Eeprom dump thread!
This is a sticky topic.
  • yokoono
    • Apr 2010
    • 485
    #1161
    Re: Eeprom dump thread!
    1. Format a stick with FAT32
    2. Unzip and put the 4 files directly on the stick
    3. Insert the stick into the TV
    4. Press and hold the OK key on the remote control
    5. Plug in the TV
    6. The TV's stby LED flashes slowly and then quickly. Now release the OK key
    7. Wait for it to finish. It may take 5-10 minutes.
    If after this operation the remote control is no longer useful, use a programmable one or a Vestel one.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #1162
      5. Plug in the TV
      Thank you i will try it once the remote arrives.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #1163
        Hi remote came and mainboard will not take the update at all i just get a brief flash of backlight at power on ( i do have a diffrent mainboard that uses the same panel the tv powers on and works ok) i cant keep this board in the set as is missing some ports like scart rca plugs extra hdmi port but board swap proves psu and backilights work fine so must be a fault on main bga ic i guess.
        • Unspun01
          • Jun 2011
          • 341
          Does anyone have EEPROM or SPI FLASH firmware for 60" LG model 60LB5200?
          Mainboard is 5800-A6M630-0P20
          part number COV32945801
          See attached image of mainboard.
          Thanks in advance.
          • lotas
            • Jan 2016
            • 4597
            • Russia
            #1165
            Thanks in advance.
            Post your non-working spi flash dump here, I'll try to fix it.
            • Unspun01
              • Jun 2011
              • 341
              Hi lotas:
              Thank you for replying.
              I attach two files:
              [1] NON-WORKING SPI flash dump from 60" LG model 60LB5200-UA.
              [2] WORKING SPI flash dump from 65" LG model 65LB5200-UA.
              Normal TV behavior upon plug-in is for power LED to flash green for a second or two, then turn red and stay red until power button is pressed on TV or remote.
              Problem symptom is green power LED upon plug-in, and stays green at all times. No response to any buttons on TV, or remote. No backlights, no audio, no video. Completely unresponsive.
              I tried the BIN file for the 65", and my TV turns on, but image is very bad with psychedelic rainbow colors since it uses a completely different panel. I only upload for you in case it helps you determine fault by comparison.
              I hope to hear from you.
              • lotas
                • Jan 2016
                • 4597
                • Russia
                #1167
                Ok, do you know the model (processor number) of MStar?
                • Unspun01
                  • Jun 2011
                  • 341
                  Hi lotas:
                  Processor under heat sink is MSD3393LU.
                  • lotas
                    • Jan 2016
                    • 4597
                    • Russia
                    #1169
                    Done, try it.
                    • Unspun01
                      • Jun 2011
                      • 341
                      Done, try it.
                      Hi lotas:
                      Thank you - I downloaded the file but no time to try it today. I will try tomorrow and report back.
                      I have a question though - The original BIN file I uploaded is 4,194,304 bytes. The file you uploaded is 3,173,140 bytes. There is larger than 1MB difference in file size.
                      I expected the files to be the same size. Is the file you uploaded the correct size? How can I program this smaller file? Do I need to fill or pad with 1's or 0's? I don't know much about that.
                      Let me know your thoughts.
                      Thanks.
                      • lotas
                        • Jan 2016
                        • 4597
                        • Russia
                        #1171
                        Hi lotas:
                        Thanks.
                        Hello, it's not so bad that the size is smaller, the programmer will fill the free space by itself FF FF...
                        • Unspun01
                          • Jun 2011
                          • 341
                          Hi lotas:
                          The .BIN file you modified for 60" LG model 60LB5200 is working for my TV.
                          Thank you very much!
                          What was the problem? How did you find the problem? What did you do to fix the problem?
                          • Rajnhl
                            • Oct 2018
                            • 94
                            • India
                            #1173
                            Done, try it.
                            hello bro, how do your repair bin files.any special tool for that or you are a programmer.
                            • Unspun01
                              • Jun 2011
                              • 341
                              Hi lotas:
                              Here is SPI flash dump from 32" RCA RLED3216A. Mainboard is CV318H-X with MSD3391DS processor. The EEPROM at position U10 is Winbond W25Q16V.
                              The TV turns on, displays the RCA logo, then screen flashes entirely green for a split second, then clearly shows the channel number 2-0 in upper corner with static on screen (it is not connected to antenna), then resets itself continuously.
                              Please have a look at it and let me know if you can assist.
                              • lotas
                                • Jan 2016
                                • 4597
                                • Russia
                                #1175
                                Hi lotas:
                                The core is whole, cut off the tail, try it.
                                • Unspun01
                                  • Jun 2011
                                  • 341
                                  Hi lotas:
                                  My 32" RCA model RLED3216A is now working after re-programming my existing EEPROM IC with your "fixed" .BIN file.
                                  Thank you for your assistance!
                                  When you "cut off the tail", what does deleting this information do? In the "fixed" file, it looks like you deleted everything including and after offset 0018F504h? How did you determine where to delete the remainder of data?
                                  This offset is certainly specific to this file and may not apply to other files, but I think it would be great to know how you picked this location?
                                  Thanks again!
                                  • lotas
                                    • Jan 2016
                                    • 4597
                                    • Russia
                                    #1177
                                    The core itself is in the dump, this is its software, panel, remote ... and eeprom (the tail that I cut off) it stores the settings, after deleting this eeprom section, when you turn on the TV for the first time, the processor itself prescribes the initial settings, like from a store.
                                    • dyomil
                                      • Jan 2019
                                      • philippines
                                      #1178
                                      looking for samsung tv model no.LA32C4OO EEPROM DUMP thank you i appreciate it a lot
                                      • dyomil
                                        • Jan 2019
                                        • philippines
                                        #1179
                                        i need eeprom dump to flash my samsung tv model no.LA32C400 main board model LOLA3_C400 please help
                                        • lotas
                                          • Jan 2016
                                          • 4597
                                          • Russia
                                          #1180
                                          This is suitable from Samsung LN32C400E4 L0LA3_C400
                                          BN41-01526A (25Q64VFIG)?
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            07-26-2025, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
