Eeprom dump thread!
This is a sticky topic.
  • dinche_ze
    • Feb 2020
    • 19
    • Bosnia Hercegovina
    #701
    Re: Eeprom dump thread!
    vox led tv dump need u10, u12
    led32783
    mainb: 17mb82s
    panel: VES315WNDB-02
    • ktgohdt125
      • Jun 2010
      • 10
      #702
      does anyone have Eeprom files for Philips 48PFA4609/98 Firmware
      I was saving a copy of the working EEPROM .bin files to post over here but the files which were only reading a 64kb size, re-read and re-save another copy still 64kb size, after that, I proceed to erase the file and reprogram back using the files save previously, the tv seems not responding any more!!
      so, anyone has this particular model dump files??
      ps. normally how big is the size of the dump files from a working tv??
      • arizanotlari
        • Nov 2014
        • 158
        • Turkiye
        #703
        led32783
        mainb: 17mb82s
        https://yadi.sk/d/_X9A0UGQ2Cqe1g
        https://www.badcaps.net
        • dinche_ze
          • Feb 2020
          • 19
          #704
          thanks, I will try
          • spaljo
            • Jan 2020
            • Ireland
            #705
            Is it possible that noone have Eeprom files for philips 49PUS6162 would like to save my tv
            • dinche_ze
              • Feb 2020
              • 19
              #706
              Originally posted by arizanotlari
              Thanks, but its not working god, the picture od upside down and Graphics is low,
              • arizanotlari
                • Nov 2014
                • 158
                • Turkiye
                #707
                Panel files : https://yadi.sk/d/xO8YaifqoCqtgw
                extract pq folder to usb.
                access to service menu and select "usb operations"
                restart tv and check picture.
                • dinche_ze
                  • Feb 2020
                  • 19
                  #708
                  the file is damaged, can not opet
                  • RRice25541
                    • Nov 2015
                    • 47
                    Insignia NS-37D20SNA14
                    looking for an eeprom dump or a firmware update file for this tv
                    • arizanotlari
                      • Nov 2014
                      • 158
                      • Turkiye
                      #710
                      Update winrar.
                      • Kidface
                        • Feb 2019
                        • Uk
                        #711
                        Originally posted by cheeky2
                        Just had a Blaupunkt 43/134M-GB-11B-FEGUX-UK with main board TP.MS6486.PB711 and screen LC430DUY-SHA1
                        It required firmware which can be requested from here:
                        http://www.umc-poland.com/datasheet/...-11b-fegux-uk/
                        Use email to request it:
                        poland@blaupunkt-europe.com
                        Its 297MB in size so unable to upload here!
                        However looking at one of the files the 'UMC_KMODE.txt' contains details as to what is enabled ie PVR which is currently disabled so by changing these I have now enabled the PVR options on the TV. It works well now
                        Attached is the original file and modified one to enable the PVR options.
                        I would suggest if you wish to use the PVR that you use the 297MB file that UMC send you just substitute the 'UMC_KMODE.txt' file with the one in the modded folder.
                        The original and modded files are attached.
                        See attached pictures of PVR working
                        Hi, do you still got this firmware? On the UMC website the link is broken, couldn't download it
                        Can you upload it to afile sharing site? or do you have a working link?
                        Thanks!
                        • NMA78
                          • Feb 2020
                          • France
                          #712
                          Originally posted by ducky29
                          Sent him a firmware and it worked correctly.
                          Thank you tremors!
                          Hello, I'm having the exact same problem with my Toshiba 24w1334g. Would it be possible for you to send me the firmware so I can get it working ?
                          Thanks for your help.
                          • jellytot
                            • Mar 2015
                            • 42
                            • Ireland
                            #713
                            Try this! and if you could let us know if it worked for you ...
                            • NMA78
                              • Feb 2020
                              • France
                              #714
                              Thank you very much. In fact it is not working, I tried to flash it with simply putting the .bin in the USB and the led stayed black, nothing happened. Then I tried renaming it mb90_en.bin and placing the mboot.bin and the usb_auto_update_A1.txt with it. The led starts blinking but the process never ends (> 20 mn or so).
                              Is there anything I should do to make it work better ?
                              Thanks you very much for your help
                              • yokoono
                                • Apr 2010
                                • 510
                                #715
                                This soft is for programmer not for stick.
                                • sdfy
                                  • Apr 2019
                                  • Ukaine
                                  #716
                                  Hi Everyone,
                                  Does anyone have the dump for a
                                  Metz 49X79
                                  IC6022 25Q16
                                  • ducky29
                                    • Dec 2015
                                    • 369
                                    • Europe
                                    #717
                                    Pls pm me
                                    • Rajnhl
                                      • Oct 2018
                                      • 94
                                      • India
                                      #718
                                      http://www.dl.toshiba.com/dtv/NA/GB/EN/24W1334G.html
                                      try this
                                      • Jovica123
                                        • Oct 2017
                                        • 84
                                        • N/A
                                        #719
                                        Does anyone have NAND for sony kdl-32r415b ?
                                        Thank you.
                                        • pocketwatch62
                                          • 74
                                          • US
                                          #720
                                          Hi Everyone,
                                          Vizio----D55u-d1
                                          Main Board----715G7689-M0C-000-005K-------GXFCB0QK024010X
                                          Panel----TPT550U2-EQYSHM.G REV:S1H
