Vizio D650I-B2
  • heavymachines
    • Mar 2011
    • 1028
    Re: Vizio D650I-B2
    http://www.shopjimmy.com/vizio-55-75...-ir-sensor.htm it looks like this and lookie here they're sold out of them but all u need to do is replace the 2 smd cap 1 larger the other smaller.
    • heavymachines
      • Mar 2011
      • 1028
      Re: Vizio D650I-B2
      Originally posted by budm
      Good job finding the problem.
      Can we see the pictures of the IR board?
      The IR board runs on 3.3V or 5V?
      and it runs at 3.3 volts replaced c1 and c3 smd cap.
        Re: Vizio D650I-B2
        That is probably why the 1117 you found was hot.
        • heavymachines
          • Mar 2011
          • 1028
          Re: Vizio D650I-B2
          yeah i agree ...
          • nightstah
            • Jul 2011
            Re: Vizio D650I-B2
            Originally posted by heavymachines
            okay figured it out it was the ir board for remote it was loading down main. tv works good now
            Just received this same set, exact same symptoms and solution. STBY voltage was going from .8V to 1.5V. Disconnecting from mainboard and get steady 5V. Once I came across this thread, disconnecting the IR board from the mainboard and got steady 5V and would power on with the power button.
            Now I gotta find the replacement IR board... gonna put this sucker on my kitchen wall, lol
            • CapLeaker
              Leaking Member
              • 8135
              Re: Vizio D650I-B2
              glad to hear that this old thread helped you out!
              • Tidy
                • Feb 2020
                Re: Vizio D650I-B2
                thanks for the info in this thread... My TV had the same shorted cap on the
                ir-led board. replaced cap and it works great. Thanks again for the info...
                • DeatRaton
                  Gio
                  • Oct 2019
                  • 36
                  Re: Vizio D650I-B2
                  Can you explain to me what you have done? I am experiencing exactly the same issue. I replaced the power supply and the main board assuming the same issues brought up. Can you explain your fix so I can try it? Should I replaced the ir board long story short?
                    • 12141
                    • U.S.
                    #29
                    Re: Vizio D650I-B2
                    Maybe unhook the ir board and see if tv works with button board on tv if there is one.
                      • 12141
                      • U.S.
                      #30
                      Re: Vizio D650I-B2
                      Can also test those 2 caps on ir board, check m in ohm mode.
                      • DeatRaton
                        Gio
                        • Oct 2019
                        • 36
                        Re: Vizio D650I-B2
                        Perfect this really helped it was the ir board awesome! Great info thanks guys!
                        • DeatRaton
                          Gio
                          • Oct 2019
                          • 36
                          Re: Vizio D650I-B2
                          No replacement available. Am not familiar with replacing these caps would try by myself but they seem to tiny and I have no experience in this field. Wouldn't even know where to get these parts. Anyone know of a place that could repair this for me or where should I even start?
                            • 12141
                            • U.S.
                            #33
                            Re: Vizio D650I-B2
                            Looks like that will work: https://www.ebay.com/itm/New-VIZIO-E...oAAOSwIexej~DF
                            • tvtimmy
                              • Mar 2015
                              • 1160
                              • usa
                              #34
                              Re: Vizio D650I-B2
                              Anyone know what the value of the 2 caps are ?
                              • DeatRaton
                                Gio
                                • Oct 2019
                                • 36
                                Re: Vizio D650I-B2
                                Man you are awesome!! Thank you so much. I really appreciate all the help. I would eventually really want to learn how to work on my own parts. Is there any videos or training guides I can follow to learn this?
                                  • 12141
                                  • U.S.
                                  #36
                                  Re: Vizio D650I-B2
                                  One there for putting them on: https://www.youtube.com/watch?v=f9fbqks3BS8
                                    • 12141
                                    • U.S.
                                    #37
                                    Re: Vizio D650I-B2
                                    Some de-soldering techniques there, one simple way is to just use two soldering irons, one on each side, there's a bunch more videos there too: https://www.youtube.com/watch?v=HZLQzBOOQbw
                                    • kcream24
                                      • Aug 2020
                                      • usa
                                      #38
                                      Re: Vizio D650I-B2
                                      Phenomenal work! Had the same problem. Thought it was the power supply. Followed your post and fixed!
                                      • bunting78
                                        • Sep 2021
                                        • 3
                                        Re: Vizio D650I-B2
                                        Hey guys new here, seeing if anyone is still on this thread willing to try to help. I have this same TV with the same problem up until the low fluctuating standby voltage. The TV just quit turning on and has no standby light. I am getting a good 5v standby, 12v and 24v in there corresponding pins on the power board. unplugged the IR board just to see, no change. Ive just run out of resources, trying to figure out what voltages I should be seeing in certain spots on the main board that would hint at an issue.
                                        • jason123
                                          Vizio P65-E1 No Activities - Voltages oK
                                          by jason123
                                          Hello guys,
                                          I'm thinking it's bad main board, but I'd love any thoughts or things to try - the board is a couple hundred $$$ and I'd like to be sure before replacing.
                                          So I got this TV dead - no standby LED or screen activity or backlight.
                                          Voltages to main board are on (not sure what the level should be, but here is the connector's (PS CN9102) voltages:
                                          PS_ON: 4.91V
                                          +VA = 18.79 V
                                          +VM = 18.82 V
                                          I spot check voltages on the LED Controller board, and all the large upper inductors have about 9.4V on one or the other side....
                                          10-21-2023, 03:14 PM
                                        • Capacitorial
                                          Powersupply has all the voltages - Monitor still no power
                                          by Capacitorial
                                          Hello guys,
                                          I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                          The weird thing is, that the Power LED is powered over the TCON board.
                                          On The TCON...
                                          12-28-2024, 02:12 PM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • howardc64
                                          Vizio SmartCast TV software bug that looks like hardware
                                          by howardc64
                                          Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                          It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                          11-16-2024, 05:17 PM
