LG 42LN5400 Power but no backlight, picture or sound
  • dhoff024
    • Mar 2013
    • 96
    Re: LG 42LN5400 Power but no backlight, picture or sound
    So I figured out how to properly get the LED strips off the TV and disconnected. The last question I have is where do I find the panel number? I just want to make sure I get the correct LED strips.
      There should be a sticker on the back of the panel for the LCD panel model number. Show us the pictures of the whole back side of the TV may be I can see the sticker.
      • diif
        • Feb 2014
        • 6978
        • England
        The strips are usually stuck down with double sided tape and clip into that green vertical strip. Warm up the back panel with a hair dryer to soften the adhesive.
        Panel number is usually on a sticker on the back of the panel.
        Are you replacing with guaranteed brand new strips or second hand, no point in swapping them all if so.
        • dhoff024
          • Mar 2013
          • 96
          Well I have seen second hand ones on eBay but am a little skeptical to purchase them. If these Tv's had issues with the LED's I don't know how much I trust second hand ones. I was planning on getting them from shopjimmy. Also I see one that is burnt badly but don't know if there are any others that are bad so I would hate to buy just that strip and need to buy more. This is my first time replacing LED's so I'm open to suggestions as always budm has been a great help and i also appreciate your input so if either of you has any suggestions as to if I should buy the LED's from shopjimmy or if they are ok to buy off eBay I would appreciate it and would trust your suggestions.
          • dhoff024
            • Mar 2013
            • 96
            I didn't even realize it was on the back of the TV case. I thought it was on the back of the panel. I was able to find it. It was a big sticker that said LG display so that was my stupidity for not seeing it. Thanks for the help
            • dskall
              • Oct 2016
              • 2905
              • usa
              #26
              There should be a sticker on panel
              • dhoff024
                • Mar 2013
                • 96
                Ended up ordering the LED's from shopjimmy.com. The correct LED's were out of stock but they gave me an alternate set of LED's that are supposed to work so I ordered them and some double sided tape. Once everything gets here I will put it back together and let you know the how it goes. Can I replace the led' s and turn it back on before I put it all back together?
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  #28
                  If you connect all the boards minus panel
                  • dhoff024
                    • Mar 2013
                    • 96
                    Just wanted to thank everyone who helped me diagnose this TV. I received the new LED's Wednesday, installed them and put everything back together, updated the firmware and the TV is back in working order. It feels good to be able to take one that someone had in the trash and bring it back to a working useable TV.
                      Thanks for the follow-up on the repair.
                      • dhoff024
                        • Mar 2013
                        • 96
                        So in my haste of putting the TV back together after replacing the LED's I forgot to put the white plastic pin clips on the white LED surround. Is it worth tearing the TV back apart to put them back or should I just not worry about it?
                        • heavymachines
                          • Mar 2011
                          • 1028
                          Those help support the diffuser sheets and lcd from flexing too much also help hold the white sheet to the metal back. It probably be ok without em for a min but could potentially cause problems in long run if back sheet or defuser sheets sags too much from heat or gravity.
                          • dhoff024
                            • Mar 2013
                            • 96
                            I will take it back apart today or tomorrow and put them on and put it back together. Thanks for the input
                            • DjKrish
                              • Oct 2012
                              • 354
                              • SG
                              #34
                              I have a problem with this same tv as well, no backlight but theres
                              image and sound. Tested the voltage on the PSU, theres voltage present on both + points which is 200 plus on side and 150 plus on another side. Theres no flash when turn on the tv either. Is the LED stripes shorted for good inside the panel? Or the LED driver dead?
                              • dskall
                                • Oct 2016
                                • 2905
                                • usa
                                #35
                                Replace your bad led's
                                  You have open circuit in the LED string.
                                  • nrbrandt
                                    • Sep 2017
                                    • 30
                                    I've got this same model of TV and I could use some help diagnosing it. When you turn the TV on, it's hit or miss whether the back light comes on or not. When it does turn on, you can bring up the menu (I don't have anything hooked to it to know if the sound works).
                                    Voltages from the power supply board to main board appear to be normal. The 24 volt pin registers 24.3. DRV ON registers 3.2 and PDIM1 and 2 are both 1.1v.
                                    On the connector to the LED strips I get (from left to right on the connector) 112v, 28v, 74v, and 19v if the back light turns on. If not I get 56v, 0.1v, 56v, 10v.
                                    Once you've gotten the TV to turn on, it won't come on again without being unplugged first.
                                    Is this bad LED strips or else what do I need to check next?
                                    • Tynan Dill
                                      by Tynan Dill
                                      Assuming...
                                      11-22-2024, 01:46 PM
                                    • Mgiffune
                                      by Mgiffune
                                      06-09-2024, 10:28 AM
                                    • TR103
                                      by TR103
                                      - it keeps rebooting
                                      01-22-2025, 04:12 PM
                                    • PantherDave
                                      by PantherDave
                                      Hi all!
                                      05-29-2024, 02:01 PM
                                    • BoardHoarder
                                      XBR-65X850D Backlight/Power On Help
                                      by BoardHoarder
                                      Currently trying to save a 65” 850D that definitely has a main board issue. Power supply has standby voltage and PS ON pin shows 3.5VDC but main has no signs of life…..no light under Sony logo and no optical port lit up. 12VDC is created by main board but no input triggers from main = no TCON 12V and no BL ON voltage present. I know about the trick of pulling the main to trigger the test pattern from the TCON but I get no backlight. If I jumper the 3.5VDC to TCON ON and BL ON, I can shine a light on the panel and see solid green, red, blue and white cycling. The 4 + backlight pins on the power...
                                      02-09-2024, 11:00 PM
