Constant fuse blowing
  • Techboxcomputer
    • Aug 2016
    • 61
    Hi All
    Hi I have a Samsung UN40HU6950 TV that blew it's fuse on the power board. The board is a SE9B505102. I bought a matched ceramic fuse for it, reinstalled the board and it immediately blew the new one. I am at a loss of what to do next
    Thanks in advance = )
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Constant fuse blowing
    The fuse is blowing for a reason, usually shorted a shorted component(s) on the power supply.
    You will need a multimeter to help find the faulty part(s) and to help us good photos of the board. I think it's a BN44-00752A ?
    • Techboxcomputer
      • Aug 2016
      • 61
      I have a multimeter and I am not totally unfamiliar with it's use. The board is exactly the one you have mentioned. Tell me what you want photos off and I will post them
        Good clear high res straight shot of the whole top and bottom side of this power supply board.
        • Techboxcomputer
          • Aug 2016
          • 61
          OK - here they are. Let me know if you need anything better.
          • CapLeaker
            Leaking Member
            • 7976
            check out the bridge rectifier BD8015 to see if it is shorted and the PFC fets next to it.
            • steves7839
              • Nov 2014
              • 200
              One way to detect a shorted board is to measure resistance on the "load" or protected side of the fuse to circuit ground. Usually it will read just a few ohms if a downstream short exists.
              To isolate whether the short is located on the power board or another board, disconnect cables from the power board and remeasure.
              • Techboxcomputer
                • Aug 2016
                • 61
                OK, lets address this one a a time, here are what my readings on my bridge rectifier is.
                With positive lead on leg one ( + ) and negative on leg 2 - .502
                With positive lead on leg one ( + ) and negative on leg 3 - .502
                With positive lead on leg one ( + ) and negative on leg 2 - tests through
                As far as the PFc's go, I am assuming you are telling me DP803 & DP804 These I am unsure how to test I now have noticed a slight discoloration around DP801c on the back of the board This sits between QP802cs & QP801cs and they read differently
                  Check the resistance between the two legs of the main filter cap, and also between the two outer legs of the bridge rectifier.
                  • Techboxcomputer
                    • Aug 2016
                    • 61
                    The 2 outer legs ring continuity on BD801s
                    If you are referring to the 2 500v68uf capacitors as the main filter cap(s) they both ring continuity also
                    The mosfet I am suspicious of is posted below. I may be wayyyy off as I am new to this but it looks like there was a heat issue with the middle one.
                      We need the reading in Ohms, continuity test does not mean much when looking for resistance value, continuity is telling you that you have connection between the two points, the resistance will tell me if it is normal or not.
                      Make sure to report if the reading is in Ohm, K Ohm, or M Ohm.
                      Yes, those are the two power MOSFET's for the PFC circuit and one PFC diode on that heatsink.
                      • Techboxcomputer
                        • Aug 2016
                        • 61
                        Ok, as I said, I am still learning, so be patient please
                        Here is what I went by
                        " Connect the 'Source' of the MosFet to the meter's negative (-) lead.
                        1) Hold the MosFet by the case or the tab but don't touch the metal parts of the test probes with any of the other MosFet's terminals until needed.
                        2) First, touch the meter positive lead onto the MosFet's 'Gate'.
                        3) Now move the positive probe to the 'Drain'. You should get a 'low' reading. The MosFet's internal capacitance on the gate has now been charged up by the meter and the device is 'turned-on'.
                        4) With the meter positive still connected to the drain, touch a finger between source and gate (and drain if you like, it does not matter at this stage). The gate will be discharged through your finger and the meter reading should go high, indicating a non-conductive device."
                        Now that you read that (if that is correct) here are my results testing the 3 mosfets I pictured. On the backside of the board I put my negative on the left and my positive on the right. My meter is set in "diode mode" Here is where I am confused. When set on that on my expensive multimeter it just beeped continuity, when I pulled out my cheap radio shack multimeter I got a reading. If I am on the right path, please continue to point me towards what to test. If not redirect me please
                        Mosfet 1 - 0.0
                        Mosfet 2 - 0.0
                        Mosfet 3 -.356
                        *note - pulled out my more expensive meter again, and it beeped on the first two as before, but on the third mosfet it measured 1.16 odd that the other meter measured .356?
                        Thank you
                          No power applied to the board, then just put meter in Ohm mode and read the resistance between Source pin and the Drain pin and then tell use how many Ohms you get on the meter, make sure to report exactly what you see on the meter to whether it is in Ohm, K Ohm, or M Ohm.
                          • Techboxcomputer
                            • Aug 2016
                            • 61
                            Okay from the mosfets pictured in my last attachment left to right (This is taken on the back of the board with one lead on the right pin and one lead on the middle pin)
                            1 .5 OHMS
                            2 1.1 OHMS
                            3 .7 OHMS
                            Hope this helps
                            • Dumah Brazorf
                              • Jun 2013
                              • 179
                              • Italy
                              Sorry i'm not english and i don't understand what do you mean by "tests through".
                              You did not test all possible connection, at least 6 measures, and ensure there's .5V or more.
                              • Moreno83
                                • Jun 2014
                                • 2008
                                • The Netherlands
                                I think he means continuity with " tests through ".
                                  1 .5 OHMS
                                  2 1.1 OHMS
                                  3 .7 OHMS
                                  Hope this helps
                                  Remove one MOSFET one at a time and then test it off the board again, so far you you do have shorted MOSFET.
                                  • CapLeaker
                                    Leaking Member
                                    • 7976
                                    something is shorted all right... but like budm already suggested: take one FET out at a time and check it, then put it back in its place. Not that you get mixed up later on where did what go.
                                    • Techboxcomputer
                                      • Aug 2016
                                      • 61
                                      So, rather then checking in circuit, you want me to desolder and resolder each mosfet? What am I looking for on the read for each mosfet?
                                        Yes, remove it and test it of the board the same way as you tested before, the one we looking for the most is the resistance reading between Source and Drain pin.
                                        • Chrissygizmo
                                          Samsung ue55hu8500t tcon board fuse blowing
                                          by Chrissygizmo
                                          Hi , I've got a Samsung UE55HU8500T that has sound but no picture, I've had it open and done a quick check of voltages etc, I found that the F2 fuse on the tcon board had blown (T-CON BOARD VD_STV5565EU22BC6LV0.3 -) so I replaced it with a similar value fuse but still nothing, ten I noticed the replacement fuse had blown too . I would appreciate any help with this. Thank you in advance...
                                          04-28-2021, 11:15 PM
                                        • Rictech
                                          Panasonic SA-MAX770PU SMPSU board fault....
                                          by Rictech
                                          Hello everyone. 😀
                                          As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                          Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                          Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                          This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                          There are no devices that have exploded or otherwise show signs...
                                          08-26-2024, 01:05 AM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
