Insignia NS-50D40SNA14
  • Helisstra
    • Sep 2017
    • 10
    Hello guys,
    Situation :
    The top left of the TV started to do fading horizontal lines. It's like the top third of the screen, and the lines were fading to normal reaching half the screens.
    The horizontal lines were NOT black, they were a different tone of colour, but you were still able to see the image correctly.
    After a couples of weeks like this, the screen went greyish/black. It's not the same colour as when the TV is off. Same issue on all Input.
    The sound is still working perfectly on HDMI.
    The backlight are all ON.
    Cannot see the menu nor the splash screen on bootup.
    What I have done / tested so far :
    After lurking lots of forum, the symptom pointed out the T-Con board, since No picture, but Sound and Backlight are OK.
    I have ordered a new T-Con and replaced it. Same issue.
    The fuse F1 on both T-Con are ok.
    I have 12 V after F1.
    When I unplug either 2 of the ribbon cable or the T-Con main connector while the TV is on, it doesn't change anything. Doesn't flicker or anything.
    When I press the channel button on the TV, the tone of grey/black seems to changed a bit.
    The chip UL1 on the main power board is really hot to the touch. And the board is a bit darker around the chip than the rest.
    No Capacitors looks burnt or damaged.
    Whats Next ?
    I would need your help for next step.
    What should I measure with my multimeter?
    What can be the issue? The main board?
    Let me know thanks
    Re: Insignia NS-50D40SNA14
    Is the T-CON mounted on the bottom center of the LCD PANEL?
    Pictures of the whole back side of the TV showing all the boards will help.
    What do you get on the screen if you have one ribbon cable between the T-CON and the LCD panel connected one at a time?
    • Helisstra
      • Sep 2017
      • 10
      Here the picture of the full layout.
      Yes T-Con in bottom middle
      When I plug only the right ribbon, half right of the image is displayed correctly.
      When I plug only the left ribbon, no image.
      If I plug the right ribbon, on the left LCD, no image.
      If I plug the left ribbon, on the right LCD, no image.
      Plug back the right ribbon on the right LCD, half right image again.
      I can do that right since both ribbon have the same P/N ?
        You have problem in the LCD panel. This LCD panel has tab bonding board on the bottom edge of the screen so when people spray the cleaner on to the screen the liquid will drip down on to the board and damage the board, that is more likely to cause of the failure, but if you lucky, it can also be bad caps on the tab bonding board. The bottom line is that you will have to get the frame off the panel to inspect the board for damages.
        • CapLeaker
          Leaking Member
          • 8326
          what budm said x 2
          • Helisstra
            • Sep 2017
            • 10
            Thanks I will remove the frame, later today or tomorrow to inspect the board.
            • Helisstra
              • Sep 2017
              • 10
              I have removed the frame, I don't see anything suspicious on the board. Linked picture
              Is there a chance of repair at this point or it's dead since it's the LCD Panel ?
              The bonding board is not replacable due to the soldered ribbon ?
                There are many caps on that tab bonding board, you should check to see if any of them show low (100 Ohms or less) resistance when measured between the two legs of each caps.
                • Helisstra
                  • Sep 2017
                  • 10
                  Tested them all, no one have 100 ohm or less.
                  • Helisstra
                    • Sep 2017
                    • 10
                    Is there something else I can do about this issue or it's a case of buying a new TV ?
                    Let me know thanks
                    • advant
                      by advant
                      02-03-2020, 12:25 AM
                    • Tr0ll
                      by Tr0ll
                      Original T-con:
                      First replacement T-con:
                      10-07-2023, 07:48 PM
                    • kca
                      by kca
                      Hello all ~
                      08-31-2025, 06:38 AM
                    • Daren87
                      Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                      by Daren87
                      I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                      08-13-2023, 03:25 PM
                    • netgearnetgear
                      TCL 43S423 TCON OR PANEL FAULTY???
                      by netgearnetgear
                      Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                      08-20-2025, 06:04 PM
