Eeprom dump thread!
This is a sticky topic.
  • jimbofz
    • Apr 2013
    • 539
    • uk
    #1461
    Re: Eeprom dump thread!
    i now understand thanks for advice
    • jimbofz
      • Apr 2013
      • 539
      • uk
      #1462
      hi can anyone help with dump for philips 65PUS6162,05
      MB NUM:715G8709 MOE BOO 005N
      maybe the same as 55inch model?
      chassis TPM17.7E LA
      • yokoono
        • Apr 2010
        • 488
        #1463
        Chassis TPM17.7E LA or TMP17.7E LA ?.
        • jimbofz
          • Apr 2013
          • 539
          • uk
          #1464
          im confused?
          • jimbofz
            • Apr 2013
            • 539
            • uk
            #1465
            sorry its TPM i must remember to wear my glasses
            • luzmina
              • May 2015
              • 17
              • US
              #1466
              jimbofz: in those Chinese tvs, if the only issue is no sound the problem is the sound amp, make sure the sound IC has power before replacing it, if no sound after replacing it then the issue is the microcomputer.
              • lotas
                • Jan 2016
                • 4668
                • Russia
                #1467
                chassis TPM17.7E LA
                Here the error is not "O", but "0" correctly so 715G8709 M0E B00 005N
                • yokoono
                  • Apr 2010
                  • 488
                  #1468
                  Software pkg
                  https://files.fm/u/eqd8g2ejw
                  • jimbofz
                    • Apr 2013
                    • 539
                    • uk
                    #1469
                    Originally posted by lotas
                    Try
                    many thanks
                    new spi chip with your dump works fine on technika
                    • jimbofz
                      • Apr 2013
                      • 539
                      • uk
                      #1470
                      Originally posted by yokoono
                      many thanks for this dump
                      im having problem writing extracted .bin file to chip
                      my new chip is :st m24128b wmn6p
                      the ch341a programmer only has up to
                      m24c64 when you select manufacturer st from list
                      when i select atmel at24c128bi get
                      "chip memory with contents disagreement " message
                      can you advise please
                      • lotas
                        • Jan 2016
                        • 4668
                        • Russia
                        #1471
                        What program do you have for CH341A?
                        • jimbofz
                          • Apr 2013
                          • 539
                          • uk
                          #1472
                          version 1.30
                          • lotas
                            • Jan 2016
                            • 4668
                            • Russia
                            #1473
                            version 1.30
                            Install this program
                            https://www.badcaps.net/forum/showpo...7&postcount=51
                            • lotas
                              • Jan 2016
                              • 4668
                              • Russia
                              #1474
                              Or this
                              • Slimmwill
                                • Dec 2021
                                #1475
                                can you help looking for firmeware for a hisense h55m3300 can anybody help
                                • jimbofz
                                  • Apr 2013
                                  • 539
                                  • uk
                                  #1476
                                  ok installed siberia prog
                                  LOOKS GOOD DESIGN ,
                                  connected ch341a with new blank eeprom soldered on : m24128 bwmn6p
                                  changed language to english
                                  entered
                                  ;EEPROM 24XX
                                  24C128
                                  i get:recognition error?
                                  any ideas ?
                                  • lotas
                                    • Jan 2016
                                    • 4668
                                    • Russia
                                    #1477
                                    Do you correctly insert it (eeprom) into the programmer? Post a photo of how it's installed.
                                    • jimbofz
                                      • Apr 2013
                                      • 539
                                      • uk
                                      #1478
                                      it seems that if the chip is blank it shows
                                      recognition error
                                      i am now able to write to chip
                                      but it only took a few seconds to write is that normal?
                                      i expected it to take more time?
                                      • lotas
                                        • Jan 2016
                                        • 4668
                                        • Russia
                                        #1479
                                        Eeproms are written quickly, but there should not be a recognition error, most likely you have not recorded anything.
                                        • lotas
                                          • Jan 2016
                                          • 4668
                                          • Russia
                                          #1480
                                          Detect chip?
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            07-26-2025, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
