Eeprom dump thread!
This is a sticky topic.
  • Cf elettronica
    • May 2023
    • 10
    • Italy
    #1541
    Re: Eeprom dump thread!
    I could try with your version. Do you think it could work as well?
    • lotas
      • Jan 2016
      • 4668
      • Russia
      #1542
      Are you sure you have a problem in firmware 25Q40? You can try with my dump, just don't forget to keep your native dump!
      • Cf elettronica
        • May 2023
        • 10
        • Italy
        #1543
        I'm pretty sure it's a firmware issue. I only have ch341 programmer so i'm not able to flash the nand chip. I hope for the best or i will buy new tv. My readings into chip are most FF and some others unsignificant values. Any ideas for tv stuck on boot logo?
        • lotas
          • Jan 2016
          • 4668
          • Russia
          #1544
          In this chassis, flashing eeprom (24C256) often helps from freezing on the "Smart TV" log, if it does not help, then flashing the entire set (eMMC, Spi flash and Eeprom).
          • Cf elettronica
            • May 2023
            • 10
            • Italy
            #1545
            Just in case, please do you have also the eeprom file? My eeprom is labeled IC901 part number s24c51. Thank you
            • Cf elettronica
              • May 2023
              • 10
              • Italy
              #1546
              Do anyone has it please?
              • lotas
                • Jan 2016
                • 4668
                • Russia
                #1547
                Who, exactly what?
                • datriad
                  • Jan 2014
                  Does anyone have a dump For Vizio m60 d1 please
                  • sylves
                    • Apr 2016
                    • 10
                    • usa
                    #1549
                    I have a Samsung un55ku6290f that turns on as soon as I plug it up. There is backlight but that's it. No image or remote control functions at all. Could this be a bad bios.
                    • rott
                      • Jan 2015
                      • cyprus
                      #1550
                      Hi guys I'm looking for a firmware for a Samsung tv, model UE55J6200AWXXH
                      Board code BN41-02353B
                      Model : BN41-02353
                      Thank you
                      • sylves
                        • Apr 2016
                        • 10
                        • usa
                        #1551
                        Insignia NS-50L260A13
                        Here is a working spi flash for Insignia ns-50L260A13
                        • kyowee
                          • Aug 2014
                          #1552
                          I need flash dump for Sharp LC-60LE740E mainboard DKEYDF733FM65, QPWBXF733WJN2
                          • lotas
                            • Jan 2016
                            • 4668
                            • Russia
                            #1553
                            Dump what eeprom, nand...? Post your non-working dump here.
                            • kyowee
                              • Aug 2014
                              #1554
                              The nand I need (IC8401), i thought mentioning flash would be enough.
                              The non working one is not relevant, the guy from whom the set is, upgraded the TV from USB stick for a different main board (LC-60LE745U) so now the lvds isn't working.
                              • lotas
                                • Jan 2016
                                • 4668
                                • Russia
                                #1555
                                Link to dupm nand in private messages, try it.
                                • kyowee
                                  • Aug 2014
                                  #1556
                                  Thank You lotas!
                                  • xurplusxhop
                                    • Jan 2012
                                    • 36
                                    #1557
                                    I need working bin for HAIER LE32F6500 TV (TP.VST59S.PB813).
                                    Attached is my dump bin file. thanks
                                    • lotas
                                      • Jan 2016
                                      • 4668
                                      • Russia
                                      #1558
                                      xurplusxhop Your dump soft is live, try with the nvm cut out.
                                      • rddube
                                        Aspiring Expert
                                        • Jun 2013
                                        • 944
                                        Need help fixing dump for a Toshiba 32L310UL believed to be corrupt
                                        I would need help trying to fix this dump for a Toshiba 32L310U20 believed to be corrupt. I've searched everywhere, but could not find the firmware for this model.
                                        When plugged in, the TV just turns on the red light, then off, then flashes 5 times. No response to power on, just stays off. If I unplug, and plug back in, again same scenario.
                                        Many thanks, or if anyone has a working dump, it would be appreciated!
                                        • lotas
                                          • Jan 2016
                                          • 4668
                                          • Russia
                                          #1560
                                          Re: Need help fixing dump for a Toshiba 32L310UL believed to be corrupt
                                          Try
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            07-26-2025, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
