Eeprom dump thread!
This is a sticky topic.
  • cheeky2
    • Dec 2012
    • 337
    • uk
    #1901
    Originally posted by lotas
    Try this dump, but the panel is unknown.
    Thanks I will give it a go over the next few days and let you know the results
    • dinche_ze
      • Feb 2020
      • 16
      • Bosnia Hercegovina
      #1902
      hello friend
      I need spi flash for TESLA TV
      model: 43S306BF
      dont know matric number
      • lotas
        • Jan 2016
        • 4665
        • Russia
        #1903
        Originally posted by dinche_ze
        hello friend
        model: 43S306BF
        Don't you know the motherboard number either?
        • dinche_ze
          • Feb 2020
          • 16
          #1904
          • lotas
            • Jan 2016
            • 4665
            • Russia
            #1905
            Post here your original, non-working dump, I'll try to fix it.​
            • dinche_ze
              • Feb 2020
              • 16
              #1906
              problem is that remote control is not working, other things works fine.
              • lotas
                • Jan 2016
                • 4665
                • Russia
                #1907
                So what does the firmware have to do with it? If it doesn't work for you via the remote control, check the remote control, try via a universal remote control. If it doesn't work, replace the IR receiver, make sure the pulses reach the processor...
                • dinche_ze
                  • Feb 2020
                  • 16
                  #1908
                  probao sam, ispravan daljinski, nece ni univerzalni. a ir prijemnik sa 4 pina,( 2 gnd, na jednom stalnih 5V, a na drugom 5V koji opada na 3,5V kada koristim daljinski), nemam takav ir da bi testirao ,mada sumnjam da je do njeg jer reaguje
                  • cheeky2
                    • Dec 2012
                    • 337
                    • uk
                    #1909
                    Thanks Lotas it worked a treat
                    • lotas
                      • Jan 2016
                      • 4665
                      • Russia
                      #1910
                      Ok!
                      • dinche_ze
                        • Feb 2020
                        • 16
                        #1911
                        Pozdrav prijatelji,
                        imam Toshiba 32el933g TV. Samo crveno svjetlo svijetli, ne pali se ni ništa. Kada sam ažurirao firmware, otkrio sam da se TV uključuje, ali nema slike. Mislim da se matrica ne podudara. Moja matrica je LG. Za drugu ne znam. Objavit ću originalni firmware od TV-a i novi ako netko zna kako ih uskladiti.
                        • lotas
                          • Jan 2016
                          • 4665
                          • Russia
                          #1912
                          Pozdrav prijatelji,
                          Try.
                          • dinche_ze
                            • Feb 2020
                            • 16
                            #1913
                            Try.
                            it works.
                            than you very much
                            • lotas
                              • Jan 2016
                              • 4665
                              • Russia
                              #1914
                              it works.
                              than you very much
                              That's good.
                              • Salvatore Cancellieri
                                • May 2025
                                • 8
                                • Italia
                                #1915
                                Hi everyone, I have a 65" Philips TV, it turns on and after a while it restarts endlessly, I checked the power supply and everything is ok, I disconnected all the devices and the panel but it continues to restart, I assume it is a dump problem, below is the original dump
                                TV model 65PUS6523/12
                                Board model 703TQHPL433 715G8709-M0B-B01-005K​
                                • luzmina
                                  • May 2015
                                  • 17
                                  • US
                                  #1916
                                  Here is the dump for the Hisense 70H6570G and 70A6G. It fixed the corrupted EMMC issue that put the TV into a loop.
                                  Board RSAG7.820.9783/ROH
                                  https://drive.google.com/file/d/129h...usp=drive_link
                                  • digitel
                                    • Apr 2013
                                    • 9
                                    • Alicante
                                    #1917
                                    Please, do you have the firmware for a Hitachi 43HAE4251 TV, with Mainboard 17MB171 and Panel VES430UNDH-N2-N45? The memory is not SPI Flash. It's EMMc. Thank you.
                                    • sordids999
                                      • May 2013
                                      • 2156
                                      • uk
                                      #1918
                                      Hi does anyone have the firmware for a Panasonic 50lx650 main board 17mb185
                                      Screen ves500qnzh-n2-z01
                                      23798312
                                      • digitel
                                        • Apr 2013
                                        • 9
                                        • Alicante
                                        #1919
                                        Hitachi 43HAE4251 firmware
                                        Please, do you have the firmware for a Hitachi 43HAE4251 TV, with Mainboard 17MB171 and Panel VES430UNDH-N2-N45 The memory is not SPI Flash. It's EMMc. Thank you.
                                        • kamaku
                                          • Jul 2014
                                          • 6
                                          • Spain
                                          #1920
                                          Hi does anyone have the usb firmware or emmc dump for a Cecotec ALH30032S main: TPD.RT2841A.PB782
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            07-26-2025, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
