Samsung ln46a550p3f solarized screen problem
+ More Options
Posts
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: Samsung ln46a550p3f solarized screen problem
    change the chip .inexpensive and not difficult with good magnification .. seeing what you are doing goes a long way .
    • stock2009
      • Jun 2017
      • 19
      • usa
      Interesting. Looks like this is the chip. Crazy! it's just $1.35 !
      http://www.ebay.com/itm/1pc-of-New-A.../271948824333?
      Is that correct chip?
      My current chip also says AS19-H1G *
      I do not have any tools, and have never done this before? Will I be able to handle it ! if yes, what tools do i need.
      • diif
        • Feb 2014
        • 6978
        • England
        Yes, that's the chip.
        There are several videos on youtube showing a couple of different ways to remove the chip (hot air/low melt solder) and replacement (the trickier part).
        I would think you'd need a soldering iron, chipquik (its cheaper/a bit easier than hot air), solder, braid , flux and some kind of magnifying device. I also find a multimeter useful for checking for bridged pins.
        I wonder if the cost of buying the tools is greater than a repair service or second hand board though. I guess it depends on future tool usage.
        • dskall
          • Oct 2016
          • 2905
          • usa
          If your aim is to get your tv working I would replace t-con. It is not really repair for amateur. Lots of small parts around it.
          • stock2009
            • Jun 2017
            • 19
            • usa
            Thanks, I did a quick search and it looks like it will cost atleast 30-40 bucks to get started, and like you said depends on tool usage in future too.
            Got carried away a little. This does seem like the best option! Looking for the best chip now. Will update once I get the board.
            • stock2009
              • Jun 2017
              • 19
              • usa
              #26
              http://www.ebay.com/itm/ORIGINAL-46-.../181916375245?
              http://www.ebay.com/itm/ORIGINAL-46-.../281879117609?
              Any of these should work I assume?
              My board number:
              Part Number (From barcode): 35-D025860
              Board number: V520H1-C06
              Model: LN46A550P3F
              Model code: LN46A550P3FXZA
              • stock2009
                • Jun 2017
                • 19
                • usa
                #27
                PROBLEM SOLVED. Thanks guys!
                Replaced the t-con board with the exact set from ebay (used) for $35.
                I made sure part and board number are the same.
                Part Number : 35-D025860
                Replaced the board, turned on the TV, and did not have to do anything else. No reset or anything. Turned out to be an easy fix. Thanks everyone again!
                  Thanks for the follow-up.
                  • jetadm123
                    • 2169
                    #29
                    You could try cutting your losses a bit by selling your old board on eBay. Just let buyers know what the problem was and that you didn't have the proper tools/skills to replace the chip.
                    • stock2009
                      • Jun 2017
                      • 19
                      • usa
                      #30
                      yes, that's what I was thinking. Might get $10 out of it. Will also include the A19 chip I purchased but never used.
                      • noledud
                        • Dec 2013
                        • 413
                        • united kingdom
                        #31
                        Here in the UK i just us a seller off ebay offering TCON repair ( they also do the AS19 I believe) so i presume there will be sellers in the US offering the same sort of service.
                        • Chrissygizmo
                          by Chrissygizmo
                          02-10-2025, 12:33 AM
                        • Chrissygizmo
                          samsung galaxy ao2s very temperamental after screen replaced
                          by Chrissygizmo
                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                          Ive eventually managed to get it on and working but it's very temperamental...
                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                          05-26-2024, 12:05 AM
                        • Kiberge
                          Samsung LH82QENELGC/EN Help needed - Static line on screen
                          by Kiberge
                          HI guys!
                          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                          04-22-2024, 11:28 AM
                        • Ryan.man
                          by Ryan.man
                          02-04-2025, 12:23 PM
                        • arbitarytwist
                          Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                          by arbitarytwist
                          Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                          Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                          03-01-2025, 01:16 PM
