Samsung ue32t5300ak
  • comptek
    • Aug 2013
    • 606
    • uk
    Samsung ue32t5300ak
    SAMSUNG UE32T5300AK
    problem is standby light on just flickers when power button pressed same with remote, beleive its the dredded corrupt firmware if anyone like Lotas can check to see if its corrupt all voltages seem to be there
    still doing the same with screen, wifi, speakers disconnected
    regards
    gary
  • lotas
    • Jan 2016
    • 5398
    • Russia
    Re: Samsung ue32t5300ak
    Here is a working dump, check with it.
    • comptek
      • Aug 2013
      • 606
      • uk
      thanks Lotas, been trying but
      keeps coming up "chip %s with the contents are in disagreement"
      im using a bog standard progrm for the ch341a
      • lotas
        • Jan 2016
        • 5398
        • Russia
        This firmware is working, checked more than once, maybe you have a problem in another. Checked to run without a panel? Here is another worker, try it.
        • comptek
          • Aug 2013
          • 606
          • uk
          Hi Lotas I will try that when I'm home
          The error I'm getting is on the programming software nothing on tv screen was disconnected and still there was no change
          I will try your other firmware asap I'm out at the minute thanks bud
          Regards
          Gary
          • lotas
            • Jan 2016
            • 5398
            • Russia
            So maybe you have a problem with eMMC firmware.
            • comptek
              • Aug 2013
              • 606
              • uk
              Lotas you're a star god bless you
              It worked Tv it now working
              Kind regards
              Gary
              • lotas
                • Jan 2016
                • 5398
                • Russia
                Ok!
                • westwoodx
                  • Feb 2023
                  Hi, I also just wanted to thank you lotas, as I stumbled upon this thread trying to fix my UE32T5300 with no picture/sound/backlight and only an intermittent pulsing power LED.
                  The second firmware on this thread (ENQ2540.zip) didn't work for me but the first one did (UE32T5300AU dump 25q40.rar)!!
                  Many thanks again for your great work!!
                  • PetakiSK
                    • Mar 2023
                    • Slovakia
                    Thank you Lotas.
                    I have a SAMSUNG UE32T5372AU TV with the same problem.
                    Your Dump helped me. Thank you again
                    • drugfreejukie
                      Hi after some advice I have the same tv with same issue I presume I need to purchase the ch341a then use this ti flash the firmware on my tv? any pointers would be a massive help Thanks
                      • nomoresonys
                        • 12370
                        • U.S.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          This guide may help https://www.youtube.com/watch?v=z9uLPo9QAY8
                          • edgodd__
                            • Jul 2024
                            I have used this to fix mine, thank you!
                            Same blinking light thing, now works a charm
                            (EN25Q40.zip​ file)
                            • Tony6996
                              • Nov 2022
                              just want to give a big thanks to the guys here
                              i almost gave up trying to fix a Samsung tv but fortunately stumbled across these posts at the last minuet
                              • comose
                                • Mar 2017
                                • GER
                                EN25Q40.zip - Works on GU32T5379AU.
                                Reprogramm with CH341 3,3V Mod & NeoProgrammer V2.2.0.10
                                Many Thanks
                                • Sr. Electrónico
                                  • Feb 2018
                                  • España
                                  The second dump "UE32T5300AU dump 25q40.rar​" worked on my tv UE32T5305
                                  • Rekap69
                                    • May 2023
                                    • uk
                                    Ok!
                                    hi , i need some help locate my chip as im new in this and trying fix my tv
                                    is this the one?
                                    thanks
                                    • lotas
                                      • Jan 2016
                                      • 5398
                                      • Russia
                                      Yes, EN25Q40.
                                      • Rekap69
                                        • May 2023
                                        • uk
                                        Yes, EN25Q40.
                                        ok ,perfect i am going to try , i was in doubt as mine doesnt have the EN25Q40 wrighting on it.
                                        thank you
                                        • Boardview and Schematic Bot
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
