Eeprom dump thread!
This is a sticky topic.
  • RRice25541
    • Nov 2015
    • 47
    Re: Eeprom dump thread!
    nop still not working,
    I can put the code from an Emerson ELEFW328 on the board and the tv will come on fine all functions work,, except that i have to go into the service mode and change LVDS_ODD to LVDS_EVEN to correct the image..
    also the image is upside down..
    I couldn't find a way to change the model info, actually i never saw the model number listed anywhere
    couldn't find a way to flip the image in there anywhere either.
    The code from the original eeprom and the corrected eeprom you uploaded will allow the tv to come on but there is no image
    • lotas
      • Jan 2016
      • 4589
      • Russia
      #1202
      So it's not the firmware of the Element ELEFW505 (the problem is in the board itself)
      I don’t understand what it means to “put the code from Emerson ELEFW328”, do you mean rearrange the SPI Flash itself with firmware from one board to another?
      What is your panel? Number of your panel (matrix).
      • RRice25541
        • Nov 2015
        • 47
        If i take the code from the elefw328 and write it to the eeprom using the VGA connection from my RT809F programmer, the tv works fine except for the image being upside down.
        the panel is V500HJ1-RX01
        • lotas
          • Jan 2016
          • 4589
          • Russia
          #1204
          ELEFW505 has Full HD panel and ELEFW328 HD Ready. In service mode, you can not flip the image (mirror...)
          • RRice25541
            • Nov 2015
            • 47
            so the problem is the code from the ELEFW505
            • lotas
              • Jan 2016
              • 4589
              • Russia
              #1206
              The ELEFW505 dump is working, most likely it is not native, someone before you programmed a dump from another TV model there.
              • antas
                • Jul 2014
                • 148
                • Ireland
                #1207
                Originally posted by antas
                Could I get a USB firmware update for:
                TV: Walker
                MB: 17MB110P
                PB: 17IPS62
                Panel: VES315WNDA-2D-N12
                Thank you very much in advance
                Or even dump file, please?
                • RRice25541
                  • Nov 2015
                  • 47
                  that's very possible , I have been getting a lot of tv's lately where the owners have monkeyed around with them before they bring them in for repair.
                  so it's very possible they tried a firmware from another unit or something..
                  i guess the only way to know for sure is to get an actual dump from a working unit
                  • lotas
                    • Jan 2016
                    • 4589
                    • Russia
                    #1209
                    There is a Dump ( SPI Flash MX25L1605 ) from CROWN 32289T2SM (17MB110P, VES315WNDA-2D-N12), but there is no NAND dump, do you need it?
                    • antas
                      • Jul 2014
                      • 148
                      • Ireland
                      #1210
                      Yes, please?
                      • lotas
                        • Jan 2016
                        • 4589
                        • Russia
                        #1211
                        Ok
                        • antas
                          • Jul 2014
                          • 148
                          • Ireland
                          #1212
                          Ok
                          Thank you
                          • antas
                            • Jul 2014
                            • 148
                            • Ireland
                            #1213
                            Thank you
                            Unfortunately... Tv not working with this dump...
                            Any more ideas?
                            • lotas
                              • Jan 2016
                              • 4589
                              • Russia
                              #1214
                              17mb110p Dumps.
                              • RRice25541
                                • Nov 2015
                                • 47
                                ok so i think? i found the issue with the element, but I'm not 100% sure.
                                I'm hoping someone can help with some panel pinouts..
                                I don't think this unit has the correct panel type, maybe there's no difference, i don't know
                                but i think the correct panel type should be V500HJ1-PE8 and not the currently installed panel V500HJ1-XR01
                                I cannot find panel info on either of them
                                • antas
                                  • Jul 2014
                                  • 148
                                  • Ireland
                                  #1216
                                  17mb110p Dumps.
                                  Thank you very much. I'll try them.
                                  • mazloum
                                    • Sep 2012
                                    • 499
                                    • Lebanon
                                    #1217
                                    Hi, I need dump for hyundai tv HY-LED39E9300
                                    TP.VST59S.PB813
                                    THANKS
                                    • lotas
                                      • Jan 2016
                                      • 4589
                                      • Russia
                                      #1218
                                      TP.VST59S.PB813
                                      THANKS
                                      Post your non-working dump here, I'll fix it.
                                      • mazloum
                                        • Sep 2012
                                        • 499
                                        • Lebanon
                                        #1219
                                        https://www.mediafire.com/file/s9y29...90615.BIN/file
                                        thanks in advanced
                                        • lotas
                                          • Jan 2016
                                          • 4589
                                          • Russia
                                          #1220
                                          Did you spell the TV model correctly - "HY-LED39E9300"?
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            07-26-2025, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
