Philips 32PHH4100 faulty power supply (dropping voltage)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Re: Philips 32PHH4100 faulty power supply (dropping voltage)
    Originally posted by Dannyx
    I'll now try pulling them out and measuring them off-board
    They are fine: 3.3 meg-ohm - measured and confirmed.
    Wattevah...
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Is R9146 = 0 ohms as should be. It looks OK in the photo but?
      You also said that when you switch on the 12V supply is there and then starts falling. What is the voltage across pins 3 & 4 of U9102 when you initially switch on and after the 12V output supply drops.
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        Yes that jumper resistor is 0 ohms. Let's clarify what happens to the 12v output: when the board is plugged in, it starts off at around 5v and slowly works itself up to around 11.5 and then stays there until the output is loaded. When loaded, it goes down to around 7.5. When the load is removed, it slowly goes back up to 11v.
        I believe you meant U9101 in your previous reply, not 9012. If so, you want me to measure between ground and the CS pin (3 and 4) ? I get nothing between GND (4) and CurrentSense (3)...
        Wattevah...
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          I did mean the Opto-isolator (U9102)to check that when the 12V was supplied to the output, that it was driving the led within U9102 and switching on the transistor which in turn would short C9124 (1nF) to ground.
          I'm looking at page 59/150 of the manual given in the earlier post.
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            Oh, right....terribly sorry for the mess-up. I forgot the opto is treated as "U" as well. Still, I get absolutely nothing between its pins. However, on the LED side, I get around 1.8v on its terminals.
            Wattevah...
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #26
              OK so nothing (0 Volts) between pins 3 & 4 would correct when it's switched on by the diode and 1.8V across Pins 1 & 2 would be ON.
              Does the 1.8V remain between Pins 1 & 2 even when the output voltage falls.
                BTW, what DCV do you have between two legs of C9116 or C9122?
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  #28
                  Guys, you're not gonna believe this but the TV is working....WTF ?! I didn't do anything else - just took that last measurement of the optocoupler and noticed the voltage on the output caps was slightly higher this time (12.02v) so I put the bulb on it and this time it remained on....tried it on the TV and it fired right up. I believe it's been working for about an hour now, even from cold start-ups. Hate it when things fix themselves out of the blue. Let's hope it actually stays this way, though this could be a false sense of achievement, because something is probably only working half the time and I got lucky :|
                  Wattevah...
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    #29
                    I get 18v now that the set is working (see my latest post), but even when it didn't I'd still get around 17 with no load and they would drop to about 12v from what I recall.
                    Wattevah...
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      #30
                      I would be tempted to take the voltage readings around the PF6003AS and note them on your schematic (& post) in the event that it plays up again.
                      Any possibility that the Opto has a poor solder joint?
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        #31
                        It's not the original one - I replaced it as one of the first things I tried, so I believe I did a good job on those joints. Might actually go in there with some solder again just to make sure....
                        Wattevah...
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          #32
                          OK, but the voltage readings with the set now running would be useful to others when checking around that IC.
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            #33
                            Right, I'll probably do that on Monday because, as per usual, it's at work and I have the day off tomorrow
                            Wattevah...
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              #34
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                #35
                                Ok, back with some measurements on this suddenly-functional board as promised. Readings were taken with no load and nothing attached to the power supply.
                                Primary (GND is - of bridge rectifier or - leg of C9801):
                                -C9801: 330v (on a 230v mains supply)
                                -U9010: 11.5v on Pins 6 and 8 (VCC). 1.2v on Pin 1
                                -C9105: 12.5v (before diode D9106)
                                -C9102: 11.5 (VCC for U9010)
                                Sec (GND is chassis GND unless otherwise noted)
                                -C9101, 9109 and 9121 (actual numbering of caps might differ from the schematic) - 12.5v
                                -U9102 (across its terminals): 1.2v
                                -C8616 and C8612 (LED output): 18.2v (driver off), 29-30v (driver on)
                                Let me know if I missed anything you wanted to know.....while the TV's still around, for I'll have to return it soon if it doesn't decide to crap out on me again
                                Wattevah...
                                • Moreno83
                                  • Jun 2014
                                  • 2008
                                  • The Netherlands
                                  #36
                                  Maybe its a cracked solder somewhere? You probably measured something and applied pressure and now its working again.
                                  Something thats broken does not fix itself
                                  • Dannyx
                                    CertifiedAxhole
                                    • Aug 2016
                                    • 3912
                                    #37
                                    Well ok, I DID change a couple of things, not just measured it and hay-ho it's working
                                    Wattevah...
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      #38
                                      Thanks for the reading which may prove to be extremely helpful to anyone else with this problem. Hope the set now behaves itself.
                                      • Dannyx
                                        CertifiedAxhole
                                        • Aug 2016
                                        • 3912
                                        #39
                                        Hopefully...it's been working fine for almost 2 days now, counting the time I turned it off to let it cool down to ensure it doesn't work only thanks to heat, so it should be fine
                                        Wattevah...
                                        • CapLeaker
                                          Leaking Member
                                          • Dec 2014
                                          • 8352
                                          Things like that I keep for at least a week.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                            Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
                                            I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
                                            https://www.ebay.com/itm/116497313155?var=416785404161
                                            Here are some of the description from the eBay seller
                                            The main parameters:
                                            1. Product name: High-power non-isolated DC boost module power supply.
                                            2. Product model: 100A2000W.
                                            3. Input voltage: DC12V-60V.
                                            4. Input current: 100A (maximum)....
                                            05-18-2025, 09:45 AM
                                            LM358 LM358S-13 Datasheet
                                            The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
                                            Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...
                                            10-07-2024, 04:12 AM
                                            How to modify a switching power supply that has voltage/current adjustable but powering it from a battery pack
                                            I have been pondering this question for a while but now I have see if this doable but I need to answer this question once and for all
                                            I would like to know how to safely do this undertaking my first thought is to solder wires to the main filtering capacitors and see
                                            what voltage I am getting and seeing if I can build a battery pack with voltage or not and if
                                            I can find a BMS balancing protection board at this voltage level and weather or not do I have use more than one BMS balancing protection board...
                                            05-11-2025, 05:22 PM
                                          • labello
                                            Power supply Termaltake Smart Se 630w any voltage in output
                                            by labello
                                            Hello everybody I try to fix thi power supply, I have voltage in bridge rectifier, and also in the large capacitor , so I thought the problem was in the pfc but then I found all mosfet ok(tested out of the circuit so I just moved on in the low voltage and here I found a short of one of the diode rectifier. I'll replaced it already but it's completely dead, I mean any stanby voltage and the other voltage is not present. I don't have oscilloscope to understand if the chip work how can I test it? Thank you for the help 🙏
                                            09-09-2023, 12:06 PM
