Vizio E601i-A3 backlight issue
  • 1crow1
    • Feb 2023
    • 5
    When I turn on the TV the backlights flash on for a second and go out, I get the Vizio logo on screen for that short time. It passes the flashlight test.
    Will a bad backlight cause this shutdown or should I be looking at the power board.
    CN301 CONNECTOR
    Readings as follows
    VLED1-1+ 125 volts then drops to 0
    VLED1-1- 0 volts
    VLED1-2+ 0 volts
    VLED1-2- 109 VOLTS THEN DROPS TOO 0
    VLED2-1+ 105 volts then drops to 0
    VLED2-1- 0 volts
    VLED2-2+ 0 volts
    VLED2-2- 130 volts then drops to 0
    CN201 reading seem right, will post if needed.
    Looking online at replacement boards I see near connector CN301, i'm guessing these are
    high voltage safety capacitors ??. There are 4 near the connector and 2 more behind them.
    I see some used boards with yellow ones, with numbers F105k 450mpb. On mine they are
    black with or gray with MPHB 105k.Could the yellow ones be an improved version and could
    these posssibly be the problem?
  • nomoresonys
    • 12328
    • U.S.
    Re: Vizio E601i-A3 backlight issue
    Prolly bad backlights, unhook backlight connector from powerboard and check those VLED pins on powerboard.
    • 1crow1
      • Feb 2023
      • 5
      The measurements are posted above. Will a bad led, not the whole strip shut it down?
      • nomoresonys
        • 12328
        • U.S.
        Yes, plus that symptom is very common when bad backlight/s or backlight connection, there's ways to test them, I think I would tear it down to get a better look at them and see if they all light up the same and maybe test them individually if needed. Must be VERY CAREFUL tho, the screens are very flimsy and easy to break. Check out some youtube videos, there's a bunch on vizios, hardest part is getting the screen off and reassembled without breaking/cracking it.
        • nomoresonys
          • 12328
          • U.S.
          Maybe to be sure and cover everything before tearing it down, do the testing in this link, I think this tv has a similar powerboard, I would do the tests and be sure to do the stand alone powerboard and backlight test that Budm describes: https://www.badcaps.net/forum/showthread.php?t=79224
          • 1crow1
            • Feb 2023
            • 5
            Thanks, I'll look into that
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • bajdik
              Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
              by bajdik
              I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
              Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
              I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
              Unfortunately, I don’t have access to the schematic.
              It seems to me that when I bend the board, something changes.
              Could this...
              08-13-2025, 07:26 AM
            • Mectronik
              Vizio m601d-a3 backlight issue
              by Mectronik
              Hello, I'm working on a Vizio m601d-a3 with a backlight issue that I am having a difficulty diagnosing it. As it sits, the tv powers on, displays the Vizio symbol and with nothing hooked up it will then display no signal but you can only see half of the screen. I know it's a back light issue because the picture is there without light behind it, as I can see it by doing a light test. I've taken off the paneling and done a visual inspection. If I disconnect the tcon ribbon cable to the affected side then the entire half of the screen goes away. I've checked voltages at the LED driver from the main...
              11-05-2023, 10:20 PM
            • EazyBone
              Vizio P759-G1, Tcon issue?
              by EazyBone
              Got this TV free. Guy said it tries to turn on and doesn't. I haven't seen this specific issue before but shown in video. Any way to test the screen to rule it out on these Vizio? Or anyone seen this issue before?
              Any help appreciated
              https://youtu.be/tPeV2Q7TXIQ?feature=shared
              03-22-2024, 03:25 PM
            • remmurdmd
              Vizio E65-E1 strange image issue
              by remmurdmd
              Hi everyone. First new thread here. I picked up a TV on the side of the road. It appears to function correctly with the exception of an image issue I'm unable to describe. I've searched for “double picture” and “double image” all over the web and all I get is repair videos for when the picture is blurry and the connections are getting interference between the display panels and the t-con board. I believe this is a t-con board issue, but I haven't found anything telling me conclusively that this is where my issue is. I'd appreciate any assistance you can provide. I live a pretty busy life...
              10-02-2022, 09:12 PM
