Vizio E470 LED current mod.
  • dskall
    • Oct 2016
    • 2905
    • usa
    I have power board # 0500-0614-0270. Upper left is led ic9101. SEM5028 is chip number. I can find no pinout info. I would like to knock down current to led's. Anyone know how to id the pin for current feedback?
  • petehall347
    • Jan 2015
    • 4451
    • United Kingdom
    Re: Vizio E470 LED current mod.
    can it not be done in the service menu ? just a thought ..
      It is 2-channels version of LED driver IC SEM5027 1-CH LED driver, so you just have to increase the resistance of the current sensing resistor connected to the Source pin of the two PWM controlled power MOSFET Q9105, 9205.
      SEM5027 Diagram:
      http://4.bp.blogspot.com/-80jXWtC6Hj...D%2BDRIVER.jpg
      • dskall
        • Oct 2016
        • 2905
        • usa
        So current isn't set at the IREF? There are 2 pairs of 30ohm at R9218/A and R9118/A are the ones you are talking about off Q9105/9205
          Yes, you can use IREF too but I cannot find the pinout for this SEM5028.
          Two 30 Ohms is parallel, 15 Ohms seems kind of high. Did you measure them. If you remove one of them then the current should drop in half.
          I sure like to find the spec sheet of both ICs.
          • dskall
            • Oct 2016
            • 2905
            • usa
            I was surprised there was no datasheet. Removed one 30ohms. Have not tried it yet
            • dskall
              • Oct 2016
              • 2905
              • usa
              Ok update. The correct resistors are R9110 and R9210 which are 1.5ohm 1/2watt which output 420ma at max brightness. Replaced with 2 3.7ohm 1/4 watt in parallel. Which brought max. current to around 320ma. From what I find for led specs. is a max of 350ma. So this should bring current into reliable current ratings for led.
                I would go down just a little more like 300mA or less and you probably will not see the different in brightness.
                The max 350mA is probably at 25c but the temperature inside the panel will be higher than that so I would give it more head room by lower the current more..
                • NeedsMoreFlux
                  • Oct 2017
                  • 121
                  • California
                  scummy scammy manufacturers.
                  It is the higher voltage at start up that is the problem!
                  Disclaimer: Don't trust a thing I say-I am frequently wrong!!!
                  I have tons of spare parts, some used, some N.O.S. ham transistors and caps. Message me if you need any parts.
                  Some of the things I've fixed:
                  60" Vizio-bad LED's. iBook G4: Resoldered VCC Plug. Geo Tracker ECU: Swollen / Leaking capacitors. Windows Laptop: Soldered broken LVDS wires. Dryer: Burned contact on temp switch. Oven in R.V.: Bad contacts in relays-Exploded by the looks of them! Samsung Oven: Burned contacts on Relays. MSI Motherboard: BSOD-Swollen capacitors, bad graphics card, Moved SATA Input from SATA 1 to SATA 2 plug
                    It is the constant current circuit so the maximum current will not be any higher than the set max current which these LED backlights TV are being driven at maximum current with no regard of the heat management or the life span.
                    This is the warning from LG spec. sheet for their own LED's:
                    ※ Operating the LED beyond the listed maximum ratings may affect device reliability and cause
                    These or any other conditions beyond those indicated under recommended operating conditions
                    The exposure to the absolute maximum rated conditions may affect device reliability.
                    But guess how LG drives its LEDs in the LG panel.
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      I think this is a way to do planned obsolescence. To kill them after the warranty.
                      • nomoresonys
                        • 12330
                        • U.S.
                        I think so too, why else would they do it, they must know that too much current is a killer.
                          Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                          by sam_sam_sam
                          I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                          I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                          I tested the battery cells there are installed right now and they are testing good with no issues that I...
                          02-04-2025, 08:08 PM
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                          Diodes AP21X2SG-13 AP21X2MPG-13 Current Limited Power Switch for Laptop Computer Datasheet
                          The AP2182 and AP2192 (AP21X2SG-13 AP21X2MPG-13) are integrated high-side power switches optimized for Universal Serial Bus (USB) and other hot-swap applications. The family of devices complies with USB 2.0 and available with both polarities of Enable input. They offer current and thermal limiting and short circuit protection as well as controlled rise time and under-voltage lockout functionality. A 7ms deglitch capability on the open-drain Flag output prevents false over-current reporting and does not require any external components.
                          All AP21X2SG-13 AP21X2MPG-13 devices are available...
                          10-23-2024, 03:33 AM
                        • DynaxSC
                          Extreme High Current & Low Voltage Short Killer ??
                          by DynaxSC
                          Hi Folks
                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                          After taking off the socket, the shorts dissappear again.
                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                          10-15-2024, 10:13 AM
                          Lenovo ThinkPad E470 Notebook E Specification for Upgrade or Repair
                          This specification for the Lenovo ThinkPad E470 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E470 boardview and E470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                          09-06-2024, 08:20 AM
