Eeprom dump thread!
This is a sticky topic.
  • lotas
    • Jan 2016
    • 4668
    • Russia
    #1581
    Re: Eeprom dump thread!
    Here is an approximate programmer log for bad blocks, indicating at which addresses they are located:
    Request for bad blocks...Normal
    Number of bad blocks: 6
    Block 0x000D (13) address 0x00D00000 (0x00DB1200) Bad block
    Block 0x057B (1403) address 0x57B00000 (0x5C5ABE00) Bad block
    Block 0x058E (1422) address 0x58E00000 (0x5D9AEC00) Bad block
    Block 0x0645 (1605) address 0x64500000 (0x69A6C200) Bad block
    Block 0x06BE (1726) address 0x6BE00000 (0x719DCC00) Bad block
    Block 0x0819 (2073) address 0x81900000 (0x88754A00) Bad block
    • img1
      • Aug 2015
      • 21
      • Earth
      #1582
      Originally posted by lotas
      There can't be that many BBs "Total bad blocks: 1,467."
      Erase completely and check again.
      Erased 3 times in a row. This is my full log what FlashCat software produces:
      Welcome to the FlashcatUSB interfacing software, build: 645
      Copyright 2023 - Embedded Computers LLC
      Running on: Windows (64 bit)
      FlashcatUSB Script Engine build: 312
      Serial NOR memory database loaded: 502 devices supported
      Serial NAND database loaded: 67 devices supported
      Parallel NOR memory database loaded: 405 devices supported
      Parallel NAND memory database loaded: 273 devices supported
      Connected to FlashcatUSB Mach?, firmware version: 2.29
      OTP/UV EPROM memory database loaded: 46 devices supported
      Voltage set to: 3.3V
      Detecting connected Flash device...
      Initializing Parallel NAND device mode
      I/O mode successfully initialized
      Attempting to automatically detect Flash device
      NAND clock speed set to: 20MHz
      Mode NAND X8 ASYNC returned ident code: 0xECD5847250
      Successfully detected device in NAND mode
      Connected to Flash (CHIP ID: 0xECD5847250)
      NAND device failed to load ONFI table
      Flash detected: Samsung K9GAG08U0E (2,176,843,776 bytes)
      Programming mode: Parallel I/O
      Page Information: 128 total pages; 8,192 bytes per page; 436 bytes extended size
      Block Information: 2,076 total blocks; 1,104,384 bytes per block
      Device interface: NAND (X8 3.3V)
      Loading NAND memory map for valid memory
      Total bad blocks: 1455
      NAND memory map complete: 79,488 pages available for access
      Flash device successfully detected and ready for operation
      About the full chip erase it doesn't provide detailed information, only 2 lines:
      Sent memory erase command to device: Samsung K9GAG08U0E
      Successfully erased NAND Flash device
      I'll try to find where it logs the BBs list. Or is it not worth that because is it a highly damaged NAND beyond 'point of no return' ?
      • img1
        • Aug 2015
        • 21
        • Earth
        #1583
        No official BB list produced, so I managed to wrote down the BBs from the programs graphical interface. It is not less than 1455 (picture):
        2-13, 137, 215-377, 471-497, 499-510, 512, 514-518, 520-522, 524-532, 534-535, 537-561, 563-568, 570-584, 586-619, 621-626, 628-632,
        634-640, 642-699, 701-753, 755-768, 770-790, 792, 794-835, 837-847, 849, 851-896, 898-916, 918-959, 961-1024, 1026-1051, 1053-1106,
        1108-1140, 1142-1152, 1154-1195, 1197-1206, 1208, 1210, 1212-1221, 1223-1271, 1273-1280, 1282-1291, 1293-1408, 1410-1428,
        1430-1487, 1489-1515, 1517-1521, 1523-1530, 1532, 1534-1536, 1538-1650, 1652-1664, 1666-1787, 1943, 2033-2040, 2043, 2074.
        • lotas
          • Jan 2016
          • 4668
          • Russia
          #1584
          But there cannot be so many physical Bad Blocks, it can be the remains of a dump and in it these BBs or the programmer considers them as ECC.
          Try to thoroughly clean all the legs of the Nand Flash from flux, rinse it in isopropyl alcohol and acetone, here you need good contact between the legs and the adapter itself.
          • img1
            • Aug 2015
            • 21
            • Earth
            #1585
            I did it initially before I did anything (fiber glass pen + isopropyl alcohol), but I'll give it a second chance. Now I did it again.
            Something I don't understand: when the software recognising the NAND the message is "loading NAND memory map for valid memory, total bad blocks: 1455". And when I fiddled with the "Analyze" button in the "NAND memory map" menu, a window popped up with "Warning, this operation will erase and overwrite all blocks, continue?". Yes, of course and the process finished less than a second and then the displayed green-black blocks changed to yellow with a question mark in them, and the title says "NAND blocks analyzed (0 bad blocks found). But if I redetect (reinitialize) the NAND, the number of the BBs remains 1455.
            • lotas
              • Jan 2016
              • 4668
              • Russia
              #1586
              Yes, it’s strange here either the nand flash is completely dead (try to find exactly the same used or new one) or the programmer does not understand the algorithm of this nand, I have never had more than 10 physical BBs in this NAND.
              • img1
                • Aug 2015
                • 21
                • Earth
                #1587
                Yes, it's strange here either the nand flash is completely dead (try to find exactly the same used or new one) or the programmer does not understand the algorithm of this nand, I have never had more than 10 physical BBs in this NAND.
                I think the software is buggy. After I turned off the bad block management and erased the NAND and activated back the BB management, the number of the bad blocks decreased to 7. I really hope this is their valid number.
                137, 657, 1943, 2033, 2039, 2040, 2074.
                • lotas
                  • Jan 2016
                  • 4668
                  • Russia
                  #1588
                  Yes, now it looks more like the truth, but for some reason the BB at address 2073 is not shown, it is present on everyone, even in these new nands.
                  • img1
                    • Aug 2015
                    • 21
                    • Earth
                    #1589
                    Interesting. What if we take it as bad, that won't be a problem if we don't write on that block, isn't it?
                    Edit: As I found I can manually discard blocks as bad blocks, so I discarded the 2073.
                    Edit 2: It is just temporary so not written onto the BB table. After I redetected the NAND the manually disabled block disappeared. Or maybe I did something wrong.
                    • lotas
                      • Jan 2016
                      • 4668
                      • Russia
                      #1590
                      This is what happened under your BB.
                      • lotas
                        • Jan 2016
                        • 4668
                        • Russia
                        #1591
                        In private messages there is a link to your dump, write it down as is (without missing BB!).
                        • luzmina
                          • May 2015
                          • 17
                          • US
                          #1592
                          Hi Lotas, I have this Roku 43" TV that the standby light is on but do not respond to power ON, I replace the CPU with a good one from a similar good board of a 32", problem was the same then I put the NAND from the 32" and the 43" turn ON, backlight turn ON, respond to remote control but no picture, then I read the original NAND and programmed on the new NAND, now the TV have stand by light and does not turn ON, I suspect those Roku TVs are reading the CPU serial number so they do not work with a new CPU, here are the 2 files:
                          https://drive.google.com/file/d/1yvU...usp=drive_link
                          https://drive.google.com/file/d/1T8m...usp=drive_link
                          • Rajnhl
                            • Oct 2018
                            • 94
                            • India
                            #1593
                            start first with small and easy step.
                            Software/firmware is 1st step then hardware.
                            • mrdoob
                              • Nov 2013
                              Hi. I am looking for the firmware for an RCA RLDED4031A-RK (Canada). Main board TP.MS3393.P85.
                              EEPROM: 25Q16BSIG
                              Right now the TV just has the red LED and does nothing else.
                              • lotas
                                • Jan 2016
                                • 4668
                                • Russia
                                #1595
                                EEPROM: 25Q16BSIG
                                Post your non-working dump here, I'll take a look and maybe I'll fix it.
                                • mrdoob
                                  • Nov 2013
                                  The TV doesn't even come on, only the red LED is On. I have no way to get the dump. At least not that I know of.
                                  • lotas
                                    • Jan 2016
                                    • 4668
                                    • Russia
                                    #1597
                                    How are you going to program someone else’s dump of your flash, do you have a programmer? If there is, read the contents of your flash and post it here.
                                    If it does not go into operating mode, then most likely your firmware is damaged, you read the contents (dump) of your 25Q16BSIG and show it to me, I will restore it and it will be operational and then you will download my corrected dump and your TV will work again, when provided that the problem is in the firmware.
                                    • mrdoob
                                      • Nov 2013
                                      How are you going to program someone else's dump of your flash, do you have a programmer? If there is, read the contents of your flash and post it here.
                                      Thanks Lotas. I have been doing ecectronics repairs for a long time, but this is the first time that I need to do a firmware load. I will look into getting a porgrammer. I was hoping that with a USB drive I could just load new firmware. Like I said, this is my first time.
                                      • lotas
                                        • Jan 2016
                                        • 4668
                                        • Russia
                                        #1599
                                        On this chassis you will not be able to download the firmware via USB, you will not even have access to USB, just update it if the TV is fully working, and only through the programmer.
                                        • amine23
                                          • Apr 2017
                                          • 86
                                          • Algeria
                                          #1600
                                          hi every one i need dump of Thoshiba Toshiba 40bv700f part number 17mb61-2
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            07-26-2025, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
