TCL - L50E3020FS not turning on
  • Amraks
    • Nov 2011
    • 725
    Re: TCL - L50E3020FS not turning on
    I think I have narrowed it down to being that chip(U401) and But I also thought we might have some bad resistors along the LVCC line but they are testing to near their respected values.
    Diodes Tested around the circuit
    D401 = Good
    D403 = Good
    D404 = Good
    So checking on the VCC line
    R412/2R7 = 3.0 Ohms (good)
    R409 /100R = 100.3 Ohms (good)
    D402(Zenor Diode going back to ground)= Good
    R305 4R7 = 5.0 ohms
    *R314 4R7 (not really necessary as it goes into another chips VCC supply which turns on fine and powering its chip, ready signal then switches a transistor enabling power supply for pin 7(Lvcc) on u401 ) = 5.0 ohms
    Tested at
    R305 = 17.0v (Good)
    Pin 7 tested off d401 = 16.0v
    Also I have removed u401 from circuit while testing.
    I would say this FSFR1700XS is faulty.
    • Amraks
      • Nov 2011
      • 725
      Thanks all that helped on this TV
      A new FSFR1700XS has bought back the voltages and the tv is now working.
      • maxvalutech
        • 804
        • australia
        Nice to see a conclusion post as so many fade into the ether leaving one wondering what happened.
        • Amraks
          • Nov 2011
          • 725
          I like to finish what I started and hopeful someone else benefits from this.
          Schematics and data sheets helped a lot to understand that 24vdc circuit that was having trouble firing.
          enjoying working on LED TV Power supply problems now days now I kinda know more of what I am looking at.
          I think I might get back to Plasma Power Supplies, I have 2 Plasma's I have been putting on the back burner for awhile now.
          • Amraks
            • Nov 2011
            • 725
            Managed to get another one of these TV's
            no ps-on this time
            Main filter caps voltage is 324v this time so the other PFC is mising.
            both these are open circuit replaced them as they had holes blown in them, I powered on tv and got some new holes in the same components I replaced. all diodes look fine.
            R201 = 4R7
            R201 = 4R7
            I am trying to figure out where to look next.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #26
              Got some new holes in what? R201 & R202. If so then check the resistance between pin 1 & pin 6,7,8 of FSL206MR for short circuit internal mosfet.
              • Amraks
                • Nov 2011
                • 725
                Yes r201 and r202 both have nice holes in them again lol.
                FSL206MR
                Pin 6 427.3 ohms
                Pin 7 427.2 ohms
                Pin 8 427.1 ohms
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  #28
                  Not a dead short circuit but a very very low reading. Pins 6,7,8 are all connected together internally. I would have expected it to read Kohms while still in circuit.
                  I would remove it and test between pin 1 and Pin 6 (or 7 or 8.)
                  • Amraks
                    • Nov 2011
                    • 725
                    out of circuit readings
                    Pin 6 0.680 k
                    Pin 7 0.680 k
                    Pin 8 0.681k
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      #30
                      I would replace the IC.
                      With the set off you could also check between the pin1 to pins 6-7-8 on the board (with the IC removed) to make certain there is no low resistance and also the components around it for any damage.
                      • Amraks
                        • Nov 2011
                        • 725
                        pin 1 to pins 6-7-8 no low readings.
                        no damage except for them 2 resistors which where acting like a fuse.
                        bit of a back story on the tv
                        person was watching tv for 4 hours and turned it off into standby mode and 2 - 4 mins later he heard 4 - 5 pops.
                        • Andrew F. Ali
                          • Jan 2014
                          • 2450
                          • Trinidad & Tobago
                          #32
                          I would replace the FSL206MR. to start with.
                          • Amraks
                            • Nov 2011
                            • 725
                            replaced all these components tv is powering up and shutting down properly.
                            • Amraks
                              • Nov 2011
                              • 725
                              Hey Ended up with another one of these Sets again in fact this one been here twice but none of the above on what I have fixed in the past.
                              Previous fault was it would turn off back light once it had a channel or input.
                              I fixed this by resetting tv holding vol - ch + while powering on lasted a few months.
                              New fault
                              will flash loading logo and then it will switch off back lights
                              Here are the voltages
                              1. 23.90v
                              2. 23.90v
                              3. 0v Gnd
                              4. 23.90v
                              5. 0v Gnd
                              6. 0v Gnd
                              7. 3.25v STB
                              8. 0V A_DIM
                              9. 0v Gnd
                              10. 0v P_On
                              11. 0.895v P_Dim
                              12. 3.26V BL_On
                              Are we looking at dead backlights this time?
                                Are you sure P_ON is 0V?
                                BTW, can we see the pictures of the whole backside of the TV showing all the board?
                                • Amraks
                                  • Nov 2011
                                  • 725
                                  Hey Budm hope all is well.
                                  (P_ON is mV plugged in and unplugged) disregard metering error.
                                  • Amraks
                                    • Nov 2011
                                    • 725
                                    Here are the photos you requested
                                    • Amraks
                                      • Nov 2011
                                      • 725
                                      Hey There P_On is at 3.2v
                                      Just tried my other meter the probe was a bit more fatter and made contact with the pin.
                                        OK.
                                        The P-DIM is <1V, so check the Voltage on the P-DIM aging when turning on the TV to see how high it jumps up to and then wait 5 seconds to see what it settle down to.
                                        Your pictures are not clear, I need to see the pictures of the LED driver board since we need to do some Voltage testing on that LED driver board too.
                                        • Amraks
                                          • Nov 2011
                                          • 725
                                          P_dim jumps to 4.94v
                                            ASUS P5GC-MX motherboard recap
                                            by momaka
                                            Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                            This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                            So here is what the motherboard looked like with its original caps:
                                            CPU VRM area up close…...
                                            01-27-2021, 11:59 PM
                                          • Sparklingx
                                            HP 450 g1 keeps turning on even tho shutdown/sleep
                                            by Sparklingx
                                            HP 450 g1 keeps turning on even tho I shutdown/sleep . one way to stop the turning on cycle is pressing the power button few seconds thus force powering it off. But then sometimes it does not turn on at all but next day I try again to turn it on and it turns on....
                                            09-23-2024, 12:34 AM
                                          • khelane
                                            Satellite PRO A50-A Not turning on after turning off Windows
                                            by khelane
                                            Hello
                                            A device with specifications
                                            Toshiba Satellite PRO A50-A is here to replace the hard drive.
                                            The hard drive has been replaced and there is no problem, but there is another problem, but the customer does not care to fix the problem.
                                            The device enters Windows without any problem and works, even I put pressure on the CPU and graphics, but when I turn off the system through Windows, if I want to turn it on again, the system switches, but it turns off quickly within a second, and this routine continues. It is turning on and off within a second and soon it turns off....
                                            04-20-2023, 06:28 AM
                                          • Rabit
                                            VX3276-2K-mhd-2 Random Turning off
                                            by Rabit
                                            Recently staring turning off more often, brightens set at 50% - monitor back side in PSU area is very warm to touch, also at front left corner getting hot.
                                            When changed brightens set at 30% no longer turning off , and no longer I can feel any heat in this areas.
                                            This can be signs of bad capacitors causing overheating PSU ?
                                            06-17-2024, 09:30 AM
                                            no-name Radeon 9600 XT recap and cooler
                                            by momaka
                                            I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                                            This one was actually suggested to me by ChaosLegionnaire....
                                            11-06-2020, 07:54 PM
