Vizio P65-E1 No Activities - Voltages oK
  • jason123
    • Oct 2015
    • 1138
    Hello guys,
    I'm thinking it's bad main board, but I'd love any thoughts or things to try - the board is a couple hundred $$$ and I'd like to be sure before replacing.
    So I got this TV dead - no standby LED or screen activity or backlight.
    Voltages to main board are on (not sure what the level should be, but here is the connector's (PS CN9102) voltages:
    PS_ON: 4.91V
    +VA = 18.79 V
    +VM = 18.82 V
    I spot check voltages on the LED Controller board, and all the large upper inductors have about 9.4V on one or the other side.
    On the main board, I see a whole bunch of rails, 1.1V, 1.2V, 1.5V, 3.3 V, 5V,...
    The main board gets warm (not hot)
    Disconnecting ribbons from TCON to MAIN have no impact.
    Usually when I see many eBay postings for repairs with 3 month warranty, I think of BGA reflow.. wonder if this is the case?
    Anything you'd try at this point? Any experience with common failures on this model?
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    Re: Vizio P65-E1 No Activities - Voltages oK
    What is the voltages to the Tcon? You get 12v at fuse? 18v to main board sounds about right. I personally have had this same issue with different Vizio. My experience has no voltage going to tcon. I'd do some more testing before sending out. My fix was reflow the chip also, well I just took a hot air gun to it and very lightly pressed it with some tweezers. Give us the tcon readings when get a chance.
    https://www.badcaps.net/forum/showth...&highlight=P65
    This will probably help
    • jason123
      • Oct 2015
      • 1138
      You're correct, Tcon is not getting any power. Which of the 2 BGAs did you reflow? I have access to a pro BGA rework station. I can get that done tomorrow. Thanks
      • EazyBone
        • Jun 2023
        • 1362
        • United states
        I did both of them. I saw a video of some dude, I think Nick's tvs, said it's usually the "left one" and then said he just does them both to be professional. So if you have access to that machine lol I'd do them both. But, maybe someone with more experience has an answer.
        • jason123
          • Oct 2015
          • 1138
          Extra 6 minutes to do both... i will go with that. Thank you!
          • EazyBone
            • Jun 2023
            • 1362
            • United states
            Yup bring us the results.
            • jason123
              • Oct 2015
              • 1138
              TV is up and running again. Fresh thermal paste, full clean.
              Hope this is helpful to someone - Thank you
              • EazyBone
                • Jun 2023
                • 1362
                • United states
                Figured it was that. Good deal thx for update
                • mrtek
                  Vizio M65-C1
                  by mrtek
                  Hi.
                  picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                  When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                  This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                  07-14-2025, 07:28 PM
                • cheeky2
                  by cheeky2
                  05-25-2024, 03:27 AM
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • lfhlaw
                  Vizio E65-E3
                  by lfhlaw
                  I have this nice 65" Vizio E65-E3.
                  I can see the images using a flashlight, but I checked the LED lights and they are all functional.
                  I checked voltages on the main board.
                  The LED volts are at 0 with power on and when I power the TV on, no voltage passes through those at all. No jump in voltage.
                  Pins 11-15 have the correct voltages.
                  pins 2-5 do not show any voltages when powering up the TV at all.
                  None of the Capacitors are blown.
                  All the other voltages are correct. Via Testing I would assume the LED Driver/ power board is bad....
                  09-21-2025, 02:53 PM
