SONY KDL-52ex700: No picture, No sound, No backlight but gets Standby & Green light
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: SONY KDL-52ex700: No picture, No sound, No backlight but gets Standby & Green lig
    If you turn your backlights down what effect does it have.
    Also if you turn off all the power savng and Eco mode settings does that help?
    • sacrh
      • Aug 2017
      • 12
      • usa
      Seems little improved, but it still does turns off whenever there us a black scene. Somehow if I can maintain that low voltage.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4537
        • Italy - Milan
        Yes sounds very much as a backlight led shorted half
        • skumaran
          • Apr 2021
          • india
          Hi Sacrh
          Was your tv working fine now,even my tv (sony KDL 52nx800)show the same symptom has yours,when checked found 0.5a fuse was blown replaced and checked but still has the same problem as yours.pls let me know if it was solved.
          problem is as soon as you turn on the tv goes to standby mode and when press the power button the led turns green and back to red with 6 blinks.
          no picture or logo only sound for just a sec.
          opened and checked the led strip ,which looks visually good.
          • MOSSEP
            Monitor Audio RSW12 - Green light, but no sound
            by MOSSEP
            Hi
            Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
            Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
            The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
            I have already tried replacing all of the...
            01-26-2025, 08:33 AM
          • arctor
            samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
            by arctor
            hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
            04-26-2025, 05:22 AM
          • B0r1s
            Samsung UE49KS7000SXXH - fast clicking sound in standby mode
            by B0r1s
            PSU - BN44-00878A
            Symptoms:
            The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
            A weak clicking sound was coming from the transformer.
            Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
            Progress:
            After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
            01-17-2023, 04:58 PM
          • brithepi2k
            Sony KD-65XE8596 no standby light
            by brithepi2k
            I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
            cheers...
            09-06-2025, 02:22 PM
          • shahnld
            Sony kdl 65xg9505 green amber blinking
            by shahnld
            Good Day.
            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
            01-03-2024, 03:05 PM
