Element ELEFW40C won't turn on.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    #181
    Re: Element ELEFW40C won't turn on.
    Here's a good video that goes into the differential probes.
    https://youtu.be/RDLWQFgJ1uU
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    • Spork Schivago
      • Mar 2012
      • 4734
      #182
      I got the replacement board today and it works fine.
      I went through and recorded all the values on the good board for the transistors on the non-power supply part of the board. I'm going to switch out the good board with the bad board and see if the values are all the same. I'm hoping I find a bad transistor, then I can repair the broken board and maybe sell it to get some money back.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #183
        Glad a replacement board has got the set working and yes its a good idea hopefully you can find the issue.
        • Spork Schivago
          • Mar 2012
          • 4734
          #184
          Okay, so like I said, I took measurements of all the transistors on the working board. Then I went and checked on the bad board.
          There's one on the good board that has all 0.0000VDC on all three pins. I don't think it's active yet. But on the bad board, one of those pins doesn't read 0.0000VDC at all. It's in the millivolts range, but keeps climbing and climbing and climbing. Last I checked, it was around 80mv.
          Then, there's one on the good board that has 5.17V on the input and the output is 30mv, but on the bad board, it's got the 5.17V (or around there), but only 8mv on the output. Would that be a bad transistor? I'll go check the rest of them.
          • martino
            Not so "senior"
            • Aug 2013
            • 997
            • canada
            #185
            Would love to see the eeprom from the good board swapped onto the bad board for a sec to see results.
            Proud owner of dozens of broken TV's and many,many,many boards.
            Our website and passion:http://hollenhundshepherds.com/
            • Spork Schivago
              • Mar 2012
              • 4734
              #186
              I'm sorry, I ended up just giving the TV back. I got tired of having it around, but I still have the bad board. If you'd like, I can pull that eeprom and try dumping it, now that I have a CH341A spi / eeprom reader / writer.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5095
                • New Zealand
                #187
                Originally posted by Spork Schivago
                So, I'm watching the video. I notice something that strikes me a bit odd. He doesn't have a square wave, but it's fairly close to one. When I put a square wave on my scope, I only see the top and bottom horizontal bars, I don't see the vertical bars. Is this normal for some scopes or does mine need some work?
                It is normal for a CRO. They will show up on a DSO though, which is what he has.
                I have a waveform generator. All the signals show on the scope, except one. That signal is all messed up. That means there's either something wrong with my scope or something wrong with the waveform generator. I'm leaning towards the waveform generator, because it's really old but the other signals work just fine. Maybe I should recap that as well and see if it fixes anything.
                That depends, what is the signal that seems odd? Perhaps you are just not measuring it correctly.
                Once I get the isolation transformer, it should matter what I plug into it, am I correct? I can plug either the scope into it or the device under test. I just need one to be not sharing the same ground with the other. If I had a scope that had isolated inputs, I should still purchase an isolation transformer though, right?
                Typically you want to put the DUT on the isolation transformer. NOT the scope. In some very rare cases it would be desirable to 'float' the scope, but it's dangerous.
                It will add some safety (for you) to use an isolation transformer anyway, if you have isolated inputs or not.
                Finally, I still don't understand why when I tried probing the transformer it caused sparks on my oscilloscope. I understand an isolation transformer will prevent this, but I don't understand why it happened to begin with. Could someone try explaining what went wrong?
                I thought you were probing a crystal?
                -David VanHorn
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  #188
                  This time, I was probing a crystal, but the first time I tried using my scope, maybe a year or so ago, I tried using it on this worklight. I put the probe on the transformer, expecting to see a waveform, but I did something horribly wrong and sparks flew. I was lucky I didn't get hurt. After that, until now, I was afraid to use the thing! I just never had time to sit down and research it, but I feel a lot more confident now in my abilities.
                  I'll pull out the signal generator tomorrow and see what signal it is. I want to say the triangle wave.
                  • pajdek
                    Lenovo Y700-17ISK turn on and off
                    by pajdek
                    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                    09-20-2023, 02:49 AM
                  • RdeveLabs
                    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                    by RdeveLabs
                    To all the members here...
                    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                    05-05-2025, 04:59 AM
                  • robante15
                    Acer Aspire 4520 won't turn on after reboot
                    by robante15
                    Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                    It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                    The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                    If I remove the...
                    04-06-2024, 06:50 PM
                  • masoksian
                    Dell latitude e7470 not turn on .power buton on off and Run Power problem
                    by masoksian
                    I am dealing with the problem of turning on and off my Dell e7470 notebook.
                    The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                    The system does not turn on, there is no post.
                    I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                    The problem continues in the same way.
                    I tried to turn on the Fn key, nothing came to the screen....
                    02-15-2025, 12:08 PM
                  • Ledgurra
                    MacBook Pro A1425 it doesn't turn on
                    by Ledgurra
                    hello! hope you are all well. i have a macbook pro a1425 and it won't turn on. i took it to the service center and they said it's fine, it turned on 2 times and then it wouldn't turn on. on the power supply there is a yellow dot that is charging and turns green when charging but when i turn it on it doesn't turn on. i opened it and saw on the motherboard that 2 elements are missing, i am attaching the photos for you to understand better.
                    thank you all
                    11-09-2025, 06:07 AM
