Eeprom dump thread!
This is a sticky topic.
  • ans
    • Dec 2014
    • syria
    #801
    Re: Eeprom dump thread!
    Hi, if possible, I need a Dumb Dump. Please help, my group. Thank you. A new screen is not necessary for you to work. Thank you
    dell-se2216h-monitor
    • arizanotlari
      • Nov 2014
      • 158
      • Turkiye
      #802
      Originally posted by skyx
      Thank you very much .. but for Philips 17MB82 file (panel)?
      What is VES code?
      https://www.badcaps.net
      • pocketwatch62
        • 74
        • US
        #803
        Hello all,
        Does anyone have a dump for a Element?
        Model----ELEFW248
        serial #----F75BM
        MAIN BOARD--- TP.MS3553.PA671------------ELEFW248 F7B5M Main---H17051233
        UF1 on the board.
        THANKS
        • LUXMAN
          • Mar 2014
          • Italia
          #804
          hi someone have a firmware for a SANSUI tvc2510
          • psycho_sev
            • Nov 2019
            • england
            #805
            Please can anyone help, i need serial flash (25Q32FVSIG) for technika
            model 22E21B-FHD
            board T.MSD306.80
            panel M215HGE-L21
            • lsizquierdo
              • Nov 2015
              • 6
              • Cuba
              #806
              I have a plasma which the standby led is in red without response, the model LG 42PN4500-UA I need the dump of the 8mb spi if someone could provide it. These are the photos of the pcbs with their respective modelsD
              • Range
                • Aug 2020
                • portugal
                #807
                good presiso of firmware for tv
                Blaupunkt "32" B32A173TCFHD - Mainboard t.msd309.9B 10345 could someone help me
                • dragometin
                  • Aug 2016
                  • 20
                  • France
                  #808
                  Model: Crown ALCD1509SGB
                  MainBoard: B.SPC81B-1 9245
                  Screen: LP156WH1-TLA1
                  Model: Grundig 22VLE4520BF
                  MainBoard: VTY190R-23
                  Screen: T215HVN01
                  • Rajnhl
                    • Oct 2018
                    • 94
                    • India
                    #809
                    Toshiba_32PT200ZE DUMP
                    PANEL LTA320HN03
                    TCON DUMP included
                    • Range
                      • Aug 2020
                      • portugal
                      #810
                      Blaupunkt "32" REF: B32A173TCFHD -
                      Model code: 32 / 173I-GB-5B-FHBKU-EU
                      Customer code: BA320173BFBKUE340
                      could someone help me turn on the led but it turns red
                      • Rajnhl
                        • Oct 2018
                        • 94
                        • India
                        #811
                        model number is different but board is same.backup before flashing.
                        if it starts and turn off immediately check power supply for bad capacitors.
                        • baluka3
                          • Aug 2020
                          • Hungary
                          #812
                          Hi!
                          Can you send me this firmware? Download link does not work
                          Thanks!
                          Originally posted by cheeky2
                          Just had a Blaupunkt 43/134M-GB-11B-FEGUX-UK with main board TP.MS6486.PB711 and screen LC430DUY-SHA1
                          It required firmware which can be requested from here:
                          http://www.umc-poland.com/datasheet/...-11b-fegux-uk/
                          Use email to request it:
                          poland@blaupunkt-europe.com
                          Its 297MB in size so unable to upload here!
                          However looking at one of the files the 'UMC_KMODE.txt' contains details as to what is enabled ie PVR which is currently disabled so by changing these I have now enabled the PVR options on the TV. It works well now
                          Attached is the original file and modified one to enable the PVR options.
                          I would suggest if you wish to use the PVR that you use the 297MB file that UMC send you just substitute the 'UMC_KMODE.txt' file with the one in the modded folder.
                          The original and modded files are attached.
                          See attached pictures of PVR working
                          • JeffJ
                            • Apr 2012
                            • 189
                            Anyone have a dump from a LG 32LH500B / LG 32LH520B ?
                            • cheeky2
                              • Dec 2012
                              • 338
                              • uk
                              #814
                              Originally posted by baluka3
                              Hi!
                              Thanks!
                              Why have I put the following here in the details???
                              Use a better web translator for translation to your language.
                              • ans
                                • Dec 2014
                                • syria
                                #815
                                Welcome to the EEPROM SE2216HV Main Board 790JW1300601R00
                                Dell
                                https://www.4shared.com/get/JS_pneAR...4_E2216HV.html
                                • Farasa
                                  • Jul 2016
                                  • 47
                                  • South-Africa
                                  #816
                                  Hi all
                                  I'm looking for firmware for a logic 46 inch lcd tv..stuck on standby
                                  Chassis number:Rsag7.820.2164
                                  Panel. :Lta460hm05
                                  Thanks in advance
                                  • Farasa
                                    • Jul 2016
                                    • 47
                                    • South-Africa
                                    #817
                                    Hi anyone available
                                    • Rajnhl
                                      • Oct 2018
                                      • 94
                                      • India
                                      #818
                                      Originally posted by Farasa
                                      Hi anyone available
                                      There are 3 files try one by one.if you have any programmer try to read dump from your tv then write one of any file from my zip file.then again write your dump some time this helps.
                                      • jose almeida tavares
                                        • May 2011
                                        • 8
                                        #819
                                        Finlux fl5031uswk chassis 17mb120
                                        Hell. This tv not work. the front led, flash one time when the tv is conected in ac and not work. i need the data for memory dump. the pael is ves500qndc-2d-n12.
                                        • Farasa
                                          • Jul 2016
                                          • 47
                                          • South-Africa
                                          #820
                                          Thanks a lot..I will do that
