Vizio E470i-A0 LED Strips
Disclaimer: Don't trust a thing I say-I am frequently wrong!!!
I have tons of spare parts, some used, some N.O.S. ham transistors and caps. Message me if you need any parts.
Some of the things I've fixed:
60" Vizio-bad LED's. iBook G4: Resoldered VCC Plug. Geo Tracker ECU: Swollen / Leaking capacitors. Windows Laptop: Soldered broken LVDS wires. Dryer: Burned contact on temp switch. Oven in R.V.: Bad contacts in relays-Exploded by the looks of them! Samsung Oven: Burned contacts on Relays. MSI Motherboard: BSOD-Swollen capacitors, bad graphics card, Moved SATA Input from SATA 1 to SATA 2 plug -
Re: Vizio E470i-A0 LED Strips
OP, You are missing a few steps.
I'd get the T.V. apart and test that you are actually getting voltage-probably 20-30 volts D.C. on each strip. Divide the voltage your meter says by the number of LEDs on the strip. Yours could be 3, 3.3, or 6 volts.
Then pop off one of the lenses covering the led. warm up the underside of the board with a hair dryer or hot air station first. I set mine at 180F for this.
Then use a caliper to measure the dimensions of the LED. Could be 3528, could be 3030.
Do you know what those numbers mean?
This guy sells them on ebay in 10pcs for $9. he probably also sells them in 20pcs. They look like 3030's, probably 3-3.3 volts:
https://www.ebay.com/itm/10x-LEDs-fo...gAAOSwwzhZWr0XLast edited by NeedsMoreFlux; 11-29-2017, 08:55 PM.Disclaimer: Don't trust a thing I say-I am frequently wrong!!!
60" Vizio-bad LED's. iBook G4: Resoldered VCC Plug. Geo Tracker ECU: Swollen / Leaking capacitors. Windows Laptop: Soldered broken LVDS wires. Dryer: Burned contact on temp switch. Oven in R.V.: Bad contacts in relays-Exploded by the looks of them! Samsung Oven: Burned contacts on Relays. MSI Motherboard: BSOD-Swollen capacitors, bad graphics card, Moved SATA Input from SATA 1 to SATA 2 plugComment
The led is the positive rail, there is a gap in the copper trace under that lense/LED. if you pop off one of the lenses you can see the copper stops just under the legs on either side of the LED.
You can scrape off a tiny bit of solder mask on either side of the LED and test the LED.
The jumper wire is the negative trace.
I really need to make a youtube video and just-copy paste!Disclaimer: Don't trust a thing I say-I am frequently wrong!!!
I have these LEDs on order. https://www.ebay.com/itm/322611404018Last edited by karthur; 11-29-2017, 09:52 PM.Comment
I measured the LEDs and they are 2.8 x 3.5 mm. I guess that means they are the 2835 variety. I checked the voltage earlier and found the Vout1 and Vout2 to be 130 volts. 54 total leds, so that works out to be 2.4 volts/LED. Is that the voltage you are asking about?
You cannot just divide the supply Voltage by the Vf of the LED because the Cathode return of the LED string is not directly connected to GND, it is connected to the PWM Controlled MOSFET and the current sensing resistor to maintain the constant current through the LED string so you will also have the Vdrops on the MOSFET and the current sensing resistor.
The Vf of each LED is affected y the amount of current flowing through the LED, at 50mA the Vf will be 2.7~2.8V but at full 400mA the Vf will be about 3V.
You have two LED string with 27 LED each based on your pictures, so 27 x 3 = 81 V vF +20V on the MOSFET, so the output Voltage with load will be around 100V or so.Last edited by budm; 11-29-2017, 10:05 PM.Never stop learning
Here is what I did to fix the repair. There are 4 places where they cut the board rather than doing the piggy-back method.
I was finally able to see the trace that should go to the "-" side of the LED.... and continues on to the "+" side of the next one on the strip. The large wire on the LH side is connected to that trace.
I put electrical tape under them so they would not short.
KirkComment
I assume no responsibility for any stupid suggestions I might post.Comment
That is what to expected when there is no load, it is the constant current circuit.Never stop learning
Just ordered a set of those from ebay. Also watched a YT video on how to make a tip for my soldering iron to remove the LED.
If I was doing a bunch of these repairs, the hotplate would be the way to go.... but for just this one panel, not really worth the $40.
Hopefully this will work out.
Thanks for all the help. This site is great!!
A few things I learned. The YT video that shows how to make a foot to go on the soldering iron does not work to remove the old LED. I used a heat gun to take off the old ones. I tried to use the heat gun to put the new ones on, but hard to hold the gun and hold down the LED so the air does not blow it off.... and see what I was doing. Ended up using a soldering iron to put them back on. I would hold the soldering iron on the "+" side of the LED and it would solder on both + and - side to the trace.
When I was re-soldering in the new ones, the new LED would just break in half. I wasn't pushing on it or anything. I may have been getting it too hot, but as soon as the solder started to flow under it, I would take off the soldering iron.
This is my first time to solder LEDs to a trace, so I did learn a few tricks. Was I doing something wrong to cause them to break?
ThanksComment
With soldering iron probably only one side was molten. You need both sides molten to not stress led. You can turn airflow down to keep from blowing led off or heat strip from bottom.I assume no responsibility for any stupid suggestions I might post.Comment
I use two soldering irons to place LEDs by hand - one on each side. I find it beneficial to preheat the area where I am going to place the LED with a heatgun. I heat the area to around 180 F, the use the irons to finish the placement. I imagine that you overheated the LEDs that you place with only one iron. One side got seriously overheated, thus causing the part to fall apart. The LEDs are just high-temp plastic and are not super tough.Comment
I did get it all back together last night and it now works.There is one bright spot where I think the diffuser lens is not centered on the LED. I am going to fix that today. In all it was a pretty easy fix, just takes a little time, but I am happy with it.
A big THANK YOU to everyone for the help.
I have a Vizio E470i-A0. Classic symptoms no picture but good sound. I did the "flashlight" test and do have a picture playing in there. I pulled off the back and tested the power supply board /LED board voltages. I checked Vout1 and Vout2. Both of these show voltages of around 130VDC. From what I have been reading the LEDs are bad.
What is a good source to purchase these LED strips?
Any tutorials on how to go about replacing them? I have the back off, but that is as far as I went (dont want to damage it futher).
I have read to replace ALL of the strips, but is it ok to find the bad one/ones and just replace them? Why do all of them if they are not bad?
Thanks,
Kirk
I recommend if your not going to do that , that you buy extra leds since youll be likely replacing them a couple at a time over and over. these use the 3v 250ma leds , same as the lg versions (this vizio like many is made by LG's manufacturer) I bought 100 leds for $8 on ebay myself,Last edited by augiedoggy; 12-06-2017, 07:39 AM.Comment
by howardc64Failure Symptom
No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
Where is the short?
Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but... -
by KingfreddieOk.. this is the story:
Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
This is kinda how it looked, just that mine were at the bottom of the screen:
Assuming...7 Photos -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by edugimenoHi There!
I bought a broken 32" TV today. It has sound but no image. I checked with a flashlight and it was missing backlight
Disassembled down to the led strips and found this TV has been serviced before. Not sure if it was fixed, worked again for some time, and broke again, or maybe last repair wasn't successful
Looks like on previous repair, the center LED strip was replaced with a different model, 7 leds in it instead of 8, but when checking LEDS one by one, leds on the center strip were brighter with same test voltage (multimeter in DIODE mode) so maybe the... - Loading...
