looking for info on how to turn backlights on without AV board on a vestel power supply I forget the model but it's led I have diagram at work tried loads 24v sw to bl on / off ... Also standby to standby 5v+ with vestels how the hell do u perm turn on backlight without main AV board.. Turning 55 led TVs into roof mounted lights at work and non of us can seem to get backlights on with bl on.. Plug main AV in and it comes on.. Any ideas how to perm get black lights lit without need for main AV.. I know it's a ips Psu.. Forget the model.
Vestel 17IPS12 BL-On/Off how to
Re: Vestel BL-On/Off how to
can you post the power supply model number and also post a picture of the power supply we can advise more then. -
normally you would jump ps/on to 5v and bl/on to 5v, (pending make and so forth) with 1k resister.
ps/on turns on your other voltages and bl/on is the on command for the backlights.WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
+1
If the schematic for 17IPS12-R3 is similar to your power supply then jumper ST_BY to +5V_STBY and also BL_ON-OFF to +5V_STBY
https://www.electronica-pt.com/esque...ps12-r3-36113/Willing to help but I'm no expert.Comment
cheers guys, i work for a company that repairs catalogue tv returns, and soundbars, so we have diffrent tvs to repair on daliy basis, if anyone requires , dumps. for most logik tv's and samsungs and toshiba , digihome, i can assist, as what we do on daily basis we can also get replacement mainboards, dvd roms and dvd rom eeproms. inbox me, if you ever need any of the above cheers lee.Comment
That would be brilliant. There is a thread at the top of page 1 for EEPROM dumps.
It would be excellent if the mainboard model number, IC location and part number along with screen model number was given along with the dump file.
I'm sure the forum users would be very pleased with anything you could offerWilling to help but I'm no expert.Comment
the more eeprom dumps the better.
also having your user name in the eeprom thread will make it easier to ask if you have access to a particular eeprom.
thanks heaps.WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
Hi. Noticed your post. Looking for Toshiba 32L1350UD service guide. The Tv will not turn on.cheers guys, i work for a company that repairs catalogue tv returns, and soundbars, so we have diffrent tvs to repair on daliy basis, if anyone requires , dumps. for most logik tv's and samsungs and toshiba , digihome, i can assist, as what we do on daily basis we can also get replacement mainboards, dvd roms and dvd rom eeproms. inbox me, if you ever need any of the above cheers lee.
TimComment
by An-klammHello!
I am in despair with a Vestel 17IPS12 power supply.
With the TV, the backlight just stays off.
( Backlight tested with backlight tester = IO)
12V on the secondary side are there and constant. Voltage of the backlight is when switching on once briefly at about 60-70V and then drops slowly. (up to about 36V I have observed it whether it then drops further I do not know).
But I am sure that the problem is on the primary side, because the DC high voltage is only at 295V. I expected about 330V (with an input of 230V 50Hz).
I checked the mosfet in the component... -
by alltvrepairsHi
Am after a schematif for 17IPS12 that uses the BM1Q001FJ-E2. I have pdf for the V3 version that uses FAN6300 but circuit is not the same.
Any help appreciated!... -
Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
The TV was stuck on the logo and I couldn't access the update menu.
I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
The image result was good, but the image is inverted.
The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in... -
by France_53Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
by lberkaniHi everyone,
I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
- Toshiba 65UL2163DG
- Vestel 17MB180E mainboard
- Panel VES650QNTX-N2-N42
- Version V1.28.100.0 if available
If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt... - Loading...
