Element ELEFW40C won't turn on.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    #121
    Re: Element ELEFW40C won't turn on.
    Yeah, I'll run it by them once I pull the flash chip and see if I can dump it, just in case it's bad, although I doubt it is.
    I've learned a lot while working on this particular board and that's good. With this board, it's a problem I haven't ran into before and I think that's when we learn the most, when we do something we're not comfortable at.
    Anyway, I thought this might be a good time to try out my newly acquired slightly used Agilent 16702B Logic Analyzer. I want to see if I can see the commands going to and from that 25Q16BSIG. I'm reading up on how to use it. It could be a fun experiment, while I'm waiting for stuff to arrive in the mail. I can't contact the customer until after 5:00PM, so I have a little bit of time to experiment with it. I don't know if my logic analyzer is too old though, it might not be able to read it. It might still be worth trying, because then I'll learn something about it, I'm sure.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    • vinceroger69
      • Mar 2012
      • 6714
      #122
      would be good too i guess if customer goes for a replacement board as if eeprom/spi flash is bad you can get a good dump of the working board and maybe also repair faulty board if thats what is at fault.i It does not help that we cant find a schematic for this psu i have been looking too but no luck as yet.
      • Spork Schivago
        • Mar 2012
        • 4734
        #123
        For my Agilent 16702B logic analyzer, I have two state and timing modules. One is the 16740A and the other is the 16717A
        16740A: http://www.keysight.com/en/pd-100000...e?cc=US&lc=eng
        16717A: http://www.keysight.com/en/pd-100000...e?cc=US&lc=eng
        I wonder if either of these would be good enough to see the information on the bus there. It's definitely a new learning experience trying to do this.
        I'm working on acquiring a 16760A State Timing Analyzer Module. It'd be nice if I could snag on them fairly cheap like.
        • Spork Schivago
          • Mar 2012
          • 4734
          #124
          Should there be a clock signal going to that 8-pin chip that contains the firmware? If so, there's not. I would think that should be receiving a clock input as soon as the TVs powered on. Isn't that 8-pin chip the thing that controls the television?
          • Agent24
            I see dead caps
            • Oct 2007
            • 4953
            • New Zealand
            #125
            Yes, it will have a clock pin. Look up the EEPROM datasheet.
            No, the EEPROM Chip doesn't control the TV. It just contains some data which gets loaded. It's like the BIOS EEPROM on a motherboard, basically.
            It will receive a clock signal to read the contents when the microcontroller requests it, somewhere early on in the startup sequence I expect. If you get no clock signal (be sure you didn't just miss it, or something) the micro is probably not outputting one. Either it's bad, or it's halting somewhere in the startup sequence before it even tries to read the EEPROM.
            If that is the case, then the microcontroller could be being held in reset by a faulty reset circuit, bad voltage supply, maybe broken main crystal oscillator...
            If you can find the reset pin of the micro, check that that's working normally. Check that the main crystal is running. Check the voltages for the micro are clean and in spec.
            -David VanHorn
            • Spork Schivago
              • Mar 2012
              • 4734
              #126
              I think you misunderstood. I know it has a clock pin. I'm saying there's no clock pulse on that pin. It's 0.000VDC.
              I will throw my oscilloscope on it tomorrow, but I setup my logic analyzer and believe I did everything correctly. This was my first attempt at using it, but I followed directions and read a lot today. I'm pretty sure I did it right. There was nothing there. Could you give an example of what content would generally be on the EEPROM? Is it stuff like the character chart for various text that appear in the menus, perhaps the menus themselves? I was looking at it like a PC BIOS, which is responsible for initializing the various hardware, the various BIOSes on that hardware, and executing the code at sector 0 of the hard drive to start the OS.
              Okay, I need you to back her up for a second. When you say micro, you're not talking about the flash chip anymore, right? You're talking about the central processing unit of the television (or the TV's equivalent of a CPU), is that correct?
              To check that the x-tal is running, how would I do that? Just use my scope? Put a probe on one of the pins and see if anything shows? If I don't know which settings to put the scope on, is it safe to just play around with it a bit? I still have a bit of learning to do with it, but I've used it successfully now a few times. I even used it to help troubleshoot a car not too long ago.
              There's more than one x-tal usually, if I remember correctly. I'll check both.
              Could you or someone else give me a basic block diagram of a television startup? Something like TV gets power, CPU receives power and waits until the button's pressed. Maybe things will be easier if I fully understand how these things work. I'm going to read Budm's stickied post, I just found that a little bit ago, but it probably won't be for a couple more days. If that info is in there, I'll just read it from there.
                http://www.electronicrepairguide.com...r-circuit.html
                http://www.embedded.com/design/mcus-...tal-TV-design-
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  #128
                  There's a chance too that maybe the eeprom is fried. With the DMM (not the logic analyzer), these are the voltages I get, whether I pushed the on button or not.
                  Pin 1: 0.000VDC CS# -- Chip Select Input
                  Pin 2: 3.320VDC SO (IO1) -- Data Output (Data Input Output 1)
                  Pin 3: 3.320VDC WP# (IO2) -- Write Protect Input (Data Input Output 2)
                  Pin 4: 0.000VDC VSS -- Ground
                  Pin 5: 0.000VDC SI (IO0) -- Data Input (Data Input Output 0)
                  Pin 6: 0.000VDC SCLK -- Serial Clock Input
                  Pin 7: 3.321VDC HOLD# (IO3) -- Hold Input (Data Input Output 3)
                  Pin 8: 3.321VDC VCC -- Power Supply
                  So hold is high, write protect is high (unless it's being used as an IO pin), and SO is high. I've been studying the datasheet, earlier in the day, I believe a person sets what mode they want it in (dual, quad, single, etc) during burn time. I believe it's much like a PIC, where there's configuration bits that you set. So I don't really know for certain, for example, which pins are IO, because depending on the configuration bits, they can serve different purposes. Sometimes, ICs fail in such a way that they send voltage out pins that aren't supposed to have voltage. I'm wondering if that's what might be happening.
                  Do you think that's a possibility or should I be concentrating more on the possible reasons you gave?
                  Thanks!
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    #129
                    So they're just like my programmable interrupt controllers. I gotcha. And it's the microcontroller that has the instructions that control the television then? The microcontroller is what tells the power supply to start up, once someone hits the power button, it tells the back lighting circuit to kick on the back lights, etc, is that right?
                    I read that link you sent Budm. That's very informative. I should be checking to see if the TV's microcontroller is getting that RESET signal. From what I just read, if it doesn't get that, the TV won't turn on. I'm starting to think maybe it's a bad microcontroller or a corrupt eeprom. I'm assuming the reason tv's have eeproms, even though the microcontrollers generally have them built in is because the microcontrollers don't have large enough eeproms and the developers need more room than what the microcontrollers provide. Am I right in this?
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        #131
                        some very good information in this thread i have been reading the links budm has posted so learning what a eeprom/spi flash ic does also found on shopjimmy what issues they say a replacement eeprom ic may solve
                        IMPORTANT:
                        These main boards can have multiple failures, in addition to the EEPROM.
                        If EEPROM replacement does not repair your board, there are likely additional problems.
                        Symptoms EEPROM replacement MAY fix:
                        - On screen display is stuck on logo screen
                        - TV won’t power on with remote or buttons (LED indicator remains same color)
                        - TV won’t turn on after being off for 30+ minutes
                        - TV shuts off by itself during channel scan or when switching inputs
                        - TV turns on and is stuck in color test pattern mode forever
                        - TV turns on but there is no backlight (LED indicator shows TV is on but there is no image)
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          #132
                          IMPORTANT:
                          - TV won't power on with remote or buttons (LED indicator remains same color)
                          - TV won't turn on after being off for 30+ minutes
                          In the past, when I had a television to fix, I would just come here for help getting it fixed, but now I want to work on them for a living and I really want to understand how they all work. So when someone says test this diode, instead of just testing it, I want to know why we're testing it and what it's purpose is. I feel I've learned a lot in this one thread, probably more than I've learned in all my other ones.
                          • Spork Schivago
                            • Mar 2012
                            • 4734
                            #133
                            Even with the scope, there's nothing on the SCLK. I even verified the scope was working by using the test probe / calibration part of it. I get a square wave on the test probe / calibration hook but nothing on the SCLK pin. I'll try hooking the scope up to x-tal and see if I get anything.
                            So how do those crystals work? It's a 24.000MHz crystal. Voltage is supposed to go through on pin (or terminal) of the crystal and then a sine wave is supposed to be produced on the other pin? The material inside resonates, producing the pulses...is there a chance the crystal just isn't activated yet if there's no pulse coming out of it? I guess that wouldn't be hard to test. I can just check to see if voltage is going to one of the pins. I'm going to have to remove the board from the TV because I can only access the pins on the bottom side of the board. This can get tricky, because the cables might not be long enough for me to set the board on it's side vertically or something. I wonder if all the cables are needed for this test. The two that go to the backlighting for instance, I wonder if I can remove them for this test....
                            • Spork Schivago
                              • Mar 2012
                              • 4734
                              #134
                              I hooked up the scope to the crystal. I think I messed up though. I put the probe on one pin and hooked the grounding clamp on the other. When I went to change the VOLTS per division, I'd get shocked.
                              Maybe I'm supposed to hook the grounding clamp to the board where it'd normally be hooked to the chassis. Without the board being grounded though (I'm holding it with my hand), maybe this is why it's not working? I did not get a sine wave though. I got a really messed up looking screen.
                              • Spork Schivago
                                • Mar 2012
                                • 4734
                                #135
                                I found where the pins for the crystal connect on the top side of the board to the two SMD capacitors and resistor. Maybe I can take my measurement from the oscilloscope somewhere around that area on the top side of the board, so I don't have to hold the board while trying to test it.
                                **EDIT: I bought a replacement board off e-bay. I talked the guy down from 60.00$ to 40.00$. He accepted my offer. I'm hoping once I get the new board, if it does work, I can use it to figure out what's wrong with the old board, but if not, at least I'll be able to fix the television for the customer. Thanks for all the help.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4953
                                  • New Zealand
                                  #136
                                  In most cases, you put the ground clip on, well, ground.
                                  By connecting the crystal to the ground lead of the scope, you have in fact, connected it to mains earth. This is not what the circuit expects. It's probably why the display was messed up.
                                  It's probably also why you're getting shocked.
                                  You need the isolation transformer, really.
                                  -David VanHorn
                                  • Spork Schivago
                                    • Mar 2012
                                    • 4734
                                    #137
                                    I need the isolation transformer so when I make mistakes like this, I don't get hurt? Or I need the isolation transformer to properly test the crystal?
                                    Also, can you recommend a good isolation transformer that wouldn't need modification that I could use with my scope? Thanks!
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4953
                                      • New Zealand
                                      #138
                                      If the clock signal is fast enough and only present for a short time, a DMM may not show anything.
                                      Also, I think we need to see if there's any activity from complete power off, not just button press.
                                      What is the model number of this EEPROM? I haven't seen one before that has settable bits to change the operation behaviour. But I'm sure it's possible. It will still need a clock though, regardless of the mode it's in.
                                      I suppose it could be internally shorted although that kind of failure is more likely with power devices, and would be strange for an EEPROM. I think usually the problem is that some data cells become worn out\stuck and it loses its data in some way or gets corrupted by a 'dirty' power supply. (too much ripple, usually the result of bad capacitors)
                                      -David VanHorn
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 4953
                                        • New Zealand
                                        #139
                                        Yes, the microcontroller will generally send an enable signal to the PSU to take it out of standby, send an enable signal to the inverter\LED driver etc.
                                        If it's not running because it's got problems, or it's halting because it's receiving bad\no data from the EEPROM, it won't get to the point to tell the backlights or panel etc to turn on.
                                        Yes, size is one reason for using external EEPROMs with microcontrollers. I'm not 100% sure the exact reason in TVs in general though.
                                        -David VanHorn
                                        • dick_barton
                                          • Aug 2015
                                          • 6642
                                          • Wales
                                          #140
                                          If you're measuring a crystal on the main board which is cold side of the circuit, I cannot see how you would receive a shock. Use you multimeter and check what ac or dc voltage you have between those two points.
                                          It is good practice to isolate any set you are working on from the mains using an isolation transformer. Cheaper than a funeral.
                                          You are highly unlikely to measure the oscillation of a crystal by direct connection using your oscilloscope due to the impedance and capacitance the scope probe places on the crystal when you connect to it. This is not always the case but it is generally true for high frequency crystals.
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                          • robante15
                                            Acer Aspire 4520 won't turn on after reboot
                                            by robante15
                                            Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                            It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                            The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                            If I remove the...
                                            04-06-2024, 06:50 PM
                                          • masoksian
                                            Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                            by masoksian
                                            I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                            The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                            The system does not turn on, there is no post.
                                            I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                            The problem continues in the same way.
                                            I tried to turn on the Fn key, nothing came to the screen....
                                            02-15-2025, 12:08 PM
                                          • dqtech
                                            lenovo x240 nm-a091 wont turn on
                                            by dqtech
                                            i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                                            board number VIUX1 NM-A091 REV:1.0...
                                            02-07-2024, 01:57 AM
