Vestel 17IPS12
  • An-klamm
    • Feb 2023
    • 43
    • Deutschland
    Vestel 17IPS12
    Hello!
    I am in despair with a Vestel 17IPS12 power supply.
    With the TV, the backlight just stays off.
    ( Backlight tested with backlight tester = IO)
    12V on the secondary side are there and constant. Voltage of the backlight is when switching on once briefly at about 60-70V and then drops slowly. (up to about 36V I have observed it whether it then drops further I do not know).
    But I am sure that the problem is on the primary side, because the DC high voltage is only at 295V. I expected about 330V (with an input of 230V 50Hz).
    I checked the mosfet in the component tester and it seems OK. Tested optocoupler for feedback pin (feedback is also pulled down to about 0.3V).
    About 16V is coming from the winding (I don't know what it's called. Secondary winding?) to supply the quasi-resonant control (1Q001).
    What else can I check?
    What voltage should be on which pin of the 1Q001 for it to start and switch the mosfet?
  • Diah
    • Feb 2013
    • 6552
    Re: Vestel 17IPS12
    you wrote you have 12V...... what about 5V STBY ? and 24VCC ???
    what did the front LED indicator do when you power the TV on ?
    did you disconnect the MB from Power boards and tested the Power boards as stand alone to see if it produce all V above ???
    and what V give you the LED tester for all Groups?
    • arizanotlari
      • Nov 2014
      • 158
      • Turkiye
      Re: Vestel 17IPS12
      Dont touch primary side. psu working good. check c113 and replace led strips.
      https://www.badcaps.net
      • An-klamm
        • Feb 2023
        • 43
        • Deutschland
        Re: Vestel 17IPS12
        One leg of the optocoupler probably had no contact. Now the TV is working again.
        So it was probably only the optocoupler. The old one had a voltage drop of 0,5V, although the datasheet says maximum 0,2V. With the new one it is about 0.1V and now everything works fine again.
        • nomoresonys
          • 12328
          • U.S.
          Re: Vestel 17IPS12
          Good work, good thing you stuck with verifying the powerboard and didn't jump to any conclusions, good troubleshooting is about not assuming anything.
          • alltvrepairs
            Vestel 17IPS12 using IC U101 BM1Q001 BM1Q001FJ pdf
            by alltvrepairs
            Hi
            Am after a schematif for 17IPS12 that uses the BM1Q001FJ-E2. I have pdf for the V3 version that uses FAN6300 but circuit is not the same.
            Any help appreciated!...
            02-01-2024, 07:46 AM
          • Jaime Morillo
            Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
            by Jaime Morillo
            Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
            The TV was stuck on the logo and I couldn't access the update menu.
            I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
            The image result was good, but the image is inverted.
            The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
            Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
            08-18-2025, 11:38 AM
          • France_53
            Vestel tv, how to flip the image?
            by France_53
            Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
            05-12-2024, 05:22 AM
          • Davy no Caps
            Vestel 17MB82S EEprom dump required
            by Davy no Caps
            First time trying to fix a TV for a friend, it's a Bush DLED32165HD.
            Power Board - 17IPS11
            Mainboard - 17MBS82S
            Panel - VES315WNDB-02
            Red blinking standby light is on steady, press power button on remote and light flashes 7 times then stays steady, press power on remote again light flashes 10 times and then goes off.
            Checked all the voltages on the power board inc backlight circuit, they all read ok and are stable. Backlights tested with backlight tester and all work fine (2 strips x11LED on each).
            No picture, backlight or sound just blinking...
            06-06-2025, 03:22 PM
          • FlailingEngineer
            Help with Bush Tv (Vestel 17mb95m Mainboard)
            by FlailingEngineer
            Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
            Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
            05-31-2023, 06:52 AM
