Satellite PRO A50-A Not turning on after turning off Windows
  • khelane
    • Apr 2015
    • 172
    • xxxx
    Hello
    A device with specifications
    Toshiba Satellite PRO A50-A is here to replace the hard drive.
    The hard drive has been replaced and there is no problem, but there is another problem, but the customer does not care to fix the problem.
    The device enters Windows without any problem and works, even I put pressure on the CPU and graphics, but when I turn off the system through Windows, if I want to turn it on again, the system switches, but it turns off quickly within a second, and this routine continues. It is turning on and off within a second and soon it turns off. This routine continues until I remove the main battery of the device and put it back.
    The battery has also been tested and the system works without any problems for the first time, but as soon as I turn it off in Windows, it won't switch until I remove the adapter from the socket and reconnect it. It does not assume the time of connecting and disconnecting the charger, that is, after the shutdown in Windows and the system not turning on, I disconnected and connected the charger within one second, the system was easily switched and entered Windows!
    It was tested with another charger and another battery.
    The backup battery was also replaced.
    BIOS was programmed.
    In the BIOS, if I press the switch button and the system shuts down. It turns on without any problem, but as soon as I turn it off in Windows, the system does not boot and turns on and off within a second. I disconnect and connect the charger for a second, switch the system, it goes into Windows easily
    I tested inside mini windows and it has the same problem.
    I did not find a map of this device
    Even now, the customer does not want to repair it, I just asked for my own knowledge, what is the cause of this defect. I doubted the RTC part myself, but I didn't have a plan for this model, I will go ahead according to it, only the battery has a 3.3 voltage, along with the 3.3 battery itself, then it goes into a 5-pin AC and to several other places.
    Unfortunately, the customer was in a hurry and the device should be delivered in a few hours, otherwise I wanted to repair it for free, just to find the fault.
    I would appreciate it if you could guide me on which parts of the system I should choose for troubleshooting
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Satellite PRO A50-A Not turning on after turning off Windows
    This has nothing to do with RTC circuit. The fault is in charging/discharging circuit. Most likely one of RBFET/ACFET is leaky.
    • khelane
      • Apr 2015
      • 172
      • xxxx
      thankful
      • coasterghost
        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
        by coasterghost
        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
        System Hardware:
        Processor: AMD Ryzen 7 PRO 5850U
        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
        09-08-2025, 10:46 PM
      • zioricci
        Toshiba Satellite P855 charger disabled after a while
        by zioricci
        after a little operating time of my Toshiba laptop, ranging from about 20 to 45 minutes, the Power light goes off, the power supply switches from the charger to the battery and in fact the voltage of both gates of the 2 initial mosfets are at 0V so the 19V does not reach the PL201 inductor and the power comes only from the battery.
        However, when i close the cover to turn off the laptop, the charger starts working again, charges the battery and the Power light turns on in amber color but after about 20 minutes the charger is disabled and the power light...
        05-05-2023, 02:34 PM
      • Prott
        Surface Pro 7 - turning off briefly, then charger cutting off
        by Prott
        can somebody, please, help me diagnosing and issue regarding SP7? This machine is killing me
        Once I plug it into the charger and press the button it turns on and immediately off due to the charger cutting off power.
        I measured all the voltages / signals and it seems to get through the power on sequence into an S0 state with all voltages and signals present (it even goes as far as to display the Microsoft logo and starts reading from the bios), however after around 100 ms the charger cuts off the power.
        I checked the charger and it seems...
        03-15-2023, 05:10 PM
      • japlytic
        DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
        by japlytic
        In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
        Tried (only with keyboard/mouse connected):
        • BIOS + database update
        • Using latest Windows 11 image built with official image creation tool
        • Previous setup version for Windows 11 installer
        • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
        • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
        • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
        06-19-2025, 04:59 PM
      • BOSCHNJAK
        by BOSCHNJAK
        ABOUT ME INTRODUCTION FILE
        2
        024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
        2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
        2022 BEV, PROJECT ?
        2021 BEV, PROJECT ?
        2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
        2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
        12-28-2023, 02:09 PM
