Philips 32PHH4100 faulty power supply (dropping voltage)
Re: Philips 32PHH4100 faulty power supply (dropping voltage)
Is R9146 = 0 ohms as should be. It looks OK in the photo but?
You also said that when you switch on the 12V supply is there and then starts falling. What is the voltage across pins 3 & 4 of U9102 when you initially switch on and after the 12V output supply drops.Last edited by dick_barton; 01-13-2017, 07:41 AM.Willing to help but I'm no expert.Comment
Yes that jumper resistor is 0 ohms. Let's clarify what happens to the 12v output: when the board is plugged in, it starts off at around 5v and slowly works itself up to around 11.5 and then stays there until the output is loaded. When loaded, it goes down to around 7.5. When the load is removed, it slowly goes back up to 11v.
I believe you meant U9101 in your previous reply, not 9012. If so, you want me to measure between ground and the CS pin (3 and 4) ? I get nothing between GND (4) and CurrentSense (3)...Last edited by Dannyx; 01-13-2017, 08:03 AM.Wattevah...Comment
I did mean the Opto-isolator (U9102)to check that when the 12V was supplied to the output, that it was driving the led within U9102 and switching on the transistor which in turn would short C9124 (1nF) to ground.
I'm looking at page 59/150 of the manual given in the earlier post.Willing to help but I'm no expert.Comment
Oh, right....terribly sorry for the mess-up. I forgot the opto is treated as "U" as well. Still, I get absolutely nothing between its pins. However, on the LED side, I get around 1.8v on its terminals.I did mean the Opto-isolator (U9102)to check that when the 12V was supplied to the output, that it was driving the led within U9102 and switching on the transistor which in turn would short C9124 (1nF) to ground.
I'm looking at page 59/150 of the manual given in the earlier post.Wattevah...Comment
OK so nothing (0 Volts) between pins 3 & 4 would correct when it's switched on by the diode and 1.8V across Pins 1 & 2 would be ON.
Does the 1.8V remain between Pins 1 & 2 even when the output voltage falls.Last edited by dick_barton; 01-13-2017, 09:34 AM.Willing to help but I'm no expert.Comment
BTW, what DCV do you have between two legs of C9116 or C9122?Never stop learning
Guys, you're not gonna believe this but the TV is working....WTF ?! I didn't do anything else - just took that last measurement of the optocoupler and noticed the voltage on the output caps was slightly higher this time (12.02v) so I put the bulb on it and this time it remained on....tried it on the TV and it fired right up. I believe it's been working for about an hour now, even from cold start-ups. Hate it when things fix themselves out of the blue. Let's hope it actually stays this way, though this could be a false sense of achievement, because something is probably only working half the time and I got lucky :|Wattevah...Comment
I get 18v now that the set is working (see my latest post), but even when it didn't I'd still get around 17 with no load and they would drop to about 12v from what I recall.Wattevah...Comment
I would be tempted to take the voltage readings around the PF6003AS and note them on your schematic (& post) in the event that it plays up again.
Any possibility that the Opto has a poor solder joint?Last edited by dick_barton; 01-13-2017, 11:01 AM.Willing to help but I'm no expert.Comment
It's not the original one - I replaced it as one of the first things I tried, so I believe I did a good job on those joints. Might actually go in there with some solder again just to make sure....Wattevah...Comment
OK, but the voltage readings with the set now running would be useful to others when checking around that IC.Willing to help but I'm no expert.Comment
Right, I'll probably do that on Monday because, as per usual, it's at work and I have the day off tomorrow
Wattevah...Comment
ThanksWilling to help but I'm no expert.Comment
Ok, back with some measurements on this suddenly-functional board as promised. Readings were taken with no load and nothing attached to the power supply.
Primary (GND is - of bridge rectifier or - leg of C9801):
-C9801: 330v (on a 230v mains supply)
-U9010: 11.5v on Pins 6 and 8 (VCC). 1.2v on Pin 1
-C9105: 12.5v (before diode D9106)
-C9102: 11.5 (VCC for U9010)
Sec (GND is chassis GND unless otherwise noted)
-C9101, 9109 and 9121 (actual numbering of caps might differ from the schematic) - 12.5v
-U9102 (across its terminals): 1.2v
-C8616 and C8612 (LED output): 18.2v (driver off), 29-30v (driver on)
Let me know if I missed anything you wanted to know.....while the TV's still around, for I'll have to return it soon if it doesn't decide to crap out on me again
Wattevah...Comment
Maybe its a cracked solder somewhere? You probably measured something and applied pressure and now its working again.
Something thats broken does not fix itself
Well ok, I DID change a couple of things, not just measured it and hay-ho it's working
Wattevah...Comment
Thanks for the reading which may prove to be extremely helpful to anyone else with this problem. Hope the set now behaves itself.Willing to help but I'm no expert.Comment
Hopefully...it's been working fine for almost 2 days now, counting the time I turned it off to let it cool down to ensure it doesn't work only thanks to heat, so it should be fine
Wattevah...Comment
Assuming...7 Photos -
by sam_sam_samI want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
https://www.ebay.com/itm/116497313155?var=416785404161
Here are some of the description from the eBay seller
The main parameters:
1. Product name: High-power non-isolated DC boost module power supply.
2. Product model: 100A2000W.
3. Input voltage: DC12V-60V.
4. Input current: 100A (maximum).... -
The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...-
Channel: Common Parts Library - Datasheets
10-07-2024, 04:12 AM -
by sam_sam_samI have been pondering this question for a while but now I have see if this doable but I need to answer this question once and for all
I would like to know how to safely do this undertaking my first thought is to solder wires to the main filtering capacitors and see
what voltage I am getting and seeing if I can build a battery pack with voltage or not and if
I can find a BMS balancing protection board at this voltage level and weather or not do I have use more than one BMS balancing protection board... -
by labelloHello everybody I try to fix thi power supply, I have voltage in bridge rectifier, and also in the large capacitor , so I thought the problem was in the pfc but then I found all mosfet ok(tested out of the circuit so I just moved on in the low voltage and here I found a short of one of the diode rectifier. I'll replaced it already but it's completely dead, I mean any stanby voltage and the other voltage is not present. I don't have oscilloscope to understand if the chip work how can I test it? Thank you for the help 🙏
- Loading...
