LM358 LM358S-13 Datasheet
    The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
    Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly operated from the standard +5V power supply voltage which is used in digital systems and will easily provide the required interface electronics without requiring an additional ±15V power supply.
    LM358S-13 Features
    • Internally frequency compensated for unity gain
    • Large dc voltage gain: 100 dB
    • Very low supply current drain (500μA); essentially independent of supply voltage
    • Wide bandwidth (unity gain): 1MHz (temperature compensated)
    • Input common-mode voltage range includes ground
    • Differential input voltage range equal to the power supply voltage
    • Low input offset voltage: 2mV
    • Wide power supply range:
    o Single supply: 3V to 32V o Dual supplies: ±1.5V to ±16V
    • Large output voltage swing: 0V to V+ - 1.5V
    • SOP-8L packaging
    • "Green" Molding Compound (No Br, Sb)
    • Lead Free Finish/ RoHS Compliant (Note 1)
    LM358S-13 Applications
    • Eliminates the need for dual supplies
    • Compatible with all forms of logic
    • Two internally compensated op amps
    • Low power drain ideal for battery operation
    • Allows direct sensing near GND
    • VOUT can swing to GND
    LM358S-13 Unique Characteristics
    • In the linear mode the input common-mode voltage range includes ground and the output voltage can also swing to ground, whilst operating from only a single power supply voltage.
    • The unity gain crossing frequency is temperature compensated.
    • The input bias current is temperature compensated.​
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
    03-31-2024, 02:12 PM
    07-01-2024, 06:34 AM
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
  • JimBanville
    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
    by JimBanville
    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
    09-13-2023, 07:21 AM
