Eeprom dump thread!
This is a sticky topic.
  • Gjackson
    • Aug 2021
    • 134
    • Malta
    #1701
    Anyone have a dump for a SHARP lc-55sfe7332e?
    Thank you
    • lotas
      • Jan 2016
      • 4668
      • Russia
      #1702
      Thank you
      Mainboard T.MS6308.711?
      What problem do you have in your firmware?
      • Gjackson
        • Aug 2021
        • 134
        • Malta
        #1703
        Bootloop
        • lotas
          • Jan 2016
          • 4668
          • Russia
          #1704
          Bootloop
          What motherboard do you have (number), what panel?
          Dump what you need, Nand?
          Post your non-working dump here, I'll take a look.​
          • univers73
            • Nov 2020
            • 13
            • france
            #1705
            Originally posted by univers73
            I need to flash the eeprom of this tcon :
            Model : Samsung QE55Q80RAT
            Tcon : BN94-14062G
            Eeprom : 25Q40CLSIP
            Thanks.
            Please ? 😢
            • lotas
              • Jan 2016
              • 4668
              • Russia
              #1706
              Tcon : BN94-14062G
              Eeprom : 25Q40CLSIP
              Thanks.
              Motherboard (textolite) bn41-02695a?
              What's the problem with your dump?​
              • univers73
                • Nov 2020
                • 13
                • france
                #1707
                The tv won't turn on, every voltage are present, checked the screen, backlight... It started with the TV randomly won't turn on, light present, no blinking. I can't check the motherboard's model right now.
                • lotas
                  • Jan 2016
                  • 4668
                  • Russia
                  #1708
                  But this could be a problem with eMMC, post your 24Q40 firmware here and I’ll take a look.
                  • univers73
                    • Nov 2020
                    • 13
                    • france
                    #1709
                    Thank for your help, here the dump. By the way, also a pic of the model.
                    • lotas
                      • Jan 2016
                      • 4668
                      • Russia
                      #1710
                      Your dump is working, try yours, but with a cleared nvm.
                      • univers73
                        • Nov 2020
                        • 13
                        • france
                        #1711
                        I just tried, still no boot, i will continue my research, thank anyway for you help.
                        • univers73
                          • Nov 2020
                          • 13
                          • france
                          #1712
                          I have a last question, I have another eeprom on this tcon witch it contains the firmware (25q80), it is possible that it can be corrupted ?
                          • cccamgeek
                            • May 2009
                            • 13
                            #1713
                            hard to find new come dumped from working set
                            "Haier LET29C800" OR "MGS eled29"
                            same in two brand name :
                            main MSDV3218-ZC01-01
                            Mainboard/chassis: MSDV3218-ZC01-01
                            Painel display LCD: V290BJ1-PE1
                            Dump flash SPI 25Q32
                            • kamaku
                              • Jul 2014
                              • 6
                              • Spain
                              #1714
                              Someone can check , After logo it restart again.
                              model: OK ODL32661HN-DIB
                              Main: TP.MS3663S.PB818
                              Panel HK315LEDM
                              • lotas
                                • Jan 2016
                                • 4668
                                • Russia
                                #1715
                                Panel HK315LEDM
                                Try with a clean NVM.
                                • lotas
                                  • Jan 2016
                                  • 4668
                                  • Russia
                                  #1716
                                  Does not work?
                                  • kamaku
                                    • Jul 2014
                                    • 6
                                    • Spain
                                    #1717
                                    Yes was not working, "power-up, logo and reset" .
                                    Finally loaded the firmware for one "ok odl 32631H-SB EL" from post https://www.badcaps.net/forum/troubl...64#post1683821 , worked only remote control is diferent and used one universal one.
                                    • Ipyong tech
                                      • Jan 2022
                                      • Phillipines
                                      #1718
                                      hello,
                                      I have samsung tv UA65NU7300g no power, no standby light but if i remove the connector of motherboard the backlight is working and 12.8 volts is present. need help for dump file of IC1604 25q40cl.
                                      i have backup of the original file. can please check my dump if its ok. Thank you.
                                      Hello.. Master lotas.. need your help. thank you
                                      • lotas
                                        • Jan 2016
                                        • 4668
                                        • Russia
                                        #1719
                                        Originally posted by Ipyong tech
                                        hello,
                                        Mainboard ?
                                        I don't see a problem with your dump, it's working.
                                        • Ipyong tech
                                          • Jan 2022
                                          • Phillipines
                                          #1720
                                          thank you.. master lotas for checking my dump... now i know that my dump is good. the problem maybe somewhere in motherboard.
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            07-26-2025, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
