Element ELEFW40C won't turn on.
    Re: Element ELEFW40C won't turn on.
    Put the meter probes on those two legs of that filter cap that shows 37VDC, then hit the power switch to see if it even attempt to go up higher that 37VDC or not.
    • Spork Schivago
      • Mar 2012
      • 4734
      • United States of America
      #102
      I did as you asked and it stays at 37.2VDC. My wife pushed the power button a few times, just to make sure. It didn't even move a little.
      -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
        One thing is that I do not expect the 12V to be present all the time otherwise it will running 24/7. Some thing has to switch on.
          BTW, you may as well check the DCV of the rest of the pins.
          • Spork Schivago
            • Mar 2012
            • 4734
            #105
            I'll double check and see if that 12VDC is on VIN when the TV is first plugged in (before it's turned "on"). I don't think I can check all the pins. They're too close together. My probe will short them out.
            • Spork Schivago
              • Mar 2012
              • 4734
              #106
              Okay, the VIN has 12.10VDC, whether I push the on button or not. The outer other three pins all have 0VDC on them. I haven't tried checking the inner ones.
              That one capacitor that has the 37VDC, should I try pulling that and checking it with my ESR meter? The top isn't swollen but for some reason, to me, it just doesn't look right. Maybe I'm just not used to looking at caps on their sides like that though.
              • Spork Schivago
                • Mar 2012
                • 4734
                #107
                I found another picture of that chip. I believe it's the same picture as before, but this appears to be the complete picture, whereas the first one appeared to be cropped a little.
                https://img-fotki.yandex.ru/get/1949..._2c4d30f7_orig
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  #108
                  Budm, I'm an idiot. It's not an 8-pin chip, it's a 10-pin chip. So maybe the top chip, UB802, is our chip, not UB801. I looked at it under the lighted magnifying glass I have and counted the pins again. Sorry!
                  I wonder if the ISET pin can be used to turn it on and off?
                  On a Russian website, someone asked for the datasheet for that SN51DP. Someone else told them to compare it to this chip, because they're very similar: https://cdn.badcaps-static.com/pdfs/...92964173d4.pdf
                  That link is for an 8-pin, but it tells us what the various pins are, minus those two extra ones that my SN51DP has (the ISET and REF). I believe ISET is current set.
                  • Spork Schivago
                    • Mar 2012
                    • 4734
                    #109
                    Also, this SMD component that I think is an SMD capacitor seems to have really high resistance when I put probes on each end of it. It measures around 14 Mohm. Is that normal? The other ones in that area don't measure anywhere near that! I was thinking maybe it's a bad capacitor.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      #110
                      Capacitors normally read Meg ohms to open circuit when tested with a multimeter. Best to check with capacitance meter.
                      • Spork Schivago
                        • Mar 2012
                        • 4734
                        #111
                        Thank you.
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          #112
                          The Hisense 40H3E seems to have the same board, from what I can tell (MS3393.PB851)
                          A Westinghouse DWM42F2G1 service manual or schematic might work as well. The audio connections are a bit different, but the rest of the board is the same....
                          Maybe we can find a schematic for one of those televisions and use it to help fix this one?
                            That is MLCC, common failure mode is shorted or very low resistance, I doubt that it is bad. We are working without the diagram an without spec the spec sheet for the parts so it is not going to be easy, we know what the power supply sections are, the backlights LED power supply are, but we do not know where the command signals are.
                            • Spork Schivago
                              • Mar 2012
                              • 4734
                              #114
                              Do you have any suggestions on how I might find them command signals? I was thinking (which is never any good!). I can press the power button and I see the voltage drop on the pin for the power button. Can I try to trace that somehow? Maybe put the DMM in continuity mode and try tracing where that power pin goes to? Then, maybe try to follow the electricity or something? Maybe that'd give us a better idea what's going on.
                              Element got back to me but all they said was they suggest I call support and gave me an 800 number. I highly doubt support is going to send me a service manual. They'll just say I need to send the board in for repair. Do you think it's worth even calling them?
                                The command signals will be coming from the Micro controller, so you need to know which pins are assigned for the command output, and that output nay be buffered by a transistor and so on and on, without diagram you will then be reverse engineering the board to find out how it is configured.
                                How much is the replacement board?
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  #116
                                  I got my needle probes and went back to that LED Driver IC. I measured the pins. There's no change when it's "off" and "on". All of them show 0.000VDC, except for two pins.
                                  Code:
                                  Pin 1: 12.10VDC
                                  Pin 9: 0.664VDC
                                  According to that diagram, pin 1 is VIN (which I believe is correct) and pin 9 is OVP. I believe that's the Over Voltage Protection input pin for Boost mode.
                                  • Spork Schivago
                                    • Mar 2012
                                    • 4734
                                    #117
                                    I couldn't find a replacement board for this television, but I didn't look too hard, I just checked shop jimmy. I'll look at other sites now and see how much one is.
                                    • Spork Schivago
                                      • Mar 2012
                                      • 4734
                                      #118
                                      60$ OBO, free shipping, on e-bay, for a used one. That's the cheapest one I could find. They have other ones at around 135$.
                                      • Spork Schivago
                                        • Mar 2012
                                        • 4734
                                        #119
                                        I measured the voltages on the eeprom or whatever you want to call it. The 8-pin 25Q16BSIG ( http://www.datasheet4u.com/pdf/25Q16...65306#download )
                                        I was hoping maybe it really is bad. I saw a lot of pins that had 3.32VDC on them.
                                        Code:
                                        pin 1: 0.000VDC
                                        pin 2: 3.320VDC
                                        pin 3: 3.320VDC
                                        pin 4: 0.000VDC
                                        pin 5: 0.000VDC
                                        pin 6: 0.000VDC
                                        pin 7: 3.321VDC
                                        pin 8: 3.321VDC
                                        After looking at the datasheet though, I think the pins that have voltage are supposed to have voltage. I didn't see anything on the output channel, but I probably wouldn't unless I was measuring it while someone pushed the on button.
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          #120
                                          60$ isnt too bad for a combined board theres a lot on it i guess its down to what the customer want too pay for a repair.
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                          • robante15
                                            Acer Aspire 4520 won't turn on after reboot
                                            by robante15
                                            Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                            It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                            The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                            If I remove the...
                                            04-06-2024, 06:50 PM
                                          • masoksian
                                            Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                            by masoksian
                                            I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                            The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                            The system does not turn on, there is no post.
                                            I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                            The problem continues in the same way.
                                            I tried to turn on the Fn key, nothing came to the screen....
                                            02-15-2025, 12:08 PM
                                          • dqtech
                                            lenovo x240 nm-a091 wont turn on
                                            by dqtech
                                            i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                                            board number VIUX1 NM-A091 REV:1.0...
                                            02-07-2024, 01:57 AM
