Vestel 17IPS12 using IC U101 BM1Q001 BM1Q001FJ pdf
  • alltvrepairs
    • Jan 2014
    • 256
    • Malta
    Hi
    Am after a schematif for 17IPS12 that uses the BM1Q001FJ-E2. I have pdf for the V3 version that uses FAN6300 but circuit is not the same.
    Any help appreciated!
  • yokoono
    • Apr 2010
    • 510
    I only have the list with the value of the components from the 17IPS62 which uses the same integrated.​
    • An-klamm
      Vestel 17IPS12
      by An-klamm
      Hello!
      I am in despair with a Vestel 17IPS12 power supply.
      With the TV, the backlight just stays off.
      ( Backlight tested with backlight tester = IO)
      12V on the secondary side are there and constant. Voltage of the backlight is when switching on once briefly at about 60-70V and then drops slowly. (up to about 36V I have observed it whether it then drops further I do not know).
      But I am sure that the problem is on the primary side, because the DC high voltage is only at 295V. I expected about 330V (with an input of 230V 50Hz).
      I checked the mosfet in the component...
      10-18-2023, 01:13 AM
    • Jaime Morillo
      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
      by Jaime Morillo
      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
      The TV was stuck on the logo and I couldn't access the update menu.
      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
      The image result was good, but the image is inverted.
      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
      08-18-2025, 11:38 AM
    • France_53
      Vestel tv, how to flip the image?
      by France_53
      Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
      05-12-2024, 05:22 AM
    • FlailingEngineer
      Help with Bush Tv (Vestel 17mb95m Mainboard)
      by FlailingEngineer
      Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
      Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
      05-31-2023, 06:52 AM
    • lberkani
      Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
      by lberkani
      I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
      The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
      The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
      I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
      - Toshiba 65UL2163DG
      - Vestel 17MB180E mainboard
      - Panel VES650QNTX-N2-N42
      - Version V1.28.100.0 if available
      If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
      11-11-2025, 12:37 PM
