Vestel 17IPS12 BL-On/Off how to
  • promo7uk
    • Aug 2014
    • 31
    • uk
    looking for info on how to turn backlights on without AV board on a vestel power supply I forget the model but it's led I have diagram at work tried loads 24v sw to bl on / off ... Also standby to standby 5v+ with vestels how the hell do u perm turn on backlight without main AV board.. Turning 55 led TVs into roof mounted lights at work and non of us can seem to get backlights on with bl on.. Plug main AV in and it comes on.. Any ideas how to perm get black lights lit without need for main AV.. I know it's a ips Psu.. Forget the model.
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Vestel BL-On/Off how to
    can you post the power supply model number and also post a picture of the power supply we can advise more then.
    • promo7uk
      • Aug 2014
      • 31
      • uk
      17ips12 vestel mate obviously it's BL On / Off but no idea it ground or 12v or 24v or even dim .. As vestel are mostly different to activate backlight without main AV.. Does standby need to also be activated
      • attainteddragon
        • Apr 2013
        • 764
        • australia
        normally you would jump ps/on to 5v and bl/on to 5v, (pending make and so forth) with 1k resister.
        ps/on turns on your other voltages and bl/on is the on command for the backlights.
        WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          +1
          If the schematic for 17IPS12-R3 is similar to your power supply then jumper ST_BY to +5V_STBY and also BL_ON-OFF to +5V_STBY
          https://www.electronica-pt.com/esque...ps12-r3-36113/
          • promo7uk
            • Aug 2014
            • 31
            • uk
            cheers guys, i work for a company that repairs catalogue tv returns, and soundbars, so we have diffrent tvs to repair on daliy basis, if anyone requires , dumps. for most logik tv's and samsungs and toshiba , digihome, i can assist, as what we do on daily basis we can also get replacement mainboards, dvd roms and dvd rom eeproms. inbox me, if you ever need any of the above cheers lee.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              That would be brilliant. There is a thread at the top of page 1 for EEPROM dumps.
              It would be excellent if the mainboard model number, IC location and part number along with screen model number was given along with the dump file.
              I'm sure the forum users would be very pleased with anything you could offer
              • attainteddragon
                • Apr 2013
                • 764
                • australia
                the more eeprom dumps the better.
                also having your user name in the eeprom thread will make it easier to ask if you have access to a particular eeprom.
                thanks heaps.
                  https://www.badcaps.net/forum/showth...212#post753212
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Did you get it out of standby?
                    • timbit
                      • Jun 2017
                      • 8
                      Hi. Noticed your post. Looking for Toshiba 32L1350UD service guide. The Tv will not turn on.
                      Tim
                      • An-klamm
                        Vestel 17IPS12
                        by An-klamm
                        Hello!
                        I am in despair with a Vestel 17IPS12 power supply.
                        With the TV, the backlight just stays off.
                        ( Backlight tested with backlight tester = IO)
                        12V on the secondary side are there and constant. Voltage of the backlight is when switching on once briefly at about 60-70V and then drops slowly. (up to about 36V I have observed it whether it then drops further I do not know).
                        But I am sure that the problem is on the primary side, because the DC high voltage is only at 295V. I expected about 330V (with an input of 230V 50Hz).
                        I checked the mosfet in the component...
                        10-18-2023, 01:13 AM
                      • alltvrepairs
                        Vestel 17IPS12 using IC U101 BM1Q001 BM1Q001FJ pdf
                        by alltvrepairs
                        Hi
                        Am after a schematif for 17IPS12 that uses the BM1Q001FJ-E2. I have pdf for the V3 version that uses FAN6300 but circuit is not the same.
                        Any help appreciated!...
                        02-01-2024, 07:46 AM
                      • France_53
                        Vestel tv, how to flip the image?
                        by France_53
                        Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                        05-12-2024, 05:22 AM
                      • massimomax
                        Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                        by massimomax
                        Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende piΓΉ,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                        spero che qualcuno puΓ² averlo per riprogrammare eprom. grazie
                        Post in English !!!
                        I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                        02-28-2025, 07:27 AM
                      • Adenitz
                        Troubleshooting Vestel TV, has standby, but cannot turn ON
                        by Adenitz
                        I need advice in troubleshooting Telefunken TV (it is actually Vestel). There is red Standby light but TV cannot be turned on either by remote control (which is good and tested on another TV) or by actual on/off switch at the back of the TV.
                        Power board is Vestel 17IPS71 and I'm not sure about the mainboard, it seems like 17MB82S
                        Both boards are shown in the attached photos.
                        What is normally first that is checked in this case. I have removed power board, make sure it has no dangerous voltage on the big caps and check many components (transistors and diodes)...
                        12-27-2023, 03:43 AM
