Philips 47PFL7403D/10
  • vazaki
    • Jan 2017
    • 21
    • Greece
    Re: Philips 47PFL7403D/10
    Here are the other pics.
    R5 has been changed and burnt again. Its value is 120Ω 1W
    U101 is freezed as dick_barton have correctly noticed on earlier post
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4465
      • Italy - Milan
      With only a picture you could be helped only by a knowledged man about this model..
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        Is it just me or does the soldering on these parts look bad?
        D232
        D232a
        Q231
        D230
        Pc102
        Pc201
        D106a
          Is this the same board?
          http://www.shopjimmy.com/philips-272...pply-unit.htm#
          Philips 272217100571 (2300KEG033A-F) Power Supply Unit.
          MFR Part Number 1: Philips 272217100571
          Board Number(s): 2300KEG033A-F, PLHL-T722A 2722, 171 00571
          Substitute Parts: 272217152611, 272217100571 Repair Kit
          R5 is used to supply B+ (rectifiers D101A~D) to run the standby SMSP IC U101, once the TV is power sup, the B+ will be then supplied by the main power supply through D160, 160A., once the main power supply relays are on then R5 is no longer in use, if B+ through D160,160A is not present and the main board will try to pull full current from STBY supply, then R5 will burn up, that R5 is used just enough to supply enough current to run the main board through R5, once full power is required, R5 is no longer used in the circuit due to reverse bias of D101A~D.
          So something is drawing too much current through R5 and causes it to burn up, U101 is one of the load.
          The RCD snubber for the U101 is OK? The rectifiers D111 in the cold side is OK? D101A~D, D160, 160A OK?
          • vazaki
            • Jan 2017
            • 21
            • Greece
            Thank you Budm.!
            The part number of the board is exactly the same as you mentioned.
            Board number is PLHC-T801A(UD)
            Does Philips sell repair kits for this board? (272217152611, 272217100571).
            D101A~D have been replaced. D160 & D160A are good.
            Also there have been replaced:
            > D111
            >Pc201
            >Pc102 & 101.
            After all these, relay clicking and after a minute again R5 is blown again.
            Snubber you mean GR8? the small transformer?
            If you mean the transformer I checked it with blue ring tester. Primary is fine but secondary is bad. Is it a problem?
            • vazaki
              • Jan 2017
              • 21
              • Greece
              #26
              D232
              D232a
              Q231
              D230
              Pc102
              Pc201
              D106a
              Thanks for your post!
              Checked again! All are fine.
              D232 D232A D230 & Q231 are desoldered for checking purposes!
              • dskall
                • Oct 2016
                • 2905
                • usa
                #27
                I would try removing transformer and see if you still have problem. Whichever U101 is driving.
                  RCD snubber;
                  D106A
                  R104
                  Blue disc cap C120?? next to R104.
                  • vazaki
                    • Jan 2017
                    • 21
                    • Greece
                    #29
                    Checked the c120 it should be 10nf but I measure 5,5nf.
                    I will try to desolder the transformer and measure it again.
                    To give circuit a try I have to reorder again U101
                    What about d106a? The type of this diode is T2D 83. Checking with multimeter is seems open both sides. Is it normal situation? I tried finding specs but i didnt find anything. Is it a high voltage diode?
                      It is back to back diode so you cannot test it with your meter.https://www.badcaps.net/forum/showthread.php?t=43724
                      • vazaki
                        • Jan 2017
                        • 21
                        • Greece
                        #31
                        The small transformer is desoldered.
                        In the primary it has two windings. Both tested with blue ring meter and both are good.
                        The secondary has one winding, tested but according to blue ring meter it is bad.
                        Is it possible? The transformer seems in very good condition without signs of burnt or smell.
                        Any opinions?
                        • vazaki
                          • Jan 2017
                          • 21
                          • Greece
                          #32
                          Another photo
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4465
                            • Italy - Milan
                            #33
                            It's a very strange circuit for me.. why there is an auxiliary output of main transformer T201 that feeds st.by psu togheter with supply from PFC-out??
                            • vazaki
                              • Jan 2017
                              • 21
                              • Greece
                              #34
                              Philips TVs are very crotchety.
                              Do you know where I can buy such transformer?
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4465
                                • Italy - Milan
                                #35
                                I don't know, but i'm not sure about the value of R5, if the fourth band would be yellow and the third purple it was 1,27M but it would be strange for the use, if the fourth would be gold the value is not 120ohm but 12,7ohm or 12ohm (third black)... i expect very rarely the transformer going bad.. whatch shopjimmy picture, it has 5 bands.. i don't even know why this resistor is there..!! But i'm not expert.. finally, i've already seen resistors with band with a strange gold colour..
                                • dskall
                                  • Oct 2016
                                  • 2905
                                  • usa
                                  #36
                                  Try powering it up without transformer thru light bulb for fuse see if board is still shorted. What is resistance of secondary?
                                  • vazaki
                                    • Jan 2017
                                    • 21
                                    • Greece
                                    #37
                                    The secondary of the transformer is zero ohms. I have tested it with blue ring tester and it looks bad.
                                    I have to order again fsq510 to test it with light buld.
                                    • vazaki
                                      • Jan 2017
                                      • 21
                                      • Greece
                                      #38
                                      R5 color code is Green, yellow, brown, red, brown. I have found a pic on the net. Possibly we are talking about a protective circuit resistance.
                                      I agree with you about transformers gooing bad but is this an exception?
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4465
                                        • Italy - Milan
                                        #39
                                        About R5: since the most outer band is green, the first to count is the brown, please watch shopjimmy picture, the R104 near the little transformer T101, seems to have 2 types of yellow, like many other circuits i've found, i think the darker one is a yellow that stands for gold, so you have brown, red, brown, gold, green then 12,1ohm. Start from this.. why R5 blew i don't know..
                                        • vazaki
                                          • Jan 2017
                                          • 21
                                          • Greece
                                          #40
                                          Thanks David
                                          I checked the circuit and I noticed that also R4 and R2 has the same colors. I desolder one of these and I measured 120Ω.
                                          It is very strange thing about the color code they use for these resistors.
                                          • alro7779
                                            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                            by alro7779
                                            Hello, guys!
                                            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                            09-14-2025, 12:25 AM
                                          • zen
                                            GC9660 Philips iron advice please
                                            by zen
                                            Full model GC9660/36/BI
                                            Hi all, this iron intermittently not producing steam.
                                            Anyone have experience working on them?...
                                            11-07-2022, 04:32 AM
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
                                          • double_DD
                                            Philips curling iron - is this a common AC cable?
                                            by double_DD
                                            Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                            As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                            Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                            08-18-2025, 10:04 AM
                                          • janos6662000
                                            Philips 47PFS7509/12 LCD TV problem
                                            by janos6662000
                                            Hi
                                            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                            When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                            I downloaded original firmware and applied the update, but the problem remained.
                                            From a colleague i received a "factory package software" which is a lot bigger.
                                            I made another firmware update, but still did not solve the problem.
                                            Somewhere on the way the error got worse, because at the moment the...
                                            08-12-2025, 12:54 PM
