Hello guys,
Situation :
The top left of the TV started to do fading horizontal lines. It's like the top third of the screen, and the lines were fading to normal reaching half the screens.
The horizontal lines were NOT black, they were a different tone of colour, but you were still able to see the image correctly.
After a couples of weeks like this, the screen went greyish/black. It's not the same colour as when the TV is off. Same issue on all Input.
The sound is still working perfectly on HDMI.
The backlight are all ON.
Cannot see the menu nor the splash screen on bootup.
What I have done / tested so far :
After lurking lots of forum, the symptom pointed out the T-Con board, since No picture, but Sound and Backlight are OK.
I have ordered a new T-Con and replaced it. Same issue.
The fuse F1 on both T-Con are ok.
I have 12 V after F1.
When I unplug either 2 of the ribbon cable or the T-Con main connector while the TV is on, it doesn't change anything. Doesn't flicker or anything.
When I press the channel button on the TV, the tone of grey/black seems to changed a bit.
The chip UL1 on the main power board is really hot to the touch. And the board is a bit darker around the chip than the rest.
No Capacitors looks burnt or damaged.
Whats Next ?
I would need your help for next step.
What should I measure with my multimeter?
What can be the issue? The main board?
Let me know thanks
Situation :
Whats Next ?
Let me know thanks
