
  • Firentiosi
    Hobbyist
    • May 2021
    • 5
    Ah, found it. Crack in the LCD right where I'd expect it. Thanks anyway guys.
    • KYBOSH
      • Oct 2011
      • 581
      • Unknown
      For me... vertical lines means "dont bother"
      Usually a tab bond issue and not really a crack in the screen.
      But you can learn from this TV set.
      Its a junker but you can have a look around to get a feel of what's what.
      So next time you have a set you are trying to save you'll have a better understanding of things.
      Good luck
      • Firentiosi
        Hobbyist
        • May 2021
        • 5
        Thank you! Yes, I'd learned as much as I could from this set. Just the basics, but was still informative.
        • Stanley1843
          Screen Display Vertical Multicolor Lines
          by Stanley1843
          Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
          06-29-2024, 11:54 AM
        • gpo23
          Sony KDL-40V3000 - Vertical lines
          by gpo23
          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
          With the new t-con the color are good but there are vertical lines on all the screen :
          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
          Is there a way to fix the vertical lines on the new t-con ?
          Thank you for your help
          gpo23...
          10-04-2023, 09:11 AM
        • viking509
          vizio e65 e3 LED tv color vertical lines center tv only
          by viking509
          I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
          03-21-2023, 12:48 AM
        • rfxcasey
          Vertical Lines on Half of LCD Display
          by rfxcasey
          I have an Siemens HMI with vertical lines on half of the screen. These lines aren't scrambled garbage but rather very regular in pattern and color. I have replaced the LCD with a new one and still the problem persists. I'm wondering if this isn't indicative of a bad video process chip or video memory? Any help would be appreciated. The cable appears to be OK but one pin on the header is unpopulated, though there isn't any loose wire to suggest one broke off or popped out of the connector. In the picture below where the connector is busted out of the side, I did that with my small screw driver...
          05-16-2024, 06:52 AM
        • noisykid
          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
          by noisykid
          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
          12-30-2024, 07:15 PM
