Panasonic Tx37lzd80
  • Norman1
    • Jun 2017
    • 77
    • Uk
    Panasonic Tx37lzd80
    Hi guys, I have a Panasonic that comes out of standby just fine,then the screen go's a dark blue and that's it,no picture no sound, no graphics, nothing. Any sudgestions?
    Thanks in advance
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Panasonic Tx37lzd80
    Need good clear straight on pictures of back of tv with cover off and each board.
    • Norman1
      • Jun 2017
      • 77
      • Uk
      Il take a few pics when I get in later, the back light led's are lit if that's any help.
      • attainteddragon
        • Apr 2013
        • 764
        • australia
        check your fuse on the t-con to star with.
        and pics.
        WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
        • Norman1
          • Jun 2017
          • 77
          • Uk
          Il have a look for the fuse now, I'm having trouble uploading pics, bloody computers
          • Norman1
            • Jun 2017
            • 77
            • Uk
            Pictures
            • Norman1
              • Jun 2017
              • 77
              • Uk
              Could you give me a hint as to where the fuse is on the t con panel?
              • diif
                • Feb 2014
                • 6978
                • England
                It's just next to the LVDS connector marked 24V/1.6A
                A pic of the back of your TV will help.
                • Norman1
                  • Jun 2017
                  • 77
                  • Uk
                  It looks like the fuse is open circuit, what rating is the fuse, is it 1.6ah as marked on the board?
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    The picture uploaded post #6 appears to be the power supply board. Is that where the blown 1.6Amp fuse is or is it on the Tcon board
                    • Norman1
                      • Jun 2017
                      • 77
                      • Uk
                      It's on the t con board 24v 1.6ah
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Go ahead and replace it with a 1.6A fuse. I suspect it's an smd fuse?
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          Some decent pictures would help. I would connect an ammeter momentarily across fuse and check current draw. Use min/max if you have it
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            I use these http://cpc.farnell.com/multicomp/mc1...-5a/dp/FF02271
                            • Norman1
                              • Jun 2017
                              • 77
                              • Uk
                              It's hard to find ppl selling them online, where do you go for yours? I wonder if a wickman fuse would work
                              • Norman1
                                • Jun 2017
                                • 77
                                • Uk
                                Does it matter if the voltage rating is higher
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  Hello Norman, without any pictures it would be total guesswork as to what type and size of fuse is on your board. If it's smd is it 603, 805, 1206?
                                  I get my replacement fuses from ebay since they tend to be low value parts and can be sent by ordinary letter post.
                                  https://en.wikipedia.org/wiki/Surface-mount_technology
                                  • Norman1
                                    • Jun 2017
                                    • 77
                                    • Uk
                                    Don't know if the quality of this pic is good enough to see
                                    • diif
                                      • Feb 2014
                                      • 6978
                                      • England
                                      I've used them successfully on 5 of these Panasonic TVs now after being recommended by an EE wizard on here. No come backs.
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        You weren't wrong there.
                                        Measure it as best you can and check against the chart. For example if its a 1206 type then it will measure 3.2mm x 1.6mm.
                                        • BigPete
                                          Panasonic Heatpump Dryer Repair
                                          by BigPete
                                          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                          Unfortunately the whole machine has to come apart to fix it.
                                          I have...
                                          11-01-2025, 06:40 PM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • AquaMan Ua
                                          by AquaMan Ua
                                          05-17-2025, 09:40 AM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
                                        • aa10aa10
                                          Panasonic Toughbook CF-33 mk1 BIOS repair
                                          by aa10aa10
                                          Good day,
                                          I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                                          I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                                          01-21-2025, 06:13 AM
