SONY KDL-52ex700: No picture, No sound, No backlight but gets Standby & Green light
  • sacrh
    • Aug 2017
    • 12
    • usa
    We came one evening & realized this problem when tried to turn on the TV (SONY KDL-52ex700), there has been, no sound, no picture, no click sound (for backlight).
    Here is the sequence I have checked so far.
    1. Pressing the Energy saving switch button, TV used to turn ON green light, get backlight click sound & used to show Sony logo with sound
    - None above happen anymore. No green light, No sound, no picture, No backlight
    2. Pressing the power switch button used to either put the TV in standby mode OR turn on green light, get backlight click sound & used to show Sony logo with sound
    - Now when pressed first time I can do get Red stand by light & after pressing one more time gets green light but then no sound or logo
    3. Checked for few minutes, on Green light & it remains solid green & does not turn Red until I press remote button to Standby mode. So Red light do not blink. Remains solid Red.
    4. Backlights are not illuminated at any time
    4. As per few suggestions changed the main board but all above behavior remains same. Said that I felt "probably" it didn't used to respond to other keys on the remote (like volume, channel change etc). But not very sure (I can replcae the original board & confirm if needed).
    5. I checked the voltages & initially felt problem was more likely with logic board, as I do get 3.3V on Stand-by pin on Power board connector as well as Logic board input connector.
    6. Gets 3.3V at connector CN6150 (picture attached) but do NOT get voltages on any other pins of the connector, either in Stand-by or Power On mode.
    Question is, Do the other pin voltages on CN6150 are triggered thru the main board? Or should they be available all the times once in standby or power ON mode? Should I have replaced the Power board instead of Logic board?
    Is there any flow diagram which shows how the voltages exactly flows thru this model of Sony. Unfortunately I didnt find the Schematic Board circuit diagrams for this particular model on any websites.
    Will really appreciate any help on this.
    Sachin
    Re: SONY KDL-52ex700: No picture, No sound, No backlight but gets Standby & Green lig
    https://www.badcaps.net/forum/showthread.php?t=25810
    May be you will understand more as to what the TV requires to operate.
    Service manuals:
    http://elektrotanya.com/?q=showresul...oria=&kat2=all
    Training manuals:
    There are also many thread at BC about this model.
    • sacrh
      • Aug 2017
      • 12
      • usa
      After doing some more diagnosis felt the Power board seems to be the issue somwehere. As the green light turns on I will be curious to know how the voltages flow. Where can I verify the voltages flow between different boards. Specifically triggering of high voltages on Power board from logic board. Went thru dufferent manuals but will appreciate any inputs or do we have any thread running on that?
      • attainteddragon
        • Apr 2013
        • 764
        • australia
        if you want more help, you need to upload some pics of the entire rear of the set and a pic of each board.
        we assume that you have a dmm and basic usage knowledge to proceed further.
        WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
          You need top look at the diagram of each board and then look at your TV to see how the wire harness are connected between each board, the connectors of the boards have pin name and pin number to tell you what they are. You know how to read schematic, right?
          • sacrh
            • Aug 2017
            • 12
            • usa
            My apologies for the delayed response.
            Yes very well aware of the schematics & have all the gears at home. DMM, Soldering kit, etc..
            I have attached pictures of the back of the TV, Power board & Main/Logic board (replaced this day back so not original). Also atached some schemtics diagram from the manual.
              You have the schematic of the power supply that you can see the connector pin names to tell you what they are.
              • sacrh
                • Aug 2017
                • 12
                • usa
                Was curious if there is any document/picture shows the flow of voltage. Meanwhile I changed the Power board & Main board & almost able to had everything working. Sony logo comes up with the sound. Was able to upgrade the firmware, set the network configuration & tune & watch the channels. The problme I am running into now is, after around 10-15 mins watching, the TV turns off & then gives "6" blinks of the Red standby light.
                The diagnostic manuals for 6 Red light blinks says,
                6 BACKLITE_ Back Light Error (Panel Inverter)
                Not sure what exactly that means but as I have alreayd changed Power & Main board. So is this T-Coon board issue? After going thru manuals, my understanding of this error & Panel board so far is not clear.
                Any advice?
                  BACKLIGHTS issue.
                  "Was curious if there is any document/picture shows the flow of voltage." What does that mean the 'The flow of the Voltage'?
                  Turn down the backlights level (not brightness) to see if the backlights will stay on longer.
                  • sacrh
                    • Aug 2017
                    • 12
                    • usa
                    BACKLIGHTS issue.
                    By 'Flow of voltage', I was referring to functional flow, once Power Switch is turned ON, & then from standby mode untill there is a picture on the screen. Possible voltages on various connector pins & IC's during this process. Like when TV is in standby & then in power ON mode. Basically which pin I should get how much voltage at what point of time (mainly I was curious about pins on connector 6150 on power board) & different pins on IC's on Main board. Also how the high voltages are triggered on Power board from main board. What are the voltages expected across different connector pins during the process.
                    For example I realized my original power board wasnt showing any voltage across all pins on 6150 except 3.3v on Pin1 & it remained that way even after Power ON (green light was ON). The board circuit digram mention the details in limt.
                    Meanwhile I will change the backlights level from picture setup & update in few hours.
                    Thank you
                    • sacrh
                      • Aug 2017
                      • 12
                      • usa
                      I turned down the backlights level (from middle to low) & now the TV turns off within 10-15 seconds .. I do not even get chance to revert that settings. By the time I can reach the picture setting the TV is turned off.
                      • sacrh
                        • Aug 2017
                        • 12
                        • usa
                        Any thoughts. Which one is thepanel board?
                          So did you download this service manual?
                          sony_kdl-32ex700_40ex_46ex_52ex_60ex700_701_703_chassis_az1-l_9-888-268-51_ver.1.0.pdf
                          Did you look at page 34 where CN6150 is and see all those pin label to tell you what they are?
                          In post 1 you said you do not have backlights but now you do which means that there is no way you can have all 0V readings on all the pin except the 3.3V pin. BTW, did you read the basic training so you will understand what the PS-ON and BL-ON are for?
                          At this point since you do have backlights on at least 10~15 seconds, then what you need to do is to put black probe of the DC meter on the chassis, put the red probe on pin 1 (or pin 2, these are the Anode pin of the LED strings) of the LED connector CN6800 then turn on the TV and see how high the Voltage goes up to before it goes out, record that reading. Turn the TV off then move the red probe to CN6801 pin1 (Cathode return of LED string 1) then turn on the TV and see how high the Voltage goes up to before the backlights go black then turn off the TV. Put red probe on the CN6801 PIN 2 (Cathode return of LED string 2) then turn on the TV and see how high the Voltage goes up to before the backlights go black then turn off the TV. Report all those readings.
                          BTW you look at page 34 of the schematic then you see how the LED strings are driven. BTW, how much electronics knowlegde do you have? For example: do you know how the Transistor is turned on and off? If you want me to help to do in-depth trouble shooting I will need to know how much you know first.
                          For example the connector CN6150 pin 3 (Power _on), if you follow that connection you will see where it goes to which if you understand the circuit then you hsould know that pin 3 is the signal Receiving pin and you can see how high the Voltage on that pin should be to turn on the Transistor.
                            http://www.shopjimmy.com/sony-1-474-...wer-board.htm#
                            Sony 1-474-212-11 (APS-263(CH), 1-881-773-12) GE2 Power Board
                            • sacrh
                              • Aug 2017
                              • 12
                              • usa
                              Budm sir my apologies. I have been working in the office & then busy helping volunteering cleaning work for Hurricane victims around neighborhood since last few weeks. I did spent some time going thru the schematics diagram but was not able to lot time reading material. I did my basic electronics during engineering so very well aware of the diodes capacitors, transistors. Will check few more things for Transistors as it has been a long time.
                              Really appreciate all the suggestions. Page 34 does make lot of sense as I reviewed it again. I will check the details on all the pins as per your suggestion tomorrow morning & update with the readings details, in table here.
                              Meanwhile I will be curious to know, why the TV turns off quickly now, after I infact lowered backlight settings from TV menu. It was ON for minimum 10-15 minutes before I lowered that setting. Also I would like to mention that I have replaced both power board & logic board replaced. Can they be faulty also?
                              Will update the readings soon as per your suggestions.
                              Thanks Budm
                                More likely the LEDs are failing and with less current flowing through them when the backlights level is turned down they cannot stay on so it goes into protection shut down. It will be good to have LED tester because opening up the panel is the last thing you will want to do. You can look on EBAY for similar product too.
                                http://www.shopjimmy.com/sid-gj2c-le...ght-tester.htm
                                • JoeC39
                                  • Apr 2019
                                  I am having similar problem as SACRH. My SONY KDL46EX700 TV has the standby light blinking 6 times. I downloaded the service manual and went through the troubleshooting check list. It directs me to check JL2565 on the BAL board. If over 2.65V Change G* board. Problem is JL2565 is not identified on the BAL board.
                                  As with SACRH when I power on I get the green light and the usual audible sound when the TV comes on then in a couple seconds it goes off again and the red error light starts blinking 6 times.
                                  When I measured the standby voltage for the specified 3.5V it actually read double at 6.6V. Disconnecting connector CN6150 and testing for 3.5V again it read 6.6V again.
                                  I am assuming that the GE2 power board is bad. Will replace and check again.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4350
                                    • Italy - Milan
                                    before cahnging the PSU have you tested voltage of a known good battery? Maybe tester is bad or low batt.
                                    6 blinks stands for backlight problem, you much probably have a bad led.
                                      6.6V on the 3.3V standby output sounds like measurement error.
                                      • sacrh
                                        • Aug 2017
                                        • 12
                                        • usa
                                        After long I started having the problem (since few months now). But has been more prominent now. Basically whenever the background picture gets dark in the movie or news (night scene etc...), voltage starts dropping & TV turns off. Seems it can not maintain lower voltage requirements of the TV set. Is this the problem with the power supply board? As that's the only board I never replaced? Or is it LED backlight issue?
                                        Appreciate your responses.
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light, but no sound
                                          by MOSSEP
                                          Hi
                                          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                          I have already tried replacing all of the...
                                          01-26-2025, 08:33 AM
                                        • arctor
                                          samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                                          by arctor
                                          hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                                          04-26-2025, 05:22 AM
                                        • B0r1s
                                          Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                          by B0r1s
                                          PSU - BN44-00878A
                                          Symptoms:
                                          The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                          A weak clicking sound was coming from the transformer.
                                          Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                          Progress:
                                          After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                          01-17-2023, 04:58 PM
                                        • shahnld
                                          Sony kdl 65xg9505 green amber blinking
                                          by shahnld
                                          Good Day.
                                          I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                          i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                          green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                          01-03-2024, 03:05 PM
                                        • rabbituk
                                          Sony HCD BX7700dbi CMT flashing standby
                                          by rabbituk
                                          I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
                                          So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
                                          02-11-2025, 05:05 PM
