Sharp TV no longer powers on
  • mattbatt
    • Jul 2017
    • 18
    I have inherited my fathers old TV it's a Sharp LC-60LE831U. It was powering on and off randomly until IC7905 blew it's top (TY264PN) I replaced it and the TV still didn't power up. I traced down that the 2.2 ohm fusible resistor R7914 was blown so I have replaced that and still no joy.
    I am measuring 164VDC on the two outside legs of the rectifier.
    On the TY264pn using pin 3 as ground I am measuring
    1) 0.5VDC 8) 0.0VDC
    2) 0.0VDC 7) 0.0VDC
    3) GND
    4) 0.0VDC 5) 164VDC
    There is no voltage going to the mainboard connector. There are no blinking lights on the front.
    Please help me troubleshoot this TV.
    Thanks,
    MattBatt
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Sharp TV no longer powers on
    Need good pictures of front and back of power board
    • mattbatt
      • Jul 2017
      • 18
      Darn it I forgot to put the powersupply model numbers in the first post
      Delta DPS-183BP A
      RUNTKA798WJQZ
      Jimmy took better pictures than I can.
      When I get home from work tonight I can try taking some.
      No caps look blown.
      • mattbatt
        • Jul 2017
        • 18
        OK I took some pictures let me know if there is an area I can highlight further.
        Thanks for the help
        • CapLeaker
          Leaking Member
          • 8326
          So I am guessing you have no 5V STBY voltage. Check if the 5V STBY rail is shorted (secondary). If you have juice going into the TY264pn, but nothing coming out, may be a good chance it is bad, needing to be replaced.
          • dskall
            • Oct 2016
            • 2905
            • usa
            I was unable to find spec sheet for TY264pn
            • R_J
              • 9588
              Here it is
              • dskall
                • Oct 2016
                • 2905
                • usa
                Where did you find it?
                • neilc6
                  • Nov 2015
                  • 1550
                  Check R7918 as well.
                  • mattbatt
                    • Jul 2017
                    • 18
                    r7918 is also good
                    this is where I bought the replacement chip from
                    http://www.newark.com/power-integrat...8?ost=TNY264PN
                    They have a PDF up on the page https://cdn.badcaps-static.com/pdfs/...09355ebacf.pdf
                      BTW, if you leave the DCV meter (set to 20VDC range) probes connected to standby Voltage output pin and GND and then power up the board, do you see the meter shows any activity at all?
                      I wonder if the Optoisolator on the EN pin may be damaged when that IC blew up, also the bypass cap on BP pin.
                      • neilc6
                        • Nov 2015
                        • 1550
                        The shopjimmy repair kit for a similar power supply replaces IC7905, D7908, R7914 and R7918.
                        http://www.shopjimmy.com/sharp-rdenc...repair-kit.htm
                        • mattbatt
                          • Jul 2017
                          • 18
                          That was one of my thoughts as well, unfortunately I am leagues of my depth of understanding circuit boards of this complexity. Where is the 5V regulator?
                          • mattbatt
                            • Jul 2017
                            • 18
                            Alright so next up on the test block is D7908 which has the symbol of a zener Diode. It has "P6KE 150A" printed on it. I looked it up it's a TVS diode (new to me).
                            Removing it from the board and using my diode test it reads 0.6V forward bias and OL reverse bias. In resistance mode it reads OL in forward bias and 13.743 Ohms in reverse bias.
                            The next component in series with the chip is R7909 a BYV26E which is reading 0.5V forward bias and OL reverse in diode mode on the DMM
                            I suspect these might be bad since I can follow the positive bus from the capacitor bank to R7914 (bad replaced) - D7908 (?) - D7909 (?) - IC7905 (bad replaced).
                            This is the best labeled board I think I've ever seen.
                            • mattbatt
                              • Jul 2017
                              • 18
                              Does anybody have a suggestion on which way I should look next?
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                The diode test is correct in 0.6V and OL but are you sure it's 13.7 ohms and not Megohms?
                                Can you give the voltages at the connector marked PD
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  certainly not an expert, but based on your first post which I assume was done after the replacement of the switching regulator IC, based on my very quick read on the attached spec, your reading of pin 5 prevents the IC from turning on because it is below the turn on spec which at power up should be above 200v... of course, the value you read might be ok after start up... but perhaps you need to monitor that point a few times to see if it reaches the threshold.
                                  • mattbatt
                                    • Jul 2017
                                    • 18
                                    Yep totally screwed that one up it's Megaohms sorry about that.
                                    • malogro
                                      Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
                                      by malogro
                                      Hello all,
                                      I'm stumped on this guy, so wanted to see if anyone has any further ideas:
                                      Intro:
                                      This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
                                      Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
                                      04-14-2023, 04:44 PM
                                    • sefoster
                                      Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                      by sefoster
                                      I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                      11-20-2022, 09:29 AM
                                    • SONY_E-WASTER
                                      Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
                                      by SONY_E-WASTER
                                      Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
                                      The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
                                      then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
                                      does...
                                      12-26-2021, 05:46 PM
                                    • Superbee_dad
                                      Sharp 80” long short flash backlight error - Help
                                      by Superbee_dad
                                      Hello Sharp TV experts
                                      Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                      > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                      > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                      01-24-2025, 11:51 PM
                                    • jose6326
                                      Samsung s32d850t powers off
                                      by jose6326
                                      Powers on as normal shows an image then powers off after 10 seconds
                                      I have to unplug it from the wall and replug to get it to turn back on but then shuts off
                                      No blown caps
                                      I searched for this model but nothing comes up...
                                      11-29-2024, 11:21 PM
