Vizio D48-D0 10241020222, backlight ON, no picture, new boards
  • joeblah
    • Apr 2016
    • 65
    Hello all,
    Have a Vizio D48-D0, 10241020222. S/N starts with LAUSTWBS.
    The TV powers on, backlights present, no picture (not sure if this TV makes a sound on power up, but no sound heard). No special blinking LED code on front panel. At power up, the backlights look bright, then for about a second, the backlights go out, then they come back on, but look a bit dimmer than they did at power up (no picture throughout that process).
    The power board is a 0500-0605-0940. The main board is a 3648-0202-0395. ShopJimmy sold both boards for $50 total, so I ordered SJ-KIT-D48-D0-K1. Received the boards, listing said compatible with S/N LAUSTWBS, but the main board bar code had a slight difference. The original main board was 3648-0202-0150(3B), but the board from ShopJimmy is a 3648-0202-0150(3D). May that be the problem?
    I removed the old boards and put in the new kit from SJ. Here are the pin readings:
    NEW MAIN BOARD AND NEW POWER BOARD:
    CN301: LED1+: Pin 1: 63.7VDC
    CN301: LED1-: Pin 2: 1.8VDC
    CN301: LED2+: Pin 3: 63.7VDC
    CN301: LED2-: Pin 4: 1.8VDC
    CN301: LED3+: Pin 5: 63.7VDC
    CN301: LED3-: Pin 6: 1.8VDC
    CN301: LED4+: Pin 7: 63.7VDC
    CN301: LED4-: Pin 8: 1.8VDC
    CN301: LED5+: Pin 9: 63.7VDC
    CN301: LED5-: Pin 10: 1.8VDC
    CN201: PWM5: Pin 14: 3.3VDC
    CN201: PWM4: Pin 13: 3.3VDC
    CN201: PWM3: Pin 12: 3.3VDC
    CN201: PWM2: Pin 11: 3.3VDC
    CN201: PWM1: Pin 10: 3.3VDC
    CN201: Boost LED current: Pin 09: 0
    CN201: Backlight: Pin 08: 3.3VDC
    CN201: PS-ON: Pin 07: 3.3VDC
    CN201: GND: Pin 06: 0
    CN201: GND: Pin 05: 0
    CN201: GND: Pin 04: 0
    CN201: +18Vsb: Pin 03: 18VDC
    CN201: +18Vsb: Pin 02: 18VDC
    CN201: +18Vsb: Pin 01: 18VDC
    Here are the readings from the old boards:
    OLD MAIN BOARD AND OLD POWER BOARD:
    CN301: LED1+: Pin 1: 64VDC
    CN301: LED1-: Pin 2: 10VDC
    CN301: LED2+: Pin 3: 64VDC
    CN301: LED2-: Pin 4: 10VDC
    CN301: LED3+: Pin 5: 64VDC
    CN301: LED3-: Pin 6: 10VDC
    CN301: LED4+: Pin 7: 64VDC
    CN301: LED4-: Pin 8: 10VDC
    CN301: LED5+: Pin 9: 64VDC
    CN301: LED5-: Pin 10: 10VDC
    CN201: PWM5: Pin 14: 1.6VDC
    CN201: PWM4: Pin 13: 1.6VDC
    CN201: PWM3: Pin 12: 1.6VDC
    CN201: PWM2: Pin 11: 1.6VDC
    CN201: PWM1: Pin 10: 1.6VDC
    CN201: Boost LED current: Pin 09: 11mV
    LED issue? Part discrepancy between the (3B) and (3D)? My headache meter is pegged. I can't remember SJ ever sending me a bad/incompatible part.
    Any suggestions would be greatly appreciated!
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Vizio D48-D0 10241020222, backlight ON, no picture, new boards
    T-con? What was your original problem?
    • joeblah
      • Apr 2016
      • 65
      I thought t-con too, however, there is no t-con (unless it's hidden really well). Original problem is same as current problem.
      • xeroextre
        • May 2013
        • 13
        The part number stops before the parenthesis, anything after that is factory info and not relevant. The 12 digit part number (3648-0202-0150) is the same on both boards so it's the same part.
        So you have the same issue now as you did originally, no video WITH backlight on, it's highly likely that the display panel is bad since this model has no T-CON, and you've already swapped out the main board. The LED strips are working since they are on as you stated earlier. There's a small chance the main board we sent is defective, I'd say 10% or less.
        Keith M.
        (Technician at ShopJimmy)
          The panel has integrated T-CON so there should be a SMD fuse the long board of the panel that you need to find out if it is getting the switched 12v to both ends of the fuse or not.
          BTW, what is the LCD panel model number?
          • joeblah
            • Apr 2016
            • 65
            Keith M.
            Ah, okay, thanks Keith.
            • joeblah
              • Apr 2016
              • 65
              Thanks, bud. I have 12.5VDC on both sides of the SMD fuse you mentioned. Not sure about the LCD panel number. Attached are some pictures, but I Google'd all the numbers and didn't find anything helpful.
              15Y_R48FF11MB7S4LV0.2
              U33341E5K16ML
              LSC480HN08
              CS160109D
              1813-0302-2011
              1713-0302-2010
              MV-0SE88441
              D99S3
              • Hamie
                • Apr 2014
                • 1383
                There are various test points on the board.
                Avdd_17v (obviously should be 17v)
                3.3v ( same as above.
                Then look for other points like sda, vgl, vone, voffe.
                post results of all the test points you can see.
                • Hamie
                  • Apr 2014
                  • 1383
                  PS, either I'm blind or just completely looking at this the wrong way.... But where are the COF that connect to the panel?
                  • joeblah
                    • Apr 2016
                    • 65
                    Hey Hamie, thanks for the info. Here are some better pictures and measurements:
                    AVDD_17V: 172mV
                    VCC: 3.3V
                    VOFF_-11V: 110mV
                    ATD_MON_T: 1.7V
                    ATD_MON_D: 13mV
                    VCC_1.8: 1.8V
                    WP: 3.3V
                    SCL: 3.3V
                    SDA: 3.3V
                    MON_L: 334mV
                    MON_R: 334mV
                    All of the other test points ranged from 10mV-340mV.
                    • Hamie
                      • Apr 2014
                      • 1383
                      OK so you have a problem somewhere.
                      I'd check all the smd caps and see if any are shorted.
                      • joeblah
                        • Apr 2016
                        • 65
                        Hamie, most of the SMD caps on that particular board are open, a few in close proximity to each other measure ~1kΩ. That was done in-circuit, though.
                          https://www.badcaps.net/forum/attach...9&d=1487372049
                          See those two ICs with two small inductors with '100', '220' on tops?
                          Those IC are part of switching power supplies that generate VGH, VGL, etc.
                          Get the P/N and look up the spec sheets so you can see if they are generating the Voltages or not.
                          Example:
                          http://tvrepairsolution.blogspot.com...lcd-panel.html
                          • draxsin
                            • Jul 2018
                            I'm having a similar issue with this board. I just replaced the main board on a Vizio D48N-80 which restored functionality to the TV. The output is distorted though. The same board discussed here is used in this TV. I found that one of the small inductors labeled 220 is shorted to ground on the board that has been discussed on here. I can't find a replacement board so I need to attempt a component level repair.
                            Thank you
                            • gmandman
                              • Dec 2018
                              Tried to find a proper place to post this question but could not - I have a Vizio D48-D0 with no power. Replaced the power supply board, nada. Looking to replace the main board - cheap enuff on ebay. Anyone know if you can sub a 3648-0202-0150(3E) for a 3648-0202-0150(3B)?
                                • 12179
                                • U.S.
                                  • 12179
                                  • U.S.
                                  See if thats a match, on left in red it says works with starting serial nos. your number is there, you can call them to verify. https://www.shopjimmy.com/vizio-3648...0-laustwbr.htm
                                    • 12179
                                    • U.S.
                                    Both boards there for 50 bucks. https://www.shopjimmy.com/vizio-d48-...-version-1.htm
                                      • 12179
                                      • U.S.
                                      Plenty there from 13.50 on up. https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
                                      • bscottjohnston
                                        D48-D0 flickering/flashing at a very constant rate
                                        by bscottjohnston
                                        I have a D48-D0 that works on all counts except the backlights flash at a constant frequency of about 3-4 times a second. I used the Voltage measurements as seen in this thread (https://www.badcaps.net/forum/troubl...ure-new-boards) to compare mine.
                                        With CN301 unplugged with set on I have about 90VDC
                                        With CN301 plugged in of course the V varies based on the flickering
                                        These pins have 1.86 VDC not the 3.3 as shown here:
                                        CN201:...
                                        12-08-2023, 06:29 PM
                                      • armini
                                        18VDC PSU completely dead - ZD-915 desoldering station
                                        by armini
                                        Hi everyone!
                                        Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
                                        Due to a lack of time, I set it aside and didn't look at it.
                                        Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
                                        According to replies in 18VDC PSU has dropped to...
                                        04-25-2023, 07:49 AM
                                      • DXseekerMO
                                        Vizio E48-D0 Backlight flash, backlights/connections confirmed good.
                                        by DXseekerMO
                                        Hello everyone, I've had this TV for almost 6 months now, just sitting in the fix-it room and it would be great to get this finished up.
                                        It sounds like the typical Vizio complaint….hit the power button, backlights flash, image on screen but no picture with sound…so what do I do? Order backlights from SJ without taking a single voltage reading. Apparently my “jaundiced eye” over-rode my need to do a diagnostic. This was a mistake.
                                        Install SJ backlights….problem still exists. Check all connections and connectors….no happy. When the backlights flash…they...
                                        03-03-2020, 10:32 PM
                                      • 1crow1
                                        Vizio E601i-A3 backlight issue
                                        by 1crow1
                                        When I turn on the TV the backlights flash on for a second and go out, I get the Vizio logo on screen for that short time. It passes the flashlight test.
                                        Will a bad backlight cause this shutdown or should I be looking at the power board.
                                        CN301 CONNECTOR
                                        Readings as follows
                                        VLED1-1+ 125 volts then drops to 0
                                        VLED1-1- 0 volts
                                        VLED1-2+ 0 volts
                                        VLED1-2- 109 VOLTS THEN DROPS TOO 0
                                        VLED2-1+ 105 volts then drops to 0
                                        VLED2-1- 0 volts
                                        VLED2-2+ 0 volts
                                        VLED2-2- 130 volts then drops to 0
                                        CN201 reading seem...
                                        03-22-2023, 07:11 AM
                                      • paqman
                                        Vizio M60-C3 black screen
                                        by paqman
                                        So our beloved M60-C3 up and died the other day. I was not there, my wife mentioned that it came on, displayed the logo, then showed the right half of the screen white and fuzzy, with the left half of the screen ok. However when I got around to looking at it, the screen would not come on at all. The indicator LED will come on, then dim a bit. After a while, the LED might blink a bunch of times. I can't get it to be consistent to do that.
                                        So I've got the back off and am checking voltages. The capacitors on the power supply board visually check out. No bulges or anything. They all show...
                                        03-02-2024, 04:37 PM
